Why does Photoshop CS4 keep crashing?! (Mac OS)
Jan 3, 2012 12:39 PM
  Latest reply: c.pfaffenbichler, Jan 9, 2012 11:56 PM
Replies 1 2 3 Previous Next
    May 15, 2009 1:08 AM   in reply to DGJ193
    "He said third party programs are suppose to write code to work with Apple, not the other way around. "
    Next time, ask him if he can read minds and predict the future perfectly.
    No?  Well, neither can Apple's developers.  We don't know all the bugs Apple has in their code, or what bugs they will add in future versions of the OS. A responsible OS vendor would fix their bugs, make sure their APIs work as documented (esp. don't crash), and test their new OS releases against existing applications to make sure the new OS works correctly.
    If we can work around the OS bug, we do.  If we know about an OS bug, we avoid it or get it fixed. (that happens a LOT on MacOS)
    But we can't read minds or predict the future.  Nor can we fix Apple's code for them.
    If I were you, I would call Apple and ask for a supervisor - the support person you spoke to was reading a generic problem solving script, not responding to the crashes you reported.
    May 15, 2009 3:45 AM   in reply to Chris Cox
    Hi Chris
    I realize that some things are out of the hands of Adobe. But it would be very helpful if Adobe posted an active list of "known problems". This would save everyone time and resources when trying to track down software problems.
    regards
    j
    May 15, 2009 2:25 PM   in reply to Chris Cox
    Chris Cox wrote:
    Reinstalling, etc. won't fix the bugs. Apple has to fix the code.
    That has yet to sink in with the OP.
    May 15, 2009 2:40 PM   in reply to Ramón G Castañeda
    this implies that there is a known bug with the OS that is causing the OP's problem..... what part of the code is causing the crashing?
    May 15, 2009 9:32 PM   in reply to - JM -
    Sigh. Apple says they didn't fix the text crasher(s) in 10.5.7.
    "this implies that there is a known bug with the OS that is causing the OP's problem..... what part of the code is causing the crashing?"
    If I knew that, I'd be able to fix Apple's bugs for them....
    May 16, 2009 4:54 AM   in reply to DGJ193
    Hi Chris,
    Sorry, I didnt mean the actual code. It's just that it's much easier if we know what the problems are. The OP is already getting fingers pointed in both directions. If the crash reports that everyone is sending in point to a problem with the OS then it would be best if we knew what not to do in the meanwhile that its "hopefully" being fixed.
    Does "text crash" point to font issues?
    I had misc crashes last month and went through some extensive cleaning and organizing, and this seemed to help.
    regards
    j
    May 16, 2009 12:18 PM   in reply to MacWright
    No, the "text crash" means that we use a text entry control somewhere in the UI, and the Apple code for that crashes for unknown reasons.   It seems worst when opening SFW or ACR, but crashes just about anywhere at any time -- only in MacOS 10.5.x.   MacOS 10.4.x hasn't seen that crash at all.
    Same things for the QuickDraw crash - it crashes at seemingly random times when the application draws something.  Kind of hard to avoid.
    If there was something simple you could do to avoid it, we would have already said or done something (like we have for font, TWAIN, and driver crashes).
    May 17, 2009 4:36 AM   in reply to Chris Cox
    Hi Chris
    Much appreciated.
    We buy hardware and software, send in crash reports and it tends to be a one way conversation as we wait for the occasional bug fix and unfortunately get tangled up in trying to repaiir problems that sometimes (as in this case) are not within our ability to fix.
    In a way, we are all partnered in business, the Adobe products are critical to our everyday work so I appreciate you taking the time to explain and to know that this is an active process.
    regards
    j
    May 17, 2009 8:36 AM   in reply to MacWright
    I had a problem recently that one I thought I fixed because I had duplicate helvetica fonts installed. But i also have a public beta call Flow install which was working fine, so I did not suspect it. I removed the fonts and that seemed to fix the disk error problem. the problem was after one or two adjustments I receive a could not complete because of a disk error warning which could not be dismissed cause a force quit of Photoshop.
    However after removing the duplicate fonts all was well and no disk error and for some reason Flow seemed to stop working.
    Then I updated to 10.5.7 and all was well then all of a sudden Flow seemed to be working and the disk error returned. So I turned it off and without thinking went and looked at my permissions and either Flow or the 10.5.7 update caused massive permissions damage it took a ver y long time to repair everything and it seemed like just about every file need to be repaired it took a couple of hours.
    But Photoshop works well again I think.
    I think I will try and turn Flow back on and see if that was the problem. I should mention that though flow is a third party application both Adobe and Apple and I believe Microsoft as wel have a stake of some kind it this application.
    I will check it out it does not seem to be the flow software unless it works on the something over time.
    but I will assume it was permissions problem ad my startup disk had the permissions set that everyone was read only. The permissions for the admin, Me and the account was fine but you need access for everyone as well.
    So I am going to say something on Apples thing is causing changes to the permissions at seemingly random times for a variety of reasons.
    So Apple was telling you the correct thing this is a permissions problem and obviously an issue they know about but $185 dollars to tell you this is a bit much.
    Dec 21, 2011 5:14 AM   in reply to DGJ193
    I'm installing CS3 so I can get some work done without fear of crashing
    Process:         Adobe Photoshop CS4 [11172]
    Path:            /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/MacOS/Adobe Photoshop CS4
    Identifier:      com.adobe.Photoshop
    Version:         11.0.1 (11.0.1x20090216 [20090216.r.522 2009/02/16:17:00:00 cutoff; r branch]) (11.0.1)
    Code Type:       X86 (Native)
    Parent Process:  launchd [149]
    Date/Time:       2009-05-21 11:43:44.430 -0400
    OS Version:      Mac OS X 10.5.7 (9J61)
    Report Version:  6
    Anonymous UUID:  9A059F57-309E-4E59-893D-54D405B7DCE2
    Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x00000000096890a8
    Crashed Thread:  0
    Thread 0 Crashed:
    0   com.apple.QD                      0x92cf2ea8 _GetDstBits32BGRA + 4
    1   com.apple.QD                      0x92cb64f0 DevFrameRect + 795
    2   com.apple.QD                      0x92c7b89d StdRectWithPort + 267
    3   com.apple.QD                      0x92c7b77b CallRect + 53
    4   com.apple.QD                      0x92cb61d3 FrameRect + 43
    5   com.adobe.Photoshop               0x000ce083 0x1000 + 839811
    6   com.adobe.Photoshop               0x00571249 0x1000 + 5702217
    7   com.adobe.Photoshop               0x00568ba0 0x1000 + 5667744
    8   com.adobe.Photoshop               0x00350997 0x1000 + 3471767
    9   com.adobe.Photoshop               0x0006aa63 0x1000 + 432739
    10  com.adobe.Photoshop               0x0006af52 0x1000 + 434002
    11  com.adobe.Photoshop               0x000629f0 0x1000 + 399856
    12  com.adobe.Photoshop               0x0006a7e5 0x1000 + 432101
    13  com.adobe.Photoshop               0x00063d65 0x1000 + 404837
    14  com.adobe.Photoshop               0x00063ed3 0x1000 + 405203
    15  com.adobe.Photoshop               0x0006222f 0x1000 + 397871
    16  com.adobe.Photoshop               0x002206aa 0x1000 + 2225834
    17  com.adobe.Photoshop               0x00220736 0x1000 + 2225974
    18  com.adobe.Photoshop               0x00003912 0x1000 + 10514
    19  com.adobe.Photoshop               0x00003839 0x1000 + 10297
    Thread 1:
    0   libSystem.B.dylib                 0x900649c6 kevent + 10
    1   libSystem.B.dylib                 0x90065155 _pthread_start + 321
    2   libSystem.B.dylib                 0x90065012 thread_start + 34
    Thread 2:
    0   libSystem.B.dylib                 0x900342ce semaphore_wait_signal_trap + 10
    1   libSystem.B.dylib                 0x900662c6 _pthread_cond_wait + 1267
    2   libSystem.B.dylib                 0x900ab539 pthread_cond_wait + 48
    3   com.adobe.amt.services            0x04b83552 AMTConditionLock::LockWhenCondition(int) + 46
    4   com.adobe.amt.services            0x04b7e995 _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 115
    5   com.adobe.amt.services            0x04b835b0 AMTThread::Worker(void*) + 20
    6   libSystem.B.dylib                 0x90065155 _pthread_start + 321
    7   libSystem.B.dylib                 0x90065012 thread_start + 34
    Thread 3:
    0   libSystem.B.dylib                 0x9003b46e __semwait_signal + 10
    1   libSystem.B.dylib                 0x90065dcd pthread_cond_wait$UNIX2003 + 73
    2   libGLProgrammability.dylib        0x91afeb32 glvmDoWork + 162
    3   libSystem.B.dylib                 0x90065155 _pthread_start + 321
    4   libSystem.B.dylib                 0x90065012 thread_start + 34
    Thread 4:
    0   libSystem.B.dylib                 0x900342da semaphore_timedwait_trap + 10
    1   ...ple.CoreServices.CarbonCore    0x96cf047f MPWaitOnSemaphore + 125
    2   MultiProcessor Support            0x1e332eff 0x1e303000 + 196351
    3   ...ple.CoreServices.CarbonCore    0x96cdd057 PrivateMPEntryPoint + 56
    4   libSystem.B.dylib                 0x90065155 _pthread_start + 321
    5   libSystem.B.dylib                 0x90065012 thread_start + 34
    Thread 5:
    Thread 6:
    Thread 7:
    Thread 8:
    Thread 9:
    Thread 10:
    Thread 11:
    Thread 12:
    Thread 13:
    Thread 14:
    Thread 15:
    Thread 16:
    Thread 17:
    Thread 18:
    Thread 19:
    2   ...ple.CoreServices.CarbonCore    0x96cdee83 TSWaitOnCondition + 126
    3   ...ple.CoreServices.CarbonCore    0x96cbdd6a TSWaitOnConditionTimedRelative + 202
    4   ...ple.CoreServices.CarbonCore    0x96cdeb00 MPWaitOnQueue + 208
    5   AdobeACE                          0x027c138d 0x2790000 + 201613
    6   AdobeACE                          0x027c0d85 0x2790000 + 200069
    7   ...ple.CoreServices.CarbonCore    0x96cdd057 PrivateMPEntryPoint + 56
    8   libSystem.B.dylib                 0x90065155 _pthread_start + 321
    9   libSystem.B.dylib                 0x90065012 thread_start + 34
    Thread 20:
    Thread 21:
    Thread 22:
    Thread 23:
    Thread 24:
    Thread 25:
    Thread 26:
    Thread 27:
    Thread 28:
    Thread 29:
    Thread 30:
    Thread 31:
    Thread 32:
    Thread 33:
    Thread 34:
    0   libSystem.B.dylib                 0x900343a6 mach_wait_until + 10
    1   libSystem.B.dylib                 0x900ab3ad nanosleep + 314
    2   com.adobe.PSAutomate              0x23d7f755 ScObjects::Thread::sleep(unsigned int) + 143
    3   com.adobe.PSAutomate              0x23d7f7b5 ScObjects::Thread::wait(unsigned int) + 23
    4   com.adobe.PSAutomate              0x23d70502 ScObjects::BridgeTalkThread::run() + 332
    5   com.adobe.PSAutomate              0x23d7fa77 ScObjects::Thread::go(void*) + 239
    Thread 35:
    0   libSystem.B.dylib                 0x90034286 mach_msg_trap + 10
    1   libSystem.B.dylib                 0x9003ba7c mach_msg + 72
    2   com.apple.CoreFoundation          0x9477704e CFRunLoopRunSpecific + 1790
    3   com.apple.CoreFoundation          0x94777cd4 CFRunLoopRun + 84
    4   com.apple.DesktopServices         0x90614e17 TSystemNotificationTask::SystemNotificationTaskProc(void*) + 123
    5   ...ple.CoreServices.CarbonCore    0x96cdd057 PrivateMPEntryPoint + 56
    Thread 36:
    4   com.apple.DesktopServices         0x90614f90 TFSEventsNotificationTask::FSEventsNotificationTaskProc(void*) + 216
    Thread 37:
    5   com.apple.DesktopServices         0x9061ff72 TNodeSyncTask::SyncTaskProc(void*) + 84
    6   ...ple.CoreServices.CarbonCore    0x96cdd057 PrivateMPEntryPoint + 56
    7   libSystem.B.dylib                 0x90065155 _pthread_start + 321
    8   libSystem.B.dylib                 0x90065012 thread_start + 34
    Thread 38:
    Thread 39:
    0   libSystem.B.dylib                 0x900836fa select$DARWIN_EXTSN + 10
    Thread 40:
    5   com.adobe.CameraRaw               0x275bd438 0x27402000 + 1815608
    6   com.adobe.CameraRaw               0x275bcd36 0x27402000 + 1813814
    Thread 41:
    Thread 42:
    Thread 43:
    Thread 44:
    Thread 45:
    Thread 46:
    Thread 47:
    Thread 48:
    Thread 49:
    Thread 50:
    Thread 51:
    Thread 52:
    Thread 53:
    Thread 54:
    Thread 55:
    3   com.adobe.CameraRaw               0x2744703a 0x27402000 + 282682
    4   com.adobe.CameraRaw               0x276f8374 EntryFM + 802340
    5   com.adobe.CameraRaw               0x274e70e6 0x27402000 + 938214
    Thread 56:
    4   com.adobe.CameraRaw               0x27787f88 EntryFM + 1391160
    Thread 57:
    0   libSystem.B.dylib                 0x900342e6 semaphore_timedwait_signal_trap + 10
    1   libSystem.B.dylib                 0x900662af _pthread_cond_wait + 1244
    2   libSystem.B.dylib                 0x90067b33 pthread_cond_timedwait_relative_np + 47
    3   com.apple.Foundation              0x93034dcc -[NSCondition waitUntilDate:] + 236
    4   com.apple.Foundation              0x93034be0 -[NSConditionLock lockWhenCondition:beforeDate:] + 144
    5   com.apple.Foundation              0x93034b45 -[NSConditionLock lockWhenCondition:] + 69
    6   com.apple.AppKit                  0x90f9fd20 -[NSUIHeartBeat _heartBeatThread:] + 753
    7   com.apple.Foundation              0x92feee0d -[NSThread main] + 45
    8   com.apple.Foundation              0x92fee9b4 __NSThread__main__ + 308
    9   libSystem.B.dylib                 0x90065155 _pthread_start + 321
    10  libSystem.B.dylib                 0x90065012 thread_start + 34
    Thread 58:
    3   data_flow                         0x03ba02b2 boost::detail::condition_impl::do_wait(_opaque_pthread_mutex_t*) + 24
    4   data_flow                         0x03b9365b void boost::condition::do_wait<boost::recursive_mutex>(boost::recursive_mu tex&) + 51
    5   data_flow                         0x03b96061 boost::threadpool::detail::pool_core<boost::threadpool::prio_task_fun c, boost::threadpool::prio_scheduler, boost::threadpool::static_size, boost::threadpool::resize_controller, boost::threadpool::wait_for_all_tasks>::execute_task() volatile + 135
    6   data_flow                         0x03b96bba boost::threadpool::detail::worker_thread<boost::threadpool::detail::p ool_core<boost::threadpool::prio_task_func, boost::threadpool::prio_scheduler, boost::threadpool::static_size, boost::threadpool::resize_controller, boost::threadpool::wait_for_all_tasks> >::run() + 232
    7   data_flow                         0x03b9390b boost::_bi::bind_t<void, boost::_mfi::mf0<void, boost::threadpool::detail::worker_thread<boost::threadpool::detail::p ool_core<boost::threadpool::prio_task_func, boost::threadpool::prio_scheduler, boost::threadpool::static_size, boost::threadpool::resize_controller, boost::threadpool::wait_for_all_tasks> > >, boost::_bi::list1<boost::_bi::value<boost::shared_ptr<boost::threadpo ol::detail::worker_thread<boost::threadpool::detail::pool_core<boost:: threadpool::prio_task_func, boost::threadpool::prio_scheduler, boost::threadpool::static_size, boost::threadpool::resize_controller, boost::threadpool::wait_for_all_tasks> > > > > >::operator()() + 43
    8   data_flow                         0x03b95fd1 boost::function0<void, std::allocator<boost::function_base> >::operator()() const + 79
    9   data_flow                         0x03ba1bc5 thread_proxy + 99
    10  libSystem.B.dylib                 0x90065155 _pthread_start + 321
    11  libSystem.B.dylib                 0x90065012 thread_start + 34
    Thread 59:
    Thread 60:
    Thread 61:
    Thread 62:
    Thread 63:
    Thread 64:
    Thread 65:
    Thread 66:
    Thread 67:
    Thread 68:
    Thread 69:
    Thread 70:
    Thread 71:
    Thread 72:
    Thread 73:
    Thread 74:
    3   ...ple.CoreServices.CarbonCore    0x96cbdd96 TSWaitOnConditionTimedRelative + 246
    4   ...ple.CoreServices.CarbonCore    0x96cbdb76 TSWaitOnSemaphoreCommon + 422
    5   ...ple.CoreServices.CarbonCore    0x96cbd877 AsyncFileThread(void*) + 73
    Thread 75:
    5   com.apple.DesktopServices         0x90621ebc TFolderSizeTask::FolderSizeTaskProc(void*) + 104
    Thread 76:
    Thread 0 crashed with X86 Thread State (32-bit):
      eax: 0x096890a8  ebx: 0x0000003f  ecx: 0xbfffed9e  edx: 0x096890a8
      edi: 0xbfffefe8  esi: 0xbfffed86  ebp: 0xbfffea48  esp: 0xbfffe9ec
       ss: 0x0000001f  efl: 0x00010292  eip: 0x92cf2ea8   cs: 0x00000017
       ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
      cr2: 0x096890a8
    Binary Images:
        0x1000 -  0x19aefdf +com.adobe.Photoshop 11.0.1 (11.0.1x20090216 [20090216.r.522 2009/02/16:17:00:00 cutoff; r branch]) (11.0.1) <5151e2340b0a4c1da3dea7ac2285e24e> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/MacOS/Adobe Photoshop CS4
    0x207f000 -  0x2084fff  org.twain.dsm 1.9.3 (1.9.3) /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
    0x208d000 -  0x246701f +com.adobe.linguistic.LinguisticManager 4.0.0 (7863) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/Adob eLinguistic
    0x251b000 -  0x2715fcf +AdobeOwl ??? (???) <4cca2c7b48964ddaa14b725fb0c202b5> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
    0x2790000 -  0x289dfff +AdobeACE ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
    0x28bb000 -  0x2c85fef +AdobeMPS ??? (???) <277e01a3cac34fa9a5914bc0a5bc125a> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
    0x2d14000 -  0x2d74fc7 +AdobeXMP ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
    0x2d83000 -  0x307efff +AdobeAGM ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
    0x313e000 -  0x33d1fe7 +AdobeCoolType ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeC oolType
    0x3455000 -  0x346efff +AdobeBIB ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
    0x3478000 -  0x3499ff7 +AdobeBIBUtils ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeB IBUtils
    0x34a6000 -  0x34c1ff9 +AdobePDFSettings ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/Ado bePDFSettings
    0x34db000 -  0x34ffff6 +AdobeAXE8SharedExpat ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A /AdobeAXE8SharedExpat
    0x3512000 -  0x359f2cb +libicucnv.dylib.36.0 ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libic ucnv.dylib.36.0
    0x35cc000 -  0x35e780f +libicudata.dylib.36.0 ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata .dylib.36.0
    0x35ea000 -  0x37a0ff4 +com.adobe.amtlib amtlib 2.0.1.10077 (2.0.1.10077) <cb2ec3bf67714dabbf296775fb6f9608> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
    0x37d7000 -  0x3867fc3 +WRServices ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/WRServices.framework/Versions/A/WRService s
    0x39e9000 -  0x39edffc +com.adobe.AdobeCrashReporter 2.5 (3.0.20080806) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/A dobeCrashReporter
    0x39f3000 -  0x3a0ffd7 +com.adobe.LogTransport 1.0 (1.0) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/LogTransport.framework/Versions/A/LogTran sport
    0x3a1a000 -  0x3aeffdd +FileInfo ??? (???) <f0932f89fc984ba9b4f2c58d0e71d3c1> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
    0x3b20000 -  0x3b77fff +aif_core ??? (???) <b4dcb439e1eeabe3bd122c42e980366b> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
    0x3b8f000 -  0x3bacffd +data_flow ??? (???) <8e452b6f803239d8eb5c49a4e31cb988> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
    0x3bd8000 -  0x3c51fff +image_flow ??? (???) <498a857df8c6f9e0c92fbc3ec8680ed0> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flo w
    0x3cb7000 -  0x3cc7fff +image_runtime ??? (???) <f379a95229831e44676dbbd8259f131a> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_ runtime
    0x3cdc000 -  0x3e9bffe +aif_ogl ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
    0x3f4c000 -  0x444afc3 +AdobeOwlCanvas ??? (???) <fcb2d1a31f6e41828e2cd0b23572d285> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeOwlCanvas.framework/Versions/A/Adobe OwlCanvas
    0x4593000 -  0x4665fe7 +AdobeAXEDOMCore ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/Adob eAXEDOMCore
    0x4719000 -  0x477bfe7 +com.adobe.PlugPlug 1.0.0.73 (1.0.0.73) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
    0x47dc000 -  0x4823fc7 +com.adobe.adobe_caps adobe_caps 2.0.99.0 (2.0.99.0) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_cap s
    0x4833000 -  0x4872fff  com.apple.vmutils 4.1 (104) <ce02dba5e2e99fa2eb41a81bc9680985> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutil s
    0x4b50000 -  0x4b51fe1  com.apple.textencoding.unicode 2.2 (2.2) <09ac11c81bf4e673a30cc364868fdc11> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
    0x4b63000 -  0x4c04fc3 +com.adobe.amt.services AMTServices 2.0.1.10077 (BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09) (2 . 0) <31e82904c3c2424ea1aea5efadbb19b8> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/amtservices.framework/Versions/a/amtservi ces
    0x4dad000 -  0x4daffff +com.unsanity.menuextraenabler 1.0.3 (1.0.3) /Library/InputManagers/Menu Extra Enabler/Menu Extra Enabler.bundle/Contents/MacOS/Menu Extra Enabler
    0x4de1000 -  0x4deffeb  libSimplifiedChineseConverter.dylib ??? (???) <c3123eb807ed45151fe0d12da8e51d04> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter. dylib
    0x4df4000 -  0x4df5ff3  ATSHI.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
    0x4f00000 -  0x4f12fff  libTraditionalChineseConverter.dylib ??? (???) <8a2b4c7bfd8d7941fcf64a2575095e36> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter .dylib
    0x4f80000 -  0x4f8dff7 +com.adobe.asneu.framework asneu version 1.6.2f01 (1.6.2) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/asneu.framework/Versions/a/asneu
    0x4f9b000 -  0x4f9bffd  libmx.A.dylib ??? (???) /usr/lib/libmx.A.dylib
    0x4f9f000 -  0x4fa1ffa +Adobe Unit Types a2.0.0 (2.0.0) /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types
    0x1914d000 - 0x19157ffe  com.apple.URLMount 3.1.1 (3.1.1) <0189760dca64cd07c190e1a7b10283e5> /System/Library/PrivateFrameworks/URLMount.framework/URLMount
    0x19896000 - 0x19899fff +com.stclairsoft.DefaultFolderX.osax Default Folder X Addition version 1.0 (4.2d11) <20ae7639d6757ddcf4bc4056fe20f03c> /Users/beige/Library/ScriptingAdditions/Default Folder X Addition.osax/Contents/MacOS/Default Folder X Addition
    0x1c1d2000 - 0x1c1f3feb +com.stclairsoft.DefaultFolderX.CarbonPatcher kBundleVersion (kBundleVersion) <8b93f82fae47535ac5ac173ee8e6040b> /Users/beige/Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Carbon Patcher.bundle/Contents/MacOS/Carbon Patcher
    0x1c200000 - 0x1c21eff7 +Cocoa Patcher ??? (???) <f334cea477fc7dfa50ece44251cb5a78> /Users/beige/Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Cocoa Patcher.bundle/Contents/MacOS/Cocoa Patcher
    0x1c2b5000 - 0x1c2baff3  libCGXCoreImage.A.dylib ??? (???) <3a78abc535c80f9819931b670da804a2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage. A.dylib
    0x1c5d4000 - 0x1c7ccfff  com.apple.RawCamera.bundle 2.0.14 (436) <a8dd51882088fae463f33bc0674583e8> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamer a
    0x1c935000 - 0x1c944fe3 +FontAgent Pro ??? (???) <cd990c15489c946a041b570f3f9879ed> /Applications/Adobe Photoshop CS4/Plug-ins/FontAgent Pro.plugin/Contents/MacOS/FontAgent Pro
    0x1ca48000 - 0x1cbcdfe3  GLEngine ??? (???) <3bd4729832411ff31de5bb9d97e3718d> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle /GLEngine
    0x1cbfb000 - 0x1ced9ff1  com.apple.ATIRadeonX2000GLDriver 1.5.44 (5.4.4) <aeb5e93202779fb8e0f5da88291ce9f6> /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/Mac OS/ATIRadeonX2000GLDriver
    0x1cf3d000 - 0x1cf59ff7  GLRendererFloat ??? (???) <927b7d5ce6a7c21fdc761f6f29cdf4ee> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRe ndererFloat.bundle/GLRendererFloat
    0x1e0a2000 - 0x1e0adfff +Enable Async IO ??? (???) <fd91e79fc4aa4ebcaf6d3e154f14878f> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/Enable Async IO.plugin/Contents/MacOS/Enable Async IO
    0x1e0b2000 - 0x1e0bdfff +UseOldShortcuts ??? (???) <a9de9f74fcf34c1cacf5cc296335f84d> /Applications/Adobe Photoshop CS4/Plug-ins/UseOldShortcuts.plugin/Contents/MacOS/UseOldShortcuts
    0x1e0c2000 - 0x1e0d002f +FastCore ??? (???) <f12878b7bee940ca9f0565cd0f5688e2> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/FastCore.plugin/Contents/MacOS/FastCore
    0x1e0d6000 - 0x1e0e1ffb +PPCCore ??? (???) <ed521eb7681d45aa9ae36bf4663e4bd3> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/PPCCore.plugin/Contents/MacOS/PPCCore
    0x1e0e7000 - 0x1e0f2ffe +AltiVecCore ??? (???) <a967ae2af2ae4e12a7b668b981cbd906> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/AltiVecCore.plugin/Contents/MacOS/AltiVecCore
    0x1e200000 - 0x1e265fe3 +MMXCore ??? (???) <e206c8dcaea849df8fbc8b447e3a59a1> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/MMXCore.plugin/Contents/MacOS/MMXCore
    0x1e303000 - 0x1e34aff7 +MultiProcessor Support ??? (???) <001a163b53144613a23af35b63065fd0> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
    0x1e366000 - 0x1e4b8fc7 +com.adobe.coretech.adm 3.10x16 (3.1) /Applications/Adobe Photoshop CS4/Plug-ins/ADM/AdobeADM.bundle/Contents/MacOS/AdobeADM
    0x1f30e000 - 0x1f31bfff +com.alienskin.autolayer2 2.0.1 (2.0.1) <420807129f42aa6e0264f66de8c18c6b> /Applications/Adobe Photoshop CS4/Plug-ins/Alien Skin/Autolayer2.plugin/Contents/MacOS/Autolayer2
    0x20432000 - 0x20432fff +com.insidersoftware.fontagentpro.pluginsupportframework FontAgent Pro 4.0.3 build 41A6 (4.0.3) <1a613241bd6d4f4a8d3cad85995d88cd> /Library/Frameworks/FAProPluginSupport.framework/FAProPluginSupport
    0x23c4b000 - 0x23ea7fdf +com.adobe.PSAutomate 11.0 (11.0) /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/ScriptingSupport.plugin/Contents/MacOS/Script ingSupport
    0x2413b000 - 0x24209fff +AdobeExtendScript ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/Ad obeExtendScript
    0x24280000 - 0x24321fd7 +AdobeScCore ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScC ore
    0x243be000 - 0x243e1ff7 +CSI-Launcher.dylib ??? (???) /Library/Application Support/Adobe/CS4ServiceManager/CSI-Launcher.dylib
    0x24b92000 - 0x24bc3fe3 +com.adobe.amt.registration AMTRegistration 2.0.1.10077 (BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09) (2 . 0) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/registration.framework/Versions/a/registr ation
    0x24de2000 - 0x25264fe3 +AdobeLM_libFNP.dylib ??? (???) <02e9ac769cc64974af0548e737c2cc20> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/amtlib.framework/Versions/a/AdobeLM_libFN P.dylib
    0x2538e000 - 0x253eaff2 +AdobeUpdater ??? (???) <064cfaa41caf46e3bebf04948641c927> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeUpdater.framework/Versions/a/AdobeUp dater
    0x27402000 - 0x27b09ff9 +com.adobe.CameraRaw 5.3 (5.3.0f21) <077769d6e7737a315c4fb417c2ae4dcd> /Library/Application Support/Adobe/Plug-Ins/CS4/File Formats/Camera Raw.plugin/Contents/MacOS/Camera Raw
    0x2f40b000 - 0x2f479fd7 + ??? (???)
    0x35ced000 - 0x35df4fcf +com.adobe.versioncue ??? (4.0.1.095) /Library/Application Support/Adobe/Adobe Version Cue CS4/Client/4.0.1/VersionCue.framework/VersionCue
    0x40000000 - 0x400ae030 +AdobeJP2K ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
    0x8fe00000 - 0x8fe2db43  dyld 97.1 (???) <9736a715ebabb914fef61680520dc1e0> /usr/lib/dyld
    0x90003000 - 0x90019fff  com.apple.DictionaryServices 1.0.0 (1.0.0) <7d20b8d1fb238c3e71d0fa6fda18c4f7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x9001a000 - 0x90026ff9  com.apple.helpdata 1.0.1 (14.2) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpD ata
    0x90033000 - 0x9019aff3  libSystem.B.dylib ??? (???) <b47c8e6e45aef620730710a732bf1930> /usr/lib/libSystem.B.dylib
    0x9019b000 - 0x9024bfff  edu.mit.Kerberos 6.0.13 (6.0.13) <804bd1b3f08fb57396781f012006367c> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x9024c000 - 0x9028bfff  com.apple.CoreMediaIOServicesPrivate 15.0 (15.0) /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framewor k/Versions/A/CoreMediaIOServicesPrivate
    0x9028c000 - 0x90290fff  libGIF.dylib ??? (???) <3578a8fe9fb40ab4abf8f3c8356320c2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x90291000 - 0x90335fec  com.apple.CFNetwork 438.10 (438.12) <fde64bbb20532794396fb21911ccaa98> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CFNetwork.framework/Versions/A/CFNetwork
    0x90336000 - 0x90367ffb  com.apple.quartzfilters 1.5.0 (1.5.0) <92b4f39479fdcabae0d8f53febd22fad> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzFilters.framework/Versions/A/QuartzFilters
    0x90368000 - 0x90368ffa  com.apple.CoreServices 32 (32) <373d6a888f9204641f313bc6070ae065> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
    0x90369000 - 0x90391ff7  com.apple.shortcut 1.0.1 (1.0) <131202e7766e327d02d55c0f5fc44ad7> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Short cut
    0x90392000 - 0x90392ffd  com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
    0x90393000 - 0x903cafff  com.apple.SystemConfiguration 1.9.2 (1.9.2) <eab546255ac099b9616df999c9359d0e> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
    0x903cb000 - 0x903cbff8  com.apple.Cocoa 6.5 (???) <a1bc9247cf65c20f1a44d0973cbe649c> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x903cc000 - 0x903f5fff  com.apple.CoreMediaPrivate 15.0 (15.0) /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions /A/CoreMediaPrivate
    0x903f6000 - 0x905c7ffb  com.apple.security 5.0.5 (36371) <c13e0bb1acfdcf94be4d3ee118ef190e> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x905c8000 - 0x90602fe7  com.apple.coreui 1.2 (62) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x90603000 - 0x90612ffe  com.apple.DSObjCWrappers.Framework 1.3 (1.3) <182986b74247b459b2a67a47071bdc6b> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A /DSObjCWrappers
    0x90613000 - 0x9069dfe3  com.apple.DesktopServices 1.4.8 (1.4.8) <3065de6531ce839c7cb5b6dd70e03f4f> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
    0x906d9000 - 0x907c1ff3  com.apple.CoreData 100.2 (186.1) <8fb61e1714a4b8d587ce97605ad32547> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x90846000 - 0x9086ffff  libcups.2.dylib ??? (???) <1b0435164b9dc6c773d0b1f24701e554> /usr/lib/libcups.2.dylib
    0x90ec2000 - 0x90ef1fe3  com.apple.AE 402.3 (402.3) <b13bfda0ad9314922ee37c0d018d7de9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
    0x90ef2000 - 0x90ef8fff  com.apple.print.framework.Print 218.0.3 (220.2) <5b7f4ef7c2df36aff9605377775781e4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
    0x90ef9000 - 0x916f7fef  com.apple.AppKit 6.5.7 (949.46) <a80f8cb62f6bdcb3bed3c8675d55881d> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x916f8000 - 0x9183eff7  com.apple.ImageIO.framework 2.0.4 (2.0.4) <bf2299657a0600d4d4bc1f0b45ce2252> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/ImageIO
    0x9183f000 - 0x9190afff  com.apple.ColorSync 4.5.1 (4.5.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
    0x9190b000 - 0x9194cfe7  libRIP.A.dylib ??? (???) <69bd09fcd8d8b235cee7a405290d6818> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x9195d000 - 0x91a3eff7  libxml2.2.dylib ??? (???) <068cab13eb4608a7c6a5fad807ee0e33> /usr/lib/libxml2.2.dylib
    0x91a3f000 - 0x91a49feb  com.apple.audio.SoundManager 3.9.2 (3.9.2) <df077a8048afc3075c6f2d9e7780e78e> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Car bonSound.framework/Versions/A/CarbonSound
    0x91a4a000 - 0x91ad6ff7  com.apple.framework.IOKit 1.5.2 (???) <97b9f9d584f48891377f0481b9104434> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x91ad7000 - 0x91fa8fbe  libGLProgrammability.dylib ??? (???) <7f18294a7bd0b6afe4319f29187fc70d> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LProgrammability.dylib
    0x91fa9000 - 0x920e1fe7  com.apple.imageKit 1.0.2 (1.0) <c5d490cabf34706b82e70d6b900f3df6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Ima geKit.framework/Versions/A/ImageKit
    0x920e2000 - 0x920e4ff5  libRadiance.dylib ??? (???) <232d7e7bbe8c65c16098bc1a52b30b9b> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x920e5000 - 0x92109fff  libxslt.1.dylib ??? (???) <f0872c9ba3c17861fba8c45a3647cee1> /usr/lib/libxslt.1.dylib
    0x9226e000 - 0x9226efff  com.apple.Carbon 136 (136) <8ae1cd25fd33db22d69ecbd5f5103227> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x9226f000 - 0x9242bff3  com.apple.QuartzComposer 2.1 (106.13) <645bdfea218d17e8a51cc7fee78d9cd3> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzComposer.framework/Versions/A/QuartzComposer
    0x9242c000 - 0x9242efff  com.apple.securityhi 3.0 (30817) <547bdd9ce4e7276d9bdc137d4caf9c3f> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
    0x9242f000 - 0x92754fe2  com.apple.QuickTime 7.6.0 (1291) <07b7f2aca9aa205e9bd202f0cfa28c19> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x92755000 - 0x927c7fff  com.apple.PDFKit 2.1.2 (2.1.2) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDF Kit.framework/Versions/A/PDFKit
    0x927d2000 - 0x9281bfef  com.apple.Metadata 10.5.2 (398.25) <281076cdaea1362e02b6892b93d16bbb> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
    0x9281c000 - 0x92837ffb  libPng.dylib ??? (???) <ae92a25664039afc82409484407d5e83> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x9290f000 - 0x929c1ffb  libcrypto.0.9.7.dylib ??? (???) <9d714c92872a93dd127ea8556b2c8945> /usr/lib/libcrypto.0.9.7.dylib
    0x929c2000 - 0x92a13ff7  com.apple.HIServices 1.7.0 (???) <a2352abae2b8b44a95a8a76c8e111d36> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
    0x92a26000 - 0x92a2dfe9  libgcc_s.1.dylib ??? (???) <e280ddf3f5fb3049e674edcb109f389a> /usr/lib/libgcc_s.1.dylib
    0x92b10000 - 0x92b10ff8  com.apple.ApplicationServices 34 (34) <ee7bdf593da050bb30c7a1fc446eb8a6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
    0x92b48000 - 0x92b50fff  com.apple.DiskArbitration 2.2.1 (2.2.1) <2664eeb3a4d0c95a21c089892a0ae8d0> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
    0x92b51000 - 0x92c08ff3  com.apple.QTKit 7.6 (1291) /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x92c09000 - 0x92c10ffe  libbsm.dylib ??? (???) <fa7ae5f1a621d9b69e7e18747c9405fb> /usr/lib/libbsm.dylib
    0x92c11000 - 0x92c50fef  libTIFF.dylib ??? (???) <745ad643ca5bde81a88c0cdc8c942380> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x92c51000 - 0x92c55fff  libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
    0x92c56000 - 0x92c6eff7  com.apple.CoreVideo 1.6.0 (20.0) <c0f8e729d9876e91f79f9c3b6b13beb0> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x92c6f000 - 0x92d16feb  com.apple.QD 3.11.56 (???) <a94d0f5438b730e88e5efdb233295c52> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
    0x92e97000 - 0x92ef3ff7  com.apple.htmlrendering 68 (1.1.3) <1c5c0c417891b920dfe139385fc6c155> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTM LRendering.framework/Versions/A/HTMLRendering
    0x92ef4000 - 0x92f09ffb  com.apple.ImageCapture 5.0.2 (5.0.2) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
    0x92f0a000 - 0x92f63ff7  libGLU.dylib ??? (???) <a3b9be30100a25a6cd3ad109892f52b7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
    0x92f64000 - 0x92fe3ff5  com.apple.SearchKit 1.2.1 (1.2.1) <bf8c50d86ebd0c199752065658b9e2c3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
    0x92fe4000 - 0x93260fe7  com.apple.Foundation 6.5.8 (677.24) <aa84b0383891378c348ffa4a94853082> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x93261000 - 0x932a3fef  com.apple.NavigationServices 3.5.2 (163) <72cdc9d21f6690837870923e7b8ca358> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Nav igationServices.framework/Versions/A/NavigationServices
    0x93308000 - 0x93333fe7  libauto.dylib ??? (???) <2e44c523b851e8e25f05d13a48070a58> /usr/lib/libauto.dylib
    0x93334000 - 0x93402ff3  com.apple.JavaScriptCore 5525.26 (5525.26.2) <a8929f0de97428798f858023b3ce2f60> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaSc riptCore
    0x93403000 - 0x93480fef  libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
    0x93481000 - 0x9349fff3  com.apple.DirectoryService.Framework 3.5.6 (3.5.6) <daa1307737197c7757f44f16370249dc> /System/Library/Frameworks/DirectoryService.framework/Versions/A/Dire ctoryService
    0x934a0000 - 0x9351dfeb  com.apple.audio.CoreAudio 3.1.2 (3.1.2) <5a4e6329f8dbca5dcd70924525afd24a> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x9351e000 - 0x93536fff  com.apple.openscripting 1.2.8 (???) <a6b446eb8ec7844096df5fb9002f5c7b> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
    0x93537000 - 0x9383ffff  com.apple.HIToolbox 1.5.5 (???) <b17766e3d8800a73f534c41f624f5ac4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
    0x93840000 - 0x93907ff2  com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
    0x93997000 - 0x9399afff  com.apple.help 1.1 (36) <1a25a8fbb49a830efb31d5c0a52939cd> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
    0x939ce000 - 0x939d3fff  com.apple.CommonPanels 1.2.4 (85) <c135f02edd6b2e2864311e0b9d08a98d> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
    0x939d4000 - 0x939d4ffd  com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x939d5000 - 0x94075fe3  com.apple.CoreGraphics 1.409.3 (???) <25dceb14af3455b768f56e8765ecf3ca> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x94076000 - 0x94086ffc  com.apple.LangAnalysis 1.6.4 (1.6.4) <7ae8dfd6cff0e34cf7c23ffc6cc291cb> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x94087000 - 0x94090fff  com.apple.speech.recognition.framework 3.7.24 (3.7.24) <da2d8411921a3fd8bc898dc753b7f3ee> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
    0x94091000 - 0x9409fffd  libz.1.dylib ??? (???) <a98b3b221a72b54faf73ded3dd7000e5> /usr/lib/libz.1.dylib
    0x940a0000 - 0x940a1ffc  libffi.dylib ??? (???) <eaf10b99a3fbc4920b175809407466c0> /usr/lib/libffi.dylib
    0x940a2000 - 0x94230fe7  com.apple.CoreAUC 3.07.2 (3.07.2) <08a5e0090d94e132ec9fa9ef4034941d> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAU C
    0x94231000 - 0x9423efe7  com.apple.opengl 1.5.10 (1.5.10) <5a2813f80c9441170cc1ab8a3dac5038> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x9423f000 - 0x9425effa  libJPEG.dylib ??? (???) <219f13f403b1e09a67f926c9269582e2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x942cd000 - 0x942cdffc  com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x942ce000 - 0x9468cfea  libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
    0x94692000 - 0x94702ff7  com.apple.iLifeMediaBrowser 2.0.2 (321) <096200840dfe3556d984bed9e9e1e4bc> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Version s/A/iLifeMediaBrowser
    0x94703000 - 0x94703ffb  com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/ InstallServer
    0x94704000 - 0x94837fef  com.apple.CoreFoundation 6.5.6 (476.18) <2d52bab73660117571bd6486dc318f8e> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
    0x9484c000 - 0x948a6ff7  com.apple.CoreText 2.0.4 (???) <f0b6c1d4f40bd21505097f0255abfead> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreText.framework/Versions/A/CoreText
    0x9494b000 - 0x949d7ff7  com.apple.LaunchServices 290.3 (290.6) <bdba267184df88bd5b8e2116ea903872> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
    0x94ba4000 - 0x94cddff7  libicucore.A.dylib ??? (???) <cac059ebdac7d9a63ee0f7a648c9f6cf> /usr/lib/libicucore.A.dylib
    0x94cde000 - 0x94cdeffe  com.apple.quartzframework 1.5 (1.5) <6865aa0aeaa584b5a54d43f2f21d6c08> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x94cdf000 - 0x94cdfffd  com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x94ce0000 - 0x94d9afe3  com.apple.CoreServices.OSServices 227 (227) <30cebcb68b1b571df7d77474e0c31556> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
    0x94da8000 - 0x94efaff3  com.apple.audio.toolbox.AudioToolbox 1.5.2 (1.5.2) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
    0x94efb000 - 0x94f8efff  com.apple.ink.framework 101.3 (86) <d4c85b5cafa8027fff042b84a8be71dc> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
    0x951f8000 - 0x95236fff  libGLImage.dylib ??? (???) <a6425aeb77f4da13212ac75df57b056d> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
    0x95237000 - 0x9532bff4  libiconv.2.dylib ??? (???) <96ff4c6f84c4a1623cb78287371cdd3f> /usr/lib/libiconv.2.dylib
    0x9532c000 - 0x9533cfff  com.apple.speech.synthesis.framework 3.7.1 (3.7.1) <273d96ff861dc68be659c07ef56f599a> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x9533d000 - 0x9538cfff  com.apple.QuickLookUIFramework 1.3.1 (170.9) /System/Library/PrivateFrameworks/QuickLookUI.framework/Versions/A/Qu ickLookUI
    0x953bd000 - 0x96398ff6  com.apple.QuickTimeComponents.component 7.6 (1291) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacO S/QuickTimeComponents
    0x96399000 - 0x967a9fef  libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
    0x967aa000 - 0x96831ff7  libsqlite3.0.dylib ??? (???) <3334ea5af7a911637413334154bb4100> /usr/lib/libsqlite3.0.dylib
    0x96832000 - 0x96839fff  com.apple.agl 3.0.9 (AGL-3.0.9) <d64d715dab8565014f5e2f239fd2410c> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x9683a000 - 0x968b4ff8  com.apple.print.framework.PrintCore 5.5.4 (245.6) <03d0585059c20cb0bde5e000438c49e1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
    0x968b5000 - 0x968c0fe7  libCSync.A.dylib ??? (???) <9e3544fe087bb4dc760b7afe0850dd6c> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x968f6000 - 0x96c93fef  com.apple.QuartzCore 1.5.8 (1.5.8) <a28fa54346a9f9d5b3bef076a1ee0fcf> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x96c94000 - 0x96f6eff3  com.apple.CoreServices.CarbonCore 786.11 (786.13) <9e2d85d52e5e2951aa4dd53c48ccc52f> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
    0x96f6f000 - 0x9704ffff  libobjc.A.dylib ??? (???) <d1469bf9fe852864d4fff185c72768e8> /usr/lib/libobjc.A.dylib
    0x97050000 - 0x970adffb  libstdc++.6.dylib ??? (???) <7d389389a99ce696726cf4c8980cc505> /usr/lib/libstdc++.6.dylib
    0x970b1000 - 0x970b8ff7  libCGATS.A.dylib ??? (???) <211348279493364e9920adc86484cedd> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
    0x97153000 - 0x97153ffe  com.apple.MonitorPanelFramework 1.2.0 (1.2.0) <1f4c10fcc17187a6f106e0a0be8236b0> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/M onitorPanel
    0x97154000 - 0x971e7ff3  com.apple.ApplicationServices.ATS 3.7 (???) <a535fc4982d3acff6530ec25c402e679> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
    0x971ed000 - 0x971f9ffe  libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
    0x9723f000 - 0x97244fff  com.apple.DisplayServicesFW 2.0.2 (2.0.2) <df0c1a58d119d2dd90182cd2d88ccf58> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/ A/DisplayServices
    0x97245000 - 0x97272feb  libvDSP.dylib ??? (???) <4daafed78a471133ec30b3ae634b6d3e> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
    0x97273000 - 0x97290ff7  com.apple.QuickLookFramework 1.3.1 (170.9) /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x97299000 - 0x972b7fff  libresolv.9.dylib ??? (???) <39f6d8651f3dca7a1534fa04322e6763> /usr/lib/libresolv.9.dylib
    0xb0000000 - 0xb0006ff8  com.apple.carbonframeworktemplate 1.3 (1.3.12) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
    0xba300000 - 0xba301fff  libCyrillicConverter.dylib ??? (???) <4fec2bf92f6c26af7c58119df77674bf> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
    0xba500000 - 0xba501ffb  libGreekConverter.dylib ??? (???) <b63c7bb67f5eb753eb48fda5a428f638> /System/Library/CoreServices/Encodings/libGreekConverter.dylib
    0xba900000 - 0xba916fff  libJapaneseConverter.dylib ??? (???) <1ed47ca6a3bfe0c9bf656dfe3d5cc7c0> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
    0xbab00000 - 0xbab21fe2  libKoreanConverter.dylib ??? (???) <2c1a357c75d048e1eedb6c40a3f5b0e1> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
    0xbb500000 - 0xbb500fe3  libThaiConverter.dylib ??? (???) <181e3ebe4ca849331c03a19ac575e3f0> /System/Library/CoreServices/Encodings/libThaiConverter.dylib
    0xfffe8000 - 0xfffebfff  libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
    0xffff0000 - 0xffff1780  libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
    Edited by forum host : offensive language
    May 21, 2009 12:15 PM   in reply to cgbeige
    "GetDstBits32BGRA"
    That's part of the QuickDraw crashers that Apple introduced in MacOS 10.5.  Also reported, also waiting on Apple to fix them.
    May 21, 2009 12:40 PM   in reply to DGJ193
    so Photoshop is the only program to use these APIs? Would it have anything to do with the new cross-platform UI in CS4?
    May 21, 2009 1:38 PM   in reply to cgbeige
    No, Photoshop is not the only program using those APIs, nor the only program seeing crashes due to them.
    We're not sure what is causing them - we can't know until Apple finds the cause of the crash in their code.
    May 21, 2009 4:03 PM   in reply to Wade_Zimmerman
    DGJ: I mentioned in your other thread that  your cleaning hint had nothing to do with your problems, and now you know.
    The first thing you do when you have problems that hardly anyone else has, is disk repair, Then permissions. Then disconnect everything USB. Then new user. Then ask here. Then call Apple.
    Jun 5, 2009 10:08 AM   in reply to DGJ193
    FYI: The crash that involves _SetDstBits32BGRA is an occasional crash in the OSX text edit field that can happen when you drag something (such as a panel) over the text edit field.
    We have been able to provide a reproducible test case to Apple.
    If you plan on contacting Apple regarding this issue, then you could refer to Apple bug (radar): 6913072 Crash in Carbon text edit fields when dragging
    Jun 5, 2009 2:07 PM   in reply to Jesper Storm Bache
    Ah, good to know.
    I didn't realize that you'd narrowed it down that far.
    (Jesper is an Adobe engineer)
    Jun 8, 2009 6:32 AM   in reply to DGJ193
    Jesper-
    Thanks for the info.
    What percentage of the reported PS crashes are due to "_SetDstBits32BGRA"?
    A common problem that I have experienced and others too, is that when trying to force Quit PS after the app freezes, PS won't force quit. What is causing PS to not force quit? Would all of the crashes that result in the same force quit problem have a similar origin, or is the force quit problem independent of the reason for the initial freezing of the app?
    thanks
    j
    Jun 8, 2009 11:53 AM   in reply to DGJ193
    There seems to be 2 common issues with the PS crashes/quits etc.
    One is the above mentioned "force quit problem", and the other is when quitting PS ( and other apps in the CS4 suite) that the Adobe crash reporter sometimes appears as though the app has crashed upon quitting. I don't remember either of these problems with CS3. Are these also attributable to the MacOS?
    Jun 8, 2009 12:07 PM   in reply to - JM -
    "One is the above mentioned "force quit problem", and the other is when quitting PS ( and other apps in the CS4 suite) that the Adobe crash reporter sometimes appears as though the app has crashed upon quitting"
    Part MacOS, part our crash reporter trying to gather information when it shouldn't (which relates back to the MacOS issue, but we can work around it).  The delay in quitting is the Apple crash reporter code gathering information for us.
    Jun 8, 2009 12:18 PM   in reply to Chris Cox
    interesting!
    So both issues are related.
    Can the crash reporter (Apple and Adobe) be turned off so that it's not monitoring activity?
    Jun 8, 2009 12:38 PM   in reply to - JM -
    it appears that there was the ability to remove crash reporting on the Apple side but that has been removed with Leopard. This was reported on another tech site
    "in earlier versions of OS X, one could edit /etc/hostconfig and change the line
    "CRASHREPORTER=-YES-" to "CRASHREPORTER=-NO-"
    not only is this line no longer in hostconfig, but the top of this file says
    1. This file is going away "
    But Tinkertool still reports that it may be able to disable crash reporting
    http://www.bresink.de/osx/0TinkerTool/details.html
    scroll down to  "Control how Mac OS X handles application crashes"
    But this may only deal with the display of the information not the gathering which seems to be the problem.
    Jun 8, 2009 12:49 PM   in reply to - JM -
    I see that each of the CS4 apps has it's own adobecrashreporter, can this be safely removed?
    Jun 8, 2009 1:50 PM   in reply to - JM -
    "I see that each of the CS4 apps has it's own adobecrashreporter, can this be safely removed?"
    Nope.
    We're trying to make it as invisible and trouble free as possible, but sometimes OS changes cause small hiccups.
    Jun 8, 2009 6:15 PM   in reply to Chris Cox
    " but we can work around it"
    A work-around may be a good idea. Killing the crash reporting might allow everyone to get caught up with the existing problems, wait for Apple to fix their problems, and at the same time relieve the end users from problems related to crash reports that should be helping not hindering progress.
    thx.
    Jun 9, 2009 7:00 AM   in reply to - JM -
    I dug a little deeper and unfortunately Tinkertool won't stop the crash reporter either, I received a speedy response from Marcel of TT:
    Am 09.06.2009 um 14:12 schrieb CGI-Mailer:
    By choosing "When applications crash: > Don't display anything" does this stop the crash reporter from gathering information
    No, the crash reporter will still gather information but it won't display
    a dialog. Apple's exact definition of this setting is "never display the
    Unexpectantly Quit dialog. This allows for unattended operation while the
    user is logged in".
    and also from passing this information on to other crash reporters such as those from Adobe?
    I don't think that third-party crash reporters will respect or somehow reuse
    Apple's preference setting. For a definitive response you would have to contact
    the vendors of the individual reporter programs.
    Nov 10, 2009 8:14 AM   in reply to - JM -
    I don't know the percentage, but I am told that it is rather large. FYI: Apple has fixed the crash related to _SetDstBits32BGRA in 10.6.2
    Feb 1, 2011 10:55 AM   in reply to DGJ193
    I'm not helping; just ranting.
    I find CS4 in general to be a buggy piece of garbage. I spend the bulk of time in ID and PS with constant issues from both. I've long since given up looking for solutions but have found some relief that I'm not alone. PS crashes on every single quit; ID constantly loses all my pallets and also likes to crash when quitting (although no where near as often as PS).
    I used to send friendly reports to Adobe about it but in the last 4 months or so I've taken to harshly rebuking them for this abomination; so much so that I no longer get a report dialog when PS crashes. Has Adobe seen the light and disabled my reporting mechanism?
    We purchased a multi site version of CS4 with varying degrees of success amongst us, even though we all installed from the same disks. Go figure!
    While I don't expect perfection from any new upgrade, but do expect possible anomalies; I've never seen such a horrible piece of software outside of MS Office. CS5 came out fairly soon after CS4 so I took that as a sign that CS4 had some serious issues. We don't have CS5 yet but I'm hopeful that it's just one big patch.
    Feb 1, 2011 11:01 AM   in reply to stewart tower
    Which third party plugins did you install just before it started doing that?
    Though it's also possible you have a Brother printer/scanner (but a lot less common).
    No, you had to disable the crash reporter.  Adobe can't do that.  If you go into your preferences folder and delete the adobe crash reporter plist, that'll reset it.
    And you do know that while we fix bugs and report problems to third party manufacturers, there's no way we could respond to each and every crash report -- right?
    Historically, each version ships 18 to 24 months after the last.  CS5 was no exception.
    Feb 1, 2011 11:12 AM   in reply to stewart tower
    in many ways that's how I looked at CS5. CS4 was crashing consistently, and from what I was told the crash reporter would kick in before or after ( I forget which) the problem could be identified.
    I think my problems had to do with font activation with FAP and how it interacted with the CS4 suite because quite often when one app would crash on quit they all did. I don't know if the auto-activation problems were on the FAP side or CS4.... but in the end CS5, a high fiber diet and cleansing of my fonts has resulted in much less ( I might even say.... no crashing) at this point. So... even though I was one of unfortunate people that needed to reinstall CS5 it was worth upgrading just to get rid of the crash on quit issues.
    regards
    j
    Feb 1, 2011 11:33 AM   in reply to - JM -
    FYI: I have encountered situations where multiple applications crash on launch. Crashing applications can include Apple applications such as Mail. When I have encountered this, the OSX window server is typically "broken" and you need to restart your system.
    When this is the case, your window server log (Console > Files > /private/var/log > windowserver.log) > may contain error messages such as:
    CGSResolveShmemReference : offset exceeds bounds.
    This is something that we have worked with Apple on, and is something that may be related to creating either many windows at the same time, or many windows over time.
    In Cocoa we are able to reduce the number of windows that we use in Photoshop, and as such you should see this problem much less with CS5 than with previous versions.
    Feb 1, 2011 11:38 AM   in reply to Jesper Storm Bache
    I think that most of the CS4 issues mentioned here were crash on quit, is the same OS bug responsible for that?
    Feb 1, 2011 11:42 AM   in reply to - JM -
    No
    Feb 1, 2011 11:46 AM   in reply to Chris Cox
    I've installed no third party plugins; CS4 has been acting this way right off the disk.
    I have not consciously disabled my reporting mechanism so let's just add that to the bug list. But thank you for pointing out the plist tip.
    While admittedly frustrated, I'm still sane enough to know that Adobe does not reply to every crash report. My guess is that crash reports are scanned by software and not people. If Adobe does employ people to process crash reports they must have some serious overtime issues going on right now.
    I've been using Adobe software from the time it came on floppy disks with printed manuals and have been through enough hardware and software upgrades in 16 years to justifiably state that CS4 has been my worst software experience yet. The only one that's topped is so far has been Publisher. I'm actually worried that Adobe might have gotten a bit too comfortable like Quark did (you all remember Quark, right?).
    Feb 1, 2011 6:00 PM   in reply to - JM -
    Yes, FAP had many bugs to fix.
    Feb 1, 2011 6:04 PM   in reply to stewart tower
    Well, so far our crashes on quit have been due to bugs in third party plugins, or bugs in printer and scanner drivers.
    I read them, but again, we can't reply to all of them.
    And really, Photoshop doesn't crash that often except for third party issues (see above).
    If we find a bug in our code, we try to fix it as soon as we can...
    If CS4 is crashing often, then there is a problem with something else on the system.
    If you give me the email address you use when sending in the reports, I can do a search for your reports and find the exact cause.
    (probably best to send me a private message, unless you like your email address going to SPAM bots)
    Feb 1, 2011 6:06 PM   in reply to DGJ193
    Also, once in a while when i restart Photoshop, my usual actions are no longer there and my pallettes are changed around.
    That would mean that the preferences got reset for some reason (keys held down at launch, or prefs were corrupt on disk).
    Yeah, a bad external disk can cause some odd problems...
Actions
