This topic will be presented at the Creative Suite Developer Summit on May 11th through the 15th. Use this thread to discuss that presentation.
Public/Private Coordinate System:
Most functions in the SDK use the public system of page coordinates, but some use the internal artboard coordinates.
Could all functions in the sdk use the public and "only" public system of pages coordinates. It would be easier and less complex.
We won't have to wonder if we have to "harden" or to "soften" point or matrix depends on AIArtHandle type and property.
thx.
Thomas
Hello Mark,
it seems, that there are no functions that can change artboard sizes. In the Illustrator GUI it is possible to move them around and change their sizes but I can't find any similar functions in the API. If I'm wrong please point me to the right directen, if not please change the API :-)
So we neet
a) Count artboards
b) a List of every artboard with it's lower left and upper right corner in the global coordinates
c) the current artboard on wich the user has worked last (active artboard?)
d) set the current/active artboard
e) set lower left and upper right corner of artboard
e) Get/Set other needfull values for artboard n
And if changing sizes or moving an artboard there should be an option that elements on this artbourd are moved or not.
best regards
Michael
Illustrator CS4 SDK provides ability for developers to access and manipulate Artboard properties and attributes. You need to use the Crop Area suite to get access to the artboard properties and information. As the Artboard functionality is based on the original Crop Area functionality, maybe you are confused and looking for this information with reference to Artboard.
Devshi.
Adobe Systems, Inc.
Hello Devshi,
thanks for your advise. I just tested a few things with CS4 and it seems that it would do what I need.
But how can I cange the Artboard in CS3. A new document has no cropArea and creating one with sAICropArea->AddNew adds one as expected but won't change the Artboardsize itself :-(
In AIDocument is also some stuff wich deals with a CropBox. But without trying around the only promising is SetDocumentSetup which is described only working "when reading a document". Whatever this means...
So do you know how to change the artboardsize in CS3
best regards
Michael Slomski
PS.: Are there some developer licences available? My trial will expire in a few days :-((((((((
Hello Adobe
can anyone from Adobe please check the thread http://forums.adobe.com/message/1990425 or tell me where and how bugs in Illustrator can reported?
Adding a gradient color to the swatches palette does not preserve some values of the gradient. The thread above shows that this could be done and that the "add color" of the swatches palette ignore the angle of the linear gradient and perhapsother stuff. Adobe should check what is really ongoing :-()
best regards
Michael Slomski
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
