I created a new RoboHelp project and tried to insert a graphic named Timeline.jpg. I got the following error:
Unable to rename file, "Timeline.jpg".
The filename contains illegal characters.
I tried inserting a graphic that I had used in a previous RoboHelp project and got the same error. Then I opened a previous RoboHelp project and was able to successfully insert the Timeline.jpg graphic into that project.
I'm on Windows XP and RoboHelp 8. I would really like to avoid having to re-install RoboHelp, but I'm not sure where to look to troubleshoot this error message. Any help on this matter would be greatly appreciated.
Thanks.
Hi kjc90 and welcome to the RH community.
I'm wondering if the project name is at fault here. Can you tell us what the project title is?
Read the RoboColum(n) for mutterings on RoboHelp, Technical Communication Suite and technical communication.
Sure. The project name is: Online Guide to Performance Management
Is it possibly too long?
It is longer than any project title I've ever used but it isn't too long. It also doesn't contain any special characters which I thought might be the issue. Is the project on a network drive?
It's not on a network drive, it's on my hard drive. I tried creating a project with a shorter name and importing a graphic and I still got the same error message.
And it's not source-controlled, I presume? When inexplicably odd behavior occurs, the two basic all-purpose fixes I have my writers try are 1) Reboot the PC, and 2) Rebuild the cpd file. If that doesn't work, then we dig deeper.
This fixes a *lot* of weird problems.
G
It's not source controlled and I knew enough to try rebooting, but that hasn't helped.
I'm new to RoboHelp and have been learning as I go. Therefore, I have limited knowledge of the cpd file, but would it really need rebuilding as soon as I create a project and try to insert a graphic into the first topic? If so, I'll look into rebuilding it.
In the meantime, I figured out something that makes it work.
Thanks for your response.
I figured out something that enables me to insert a graphic now.
Previously, I created the RoboHelp project in my Human Resources folder on my hard drive where I already have a couple of RoboHelp projects. This morning, I created a folder on my hard drive named Human Resources New and created a project in that folder. I can now insert graphics into this project.
Since any new project I create in the Human Resources folder won't allow me to insert graphics, I figure the error has something to do with that folder or the other projects in that folder. While I am slightly curious about the problem with the folder, I'm just glad I don't have to re-install RoboHelp.
Thanks for your input on this matter.
Hi there
Perhaps try attaching the image to this thread? If you can do this I'd be happy to download it and see if I get the same issues when attempting to insert into one of my own RoboHelp projects.
In this rare case, I'm advising to use the actual Attach function as opposed to my normal advice to insert the image inline.
Cheers... Rick
Thanks for the offer, but I'm pretty sure you wouldn't have any problem inserting the graphic. Since I was able to insert the graphic into one of my other RoboHelp projects and I'm not able to insert ANY graphic into this RoboHelp project, the graphic isn't the problem. It's something with the project itself or the folder where it resides.
Creating the project in a new folder seems to have resolved the issue.
Did anyone ever make progress on this?
A colleague is now unable to import images to her project (RH8.02, CHM output, Windows XP, local disk, no source control); she gets 'Unable to rename file, "SAXS_1_32_slit.png". The filename contains illegal characters'. Other images give a similar message.
I can import the image to a test project on my PC; her project is quite large (some 3000 topics) so I don't want to copy it to my PC if I can avoid it.
What strikes me as odd is that RoboHelp has no need to rename anything. It should simply copy the image to the project directory and insert it into the HTML. We can verify that the image is copied in OK; she just can't import it.
Jeff `jonestech' described a similar problem in http://forums.adobe.com/message/2390997#2390997
Obviously we tried zapping the CPD and rebooting -- no help. Any ideas?
--- Derek
We're having trouble with this too. Any solutions?
We're having the same problem. With three copies of RoboHelp 8 HTML running in the office (all under Windows XP Pro), two of us can insert images with absolutely no problem, and the third gets an "illegal characters" error on virtually every image. In fact, I'm able to insert the very same images with no problem at all, while my co-worker gets the error message. We've done all the usual, including rebooting, deleting the CPD file, and so on.
I guess our next step will be to re-install RoboHelp. It does seem like this is becoming a a more pervasive problem.
A copy of the image is attached, although it shouldn't be the source of the problem because I can import it with no problem.
Did your colleague try inserting a graphic into a test project that was placed in a totally separate folder? This would be the fix used by the original poster. If that works, then I'd try copying the project (minus cpd) into a new location and trying again.
HTH,
G
In January I posted that a colleague had this problem. The beastie has now hit another colleague, so that 40% of our team is suffering.
Did anybody ever get a workaround?
--- Derek
I don't see anyone in this thread saying they have tried renaming the CPD and reopening the project. Just wondering if something got screwed up there.
Maybe also time to copy a project from someone with the problem to someone who is OK. Does the problem persist?
Now now, Peter, it's a bit early in the day but both LarryTX and I clearly stated the we had tried the CPD route.
Unfortunately these are pretty big projects (3000 topics) so copying is not a five-minute job. And my vacation starts tomorrow so I don't have time until the middle of August. Johan (my colleague) is monitoring this thread and will try any useful ideas.
--- Derek
You win on CPD, sorry I missed that.
Zipping up a 3000 topic project and putting it on a network shouldn't take long though.
Alternatively, if you want Johan to send it to me, I'll take a look.
Bang! bang! bang! That's the sound of the bug being nailed to the wall !
It turns out that there was an apostrophe (') in a folder name in the path (not the filename at all). When I renamed
D:\author_df\_MyNotes\RHtests\oldMyProduct\Generic
into
D:\author_df\_MyNotes\RHtests\oldMy'Product\Generic
I was unable to import an image. I changed the name back and I could import OK.
We had no problems with RoboHelp X5, so it's presumably appeared since then. Interestingly Windows allows the apostrophe -- see grab
That'll help to assure me of a relaxed vacation
--- Derek
Message was edited by: NL_Derek
I'm getting the same error.
This happened after I "upgraded" to 8.0.1.204 this morning. Worked fine yesterday before the upgrade. Now I can't insert any images at all, even ones I had inserted to the project earlier.
It says, "Unable to rename file," but I'm not trying to rename it at all.
Beats me...I'm at a standstill now.
It's extremely important that you now update to 8.0.2.208
You'll find it here:
http://www.adobe.com/support/robohelp/downloads.html
Then return here if your problem still isn't fixed.
John Daigle
Adobe Certified RoboHelp and Captivate Instructor
Yes, I did that - download 8.0.2. Problem persists...
Did you see my note that I can insert images as long as they're in the Robo "Gallery?"
But, it's the message, "Unable to rename file," that sounds like a bug, you know? Didn't ask Robo to rename a file.
Meanwhile the work-around helps...although my directory structure is going to be messed-up.
And THANKS, btw!
John
Here's an update:
I copied an image into Robo's "Gallery," clicked Insert>>Image and that worked.
Any advice from the "robotic sages" out there?
I did not see anything about a Gallery reference from you up-thread but down below??? I'm a bit confused now. This thread was started in 2009 and is getting a bit long in the tooth
Is your problem that you are not able to import images, or is it that you are interrupted by illegal character errors as shown by NL_Derek in post 18?
If you can import from the Gallery (where we know there are no mis-named folders) maybe you were trying to insert the original image from a mis-named folder? Honestly I don't know.What is the image format and does it display correctly once it's in your project?
This should not be a problem. Once you insert your image from the Gallery or anywhere else, it is automatically copied to your RoboHelp Project folder. From the Images pseudo-folder (as Rick calls it) in Project Manager you can then locate it and move it to any project subfolder you like by dragging and dropping.
John
Just to be clear also. Did you do the "Rename the .cpd file and reboot RoboHelp to recreate it?" as referred to by Peter up-thread?
