Cannot delete rogue menu from project
May 18, 2009 12:59 PM
I have a slideshow project and had sampled the Party Menu HD menu at one point but decided not to use it and created my own.  Now it still shows up in the Menus palette.  I have deleted it from the Sources directory in the project folder, however Encore says it notices that the file is missing and creates a placeholder, then it's back again.  How can I delete it permanently?
    May 18, 2009 1:04 PM   in reply to SynthMan65
    Can you delete in the Project panel? If not, does the newly-created menu cause any further trouble?
    May 18, 2009 2:21 PM   in reply to SynthMan65
    Can you delete it from the Menus panel, then?
    May 18, 2009 3:59 PM   in reply to SynthMan65
    If you can understand the problems, you'll be ahead of just about everyone.
    What you're seeing is not normal behavior. I suspect that your project is somehow corrupted. Have you tried doing a SaveAs on the project, and then deleting the menu?
    May 19, 2009 7:24 AM   in reply to SynthMan65
    I believe the cache files that Encore uses are limited to video and audio media, and not menus - but you can try deleting them anyway anyway and seeing if that helps (do this on a saved copy of the project, as I can't say for sure this would be completely safe and not affect the project itself); there is a Cache folder in the the project folder - delete it, then relaunch Encore, open the project and see if that helped any.
    I'm doubtful that will help, because far as I know, the code that Encore uses to automatically replace a missing menu lives in the project file. But I could be wrong. Be safe and work only on a copy of the project.
    May 19, 2009 9:00 AM   in reply to SynthMan65
    Rebuilding your project is usually the last resort, and one that I am reluctant to provide until everything else has been tried.
    Glad to hear you're back on track.
    May 20, 2009 6:21 PM   in reply to Joe Bowden
    I'm also glad that the OP got it going. One thing that I find extremely odd is that this is the third post, regarding the "Party" Menu, since about mid-April. Three different posters (or so they seem) have had issues with this same Menu. I wonder if there is a glitch in that particular Asset (a few of these have been found in Adobe PE's Menus). Three problems (albeit different problems) on the same Menu in a 30-day period puzzles me. Maybe it's just a popular Menu and all is coincidence. Still might be some little problem, that otherwise goes unnoticed.
    Curious,
    Hunt
    Apr 25, 2012 4:31 PM   in reply to SynthMan65
    Go to the menu panel to the left of the project (mine is on the left side middle), click on the menu you would like to erase and click "clear". That should delete the rogue menu from your project.
