LR 2.4  Is there a way to make the filmstrip vertical like LR 1?
May 26, 2009 10:19 AM
I want to change the filmstrip from horizontal along the bottom to vertical on the right margin.  Can this be done in LR 2?
Kim
    May 26, 2009 11:20 AM   in reply to KBStudio
    No, the filmstrip is fixed to the bottom.
    May 26, 2009 11:42 AM   in reply to KBStudio
    Click on the little triangle at bottom edge of filmstrip.
    Also note that Tab toggles the side panels open/closed and Shift+Tab toggles side panels and top/bottom panel open /closed.
    May 26, 2009 11:50 AM   in reply to KBStudio
    Also note there is No LR version 2.4, yet. The larest available is 2.3! ANd no word from Adobe when and if a 2.4 will be out.
    Don
    May 26, 2009 1:55 PM   in reply to KBStudio
    Another suggestion would be to plug in a larger non-wide-screen monitor and run the Loup view on this second screen where there aren't any extra panels on the second display.
    You might even be able to rotate the second monitor to portrait mode and tell the video card about the rotation and have LR use it, but I don't have one of those rotatble monitors so can't verify this.
