I am using Captivate 3, on Windows xp sp3, and the audio editor will not launch at all. I can only externally edit and import or update audio files. Nothing happens when I select an audio file from the Library and choose "Edit with Adobe Captivate...".
Audio recording does work.
Adobe CS4 is installed on this machine, so I considered that might be a conflict - however, I believe I have run Captivate 3 on a machine with CS4 without this issue.
Here is an unanswered post on the same issue from last November.
http://forums.adobe.com/message/35887#35887
Does anyone know of a fix?
Hi there
When you say "Adobe CS4", are you meaning the Creative Suite? Or do you mean Captivate 4?
If it's Captivate 4, I also have the same issue. I'm unaware of a resolution at the moment.
Assuming your setup is like mine, you should consider reporting this to Adobe as a bug.
Click here to visit the Wish Form/Bug Reporting Form
Cheers... Rick ![]()
Hi there,
I would suggest that you take a look at this post.
Adobe Captivate Installation Issues on Microsoft Windows XP
It might be that you are encountering an issue with your Windows Registry.
Best - Mark
Visit the macrofireball blog
