Hi FMShers,
I have created a video chat application using Flash Media Server, Its working well in Local, But not in FMS (If I connect with my FMS account).
But Text Chat working well, pbm in Video only...... My server is from influxis with Bandwidth 1 mbps, But My application got 13 mb totally, It is any pbm in the server,
I'm very newbie to FMS, so excuse my silliest question and explains if its.
Hope you helps me....
Thanks...
Well, I would first calculate how much bandwidth each of your connections use, multiply by the number of users, and you'll then get your overall bandwidth usage. The tool will allow you to calculate roughly what each video will use in terms of bandwidth in Kilobits per second.
Say for example:
your video/voice/chat uses 500 kilobits per second -> you could have 2 simultaneous connections (1 Megabit per second = 1000 kilobits per second)
As another example, say we have a 200 Megabit per second link,
...Copy link to clipboard
You should increase your bandwidth of server.
Oh.... We have only the 1MBPS of bandwidth, If its not enough, whats the bandwidth suitable to videochat normally,
I need to explain to my client, So please refer any tutorial or article link contains the bandwidth size for video chat,
It helps me...
Hope you helps,
This is a Flash Video Bitrate Calculator,it can help you .
http://www.fmser.cn/post/20.html
hdt1977
2009-05-26
发件人: sureshdavid
发送时间: 2009-05-26 19:34:39
收件人: Firefox hdt
抄送:
It helps me...
Hope you helps,
I cant get the meaning of the link, its in the unknwn languages, execuse
This is the original link:
http://www.adobe.com/devnet/flash/apps/flv_bitrate_calculator/
Thanks asine,
Kindly explain How this calculator helps me.. to clear my bandwidth pbm.... I have 1 mbps bandwidth FMS, But I'm developing a video chat, I want to know this bandwidth is enough or not for my project, In the chat there are so many users can at a time... So please advise me is enough or not, if enough why I cant get the video from my server...
Hopes you near to me...
Say for example:
As another example, say we have a 200 Megabit per second link, we would be able to provide around 400 simultaneous connections (200 Megabits per second = 200000 Kilobits per second).
Hope that gives you idea.
Cheers,
Paul
1 Mbps bandwidth is not enough for your project.
1 user will cost about 300Kbps bandwidth when he publish or play a stream from FMS,both publish and play will cost 300Kbps*2=600Kbps,etc.
FMSer.CN
2009-05-27
Thank you SO much Asine & Fmser, You are rocking.........................................
Thanks for the information sharing............... So finally I would finish my project within 300kbps for a single user, it helps to get live chat at FMS(1mbps). and 1 mbps is not enough for the normal video chat,
I can understood what you told exactly, which what i want exactly men...
Thanks a lot.
Ya I got a correct candle for my dark route, Hope you helps me till the project end.
