We are planning to develop an application which will use flex-hibernate (as client server).
İt also provides an interface to users where they can digitally sign some important data.
We are in the technology selection phase, and try to find some api or etc. about that problem.
İ looked for LiveCycle digital signature ES but, i couldn't find a clear info whether it can provide a solution or not.
does anyone have an idea/comment about digital signature in flex applications???
heres some code I put together a few weeks ago ![]()
hope it helps.
let me know you want server code
<?xml version="1.0" encoding="utf-8"?>
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" initialize="getIP()" creationComplete="setColor()" styleName="plain" viewSourceURL="srcview/index.html" horizontalAlign="center" verticalAlign="top" width="214" height="246">
<mx:RemoteObject
id="myService"
destination="ColdFusion"
source="signature"
fault="mx.controls.Alert.show(event.fault.message)"
showBusyCursor="true">
<mx:method name="getVisitorIP" result="my_IP_handler(event.result)"/>
<mx:method name="doUpload" result="my_CFC_handler(event.result)"/>
</mx:RemoteObject>
<mx:Script>
<![CDATA[
import mx.rpc.events.ResultEvent;
import flash.events.Event;
private var isDrawing:Boolean=false;
public var simpleDP:Array = ['0x000000', '0xFF0000', '0xFF8800',
'0xFFFF00', '0x88FF00', '0x00FF00', '0x00FF88', '0x00FFFF',
'0x0088FF', '0x0000FF', '0x8800FF', '0xFF00FF', '0xFFFFFF'];
private var x1:int;
private var y1:int;
private var x2:int;
private var y2:int;
private var sIP:String;
private var SigFileName:String;
private var drawColor:uint;
private function getIP():void {
myService.getVisitorIP();
private function setColor():void {
drawColor = cp.selectedColor;
private function doErase():void {
canvas.graphics.clear();
private function doMouseDown():void {
x1 = canvas.mouseX;
y1 = canvas.mouseY;
isDrawing = true;
private function doMouseMove():void {
x2 = canvas.mouseX;
y2 = canvas.mouseY;
if (isDrawing)
canvas.graphics.lineStyle(2, drawColor);
canvas.graphics.moveTo(x1, y1);
canvas.graphics.lineTo(x2, y2);
x1 = x2;
y1 = y2;
private function doMouseUp():void {
isDrawing = false;
private function doSave():void {
var bd:BitmapData = new BitmapData(canvas.width,canvas.height);
bd.draw(canvas);
var ba:ByteArray = PNGEnc.encode(bd);
myService.doUpload(ba,sIP);
private function doView():void {
//var u:URLRequest = new URLRequest("../converted_pngs/signature_" + sIP + ".png");
var u:URLRequest = new URLRequest("welcome.cfm?sig=" + SigFileName + ".png");
navigateToURL(u,"_blank");
private function my_IP_handler(result:Object):void {
sIP = result.toString();
lblIP.text = "IP: " + sIP
private function my_CFC_handler(result:Object):void {
SigFileName = result.toString();
btnView.enabled = true;
</mx:Script>
<mx:Canvas width="100%" height="100%">
<mx:Canvas id="canvas" width="100%" height="199"
horizontalScrollPolicy="off" verticalScrollPolicy="off"
mouseDown="doMouseDown()"
mouseMove="doMouseMove()"
mouseUp="doMouseUp()">
</mx:Canvas>
<mx:Button label="Clear" click="doErase()" x="12" y="207" fontSize="10" fontWeight="bold"/>
<mx:Button label="Accept" click="doSave()" x="75" y="207" fontSize="10"/>
<mx:Button id="btnView" label="View" click="doView()" enabled="false" x="149" y="207" fontSize="10" fontWeight="bold" color="#001ED5"/>
<mx:Label id="lblIP" text="IP:" color="#FF6600" y="227" x="10"/>
<mx:ColorPicker dataProvider="{simpleDP}" id="cp" selectedColor="0x006699" showTextField="true" change="drawColor = event.target.selectedColor" y="0" x="0"/>
</mx:Canvas>
</mx:Application>
package {
import flash.geom.*;
import flash.display.*;
import flash.utils.*;
public class PNGEnc {
public static function encode(img:BitmapData):ByteArray {
// Create output byte array
var png:ByteArray = new ByteArray();
// Write PNG signature
png.writeUnsignedInt(0x89504e47);
png.writeUnsignedInt(0x0D0A1A0A);
// Build IHDR chunk
var IHDR:ByteArray = new ByteArray();
IHDR.writeInt(img.width);
IHDR.writeInt(img.height);
IHDR.writeUnsignedInt(0x08060000); // 32bit RGBA
IHDR.writeByte(0);
writeChunk(png,0x49484452,IHDR);
// Build IDAT chunk
var IDAT:ByteArray= new ByteArray();
for(var i:int=0;i < img.height;i++) {
// no filter
IDAT.writeByte(0);
var p:uint;
if ( !img.transparent ) {
for(var j:int=0;j < img.width;j++) {
p = img.getPixel(j,i);
IDAT.writeUnsignedInt(
uint(((p&0xFFFFFF) << 8)|0xFF));
} else {
for(var k:int=0;k < img.width;k++) {
p = img.getPixel32(k,i);
(p>>>24)));
IDAT.compress();
writeChunk(png,0x49444154,IDAT);
// Build IEND chunk
writeChunk(png,0x49454E44,null);
// return PNG
return png;
private static var crcTable:Array;
private static var crcTableComputed:Boolean = false;
private static function writeChunk(png:ByteArray,
type:uint, data:ByteArray):void {
if (!crcTableComputed) {
crcTableComputed = true;
crcTable = [];
for (var n:uint = 0; n < 256; n++) {
var c:uint = n;
for (var k:uint = 0; k < 8; k++) {
if (c & 1) {
c = uint(uint(0xedb88320) ^
uint(c >>> 1));
} else {
c = uint(c >>> 1);
crcTable[n] = c;
var len:uint = 0;
if (data != null) {
len = data.length;
png.writeUnsignedInt(len);
var p:uint = png.position;
png.writeUnsignedInt(type);
if ( data != null ) {
png.writeBytes(data);
var e:uint = png.position;
png.position = p;
var d:uint = 0xffffffff;
for (var i:int = 0; i < (e-p); i++) {
d = uint(crcTable[
(d ^ png.readUnsignedByte()) &
uint(0xff)] ^ uint(d >>> 8));
d = uint(d^uint(0xffffffff));
png.position = e;
png.writeUnsignedInt(d);
Download The Tour De LiveCycle http://tourdelc.adobe.com/badge/ , you can find a lot of info there, and it's meant for developers to easily understand what the heck LiveCycle and all its sub applications are.
So I think the answer to this is no. You can't do this in your Flex/Hibernate application. I don't see anything in the Flex API that would allow me to initiate the signature process.
You could capture a digital signature if you use Live Cycle but it will have to be within a PDF.
Someone prove me wrong an I'll buy you lunch, because I would love this to work.
--Sean
I don't have code to do this, and still don't think it's possible. I also think that if it was done it would need to be done client side in the Flex code not on the server. When you apply a digital signature you have to use the users private key. If the private key was sent to the server to do the signing, that would be a big violation of the way PKI is supposed to work. Since the private key would now be compromised.
Sorry, I meant that for nikos101.
