Is there a keyboard shortcut to only show keyframes?
I usually use "UU", but that shows keyframes, plus expressions.
Hello, Navarro.
You mean "U", right? "UU" means show only modified properties, even if they're not animated ![]()
But you are right, "U" reveals animated properties, regardless of the animation method.
I don't think there is a shortcut to reveal only keyframes, if expressions also exist (the opposite is true, via the "EE" shortcut to reveal expressions).
It's a little longer, but you can press U and then press Shift+EE. When you use Shift with one of the shortcuts to show only specific properties, it actually hides them.
The one catch is that shift-EE will hide all attributes with expressions, even those that also have key frames, so the net result isn't quite the same as revealing all properties with keyframes.
This is a good one for a feature request. I've often wanted to be able to have this capability.
D'oh! Of course Aaron is right.
I don't normally do this, but I'm going to go into the feature database right now and add this feature request instead of urging y'all to fill out the feature-request form.
