mk@mkcolling.com
Properties panel missing things in css mode (CS4)
May 14, 2009 3:26 PM
Hi - I'm doing a tutorial in css with a Dreamweaver CS4 pre-designed layout. I want to make a nav bar by using an unordered list and hyperlinking the words in the list.
My properties panel (bottom of the window) in css mode does not show a box for links or a gizmo for making lists, indents, etc.Shouldn't those be available?
Do I have to use the menus at the top? Do I switch to <>HTML to get the features that are missing in css mode?
Insights would be appreciated.
Thank you.
    May 14, 2009 4:20 PM   in reply to mk@mkcolling.com
    They are when you click on the HTML button on the Property inspector.
    May 14, 2009 6:19 PM   in reply to mk@mkcolling.com
    make sure that your dpi is set to 96, in your personize tab window, in windows
    May 15, 2009 4:23 AM   in reply to mk@mkcolling.com
    You're only switching display modes for the Property inspector, not anything to do with the methods used on the page or its rendering.
