Home/Support/
Forums
1723 Views 4 Replies Latest reply: Jun 8, 2009 11:05 AM by Marc Speck RSS
Marc Speck User 52 posts since
Jun 5, 2009
Jun 6, 2009 5:09 AM
Migration 3>4: borderStyle=none?
I've started to test a migration of a Flex 3 app to Gumbo. I couldn't find out how to remove the border from components like e.g. mx:TextInput. The code below shows the problem:
<?xml version="1.0" encoding="utf-8"?>
<mx:Application
    xmlns:fx="http://ns.adobe.com/mxml/2009"
    xmlns:s="library://ns.adobe.com/flex/spark"
    xmlns:mx="library://ns.adobe.com/flex/halo"
    layout="vertical"
    <mx:TextInput
        borderStyle="none"
        borderThickness="0"
        borderColor="red"
        text="A red border is visible but I expect no border."
    <mx:TextInput
        borderColor="red"
        text="A red border is visible"
</mx:Application>
How can I remove the border of Flex 3 components?
Thanks for any hints,
Marc
  • Peter deHaan Adobe Employee 1,004 posts since
    Jun 29, 2006
    1. Jun 7, 2009 12:31 AM (in response to Marc Speck)
    Re: Migration 3>4: borderStyle=none?
    Marc,
    I believe you may need a custom TextInput border skin to achieve the same effect with the Spark skins for the mx:TextInput control. Certain styles that were supported by the default Halo controls/containers are not as easily tweakable with the Spark skins.
    So, long story longer, here is my solution. I copied the default Spark skin for the Halo TextInput control (you can find the default skin, TextInputBorderSkin.mxml, in the <SDK_Dir>\frameworks\projects\sparkskins\src\mx\skins\spark\ folder) and made a couple minor tweaks and then saved my custom skin as CustomTextInputBorderSkin.mxml in the /src/skins/ folder of my Flex Project. Here's the revised CustomTextInputBorderSkin.mxml file:
    <!--- The Spark skin class for the border of the Halo TextInput component. -->
    <local:SparkSkinForHalo xmlns:fx="
            xmlns:local="mx.skins.spark.*"
            implements="mx.core.IBorder">
        <fx:Script>
            <![CDATA[
                import mx.core.EdgeMetrics;
                import mx.core.IUIComponent;
                /* Define the skin elements that should not be colorized. */
                static private const exclusions:Array = ["background"];
                override public function get colorizeExclusions():Array {return exclusions;}
                /* Define the content fill items that should be colored by the "contentBackgroundColor" style. */
                static private const contentFill:Array = ["bgFill"];
                override public function get contentItems():Array {return contentFill};
                /* Define the border items.*/
                static private const borderItem:Array = [];
                override protected function get borderItems():Array {return borderItem;}
                static private const metrics:EdgeMetrics = new EdgeMetrics(2, 2, 2, 2);
                public function get borderMetrics():EdgeMetrics {
                    return metrics;
                override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void {
                    super.updateDisplayList(unscaledWidth, unscaledHeight);
                    if (parent && parent is IUIComponent && !IUIComponent(parent).enabled) {
                        alpha = 0.5;
                    } else {
                        alpha = 1;
        </fx:Script>
        <!-- fill -->
        <s:Rect id="background" left="1" right="1" top="1" bottom="1">
            <s:fill>
                <s:SolidColor id="bgFill" color="0xFFFFFF" />
            </s:fill>
        </s:Rect>
    </local:SparkSkinForHalo>
    And then I specified the custom border skin by specifying the borderSkin style on the Halo TextInput control, as seen in the following example:
    <mx:Application xmlns:fx="
            xmlns:mx="library://ns.adobe.com/flex/halo">
        <mx:TextInput
                borderStyle="none"
                borderThickness="0"
                borderSkin="skins.CustomTextInputBorderSkin" />
        <mx:TextInput
                borderColor="red"
                text="A red border is visible" />
    </mx:Application>
    Hopefully that helps. For a lot of other great migration information and differences between Flex 3 and Flex 4 (and how to use the Halo skins in your projects), see the following article on the Flex Developer Center: http://www.adobe.com/devnet/flex/articles/flex3and4_differences.html
    Peter deHaan
    Flex SDK Team | Adobe Systems Inc
    Jun 29, 2006
    3. Jun 8, 2009 9:21 AM (in response to Marc Speck)
    Correct.
    For the Spark TextInput control, I would use something like the following:
    <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
        <s:VGroup horizontalCenter="0" verticalCenter="0">
            <s:TextInput id="textInput"
                    skinClass="skins.CustomTextInputSkin" />
        </s:VGroup>
    </s:Application>
    And my custom skin, /src/skins/CustomTextInputSkin.mxml, is as follows:
    <!--- The default skin class for Spark TextInput component. -->
    <s:SparkSkin xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark"
          alpha.disabled="0.5">
        <fx:Metadata>
        <![CDATA[
            [HostComponent("spark.components.TextInput")]
        </fx:Metadata>
        <fx:Script>
            static private const exclusions:Array = ["background", "textView"];
        </fx:Script>
        <s:states>
            <s:State name="normal"/>
            <s:State name="disabled"/>
        </s:states>
        <!-- fill -->
        <!--- Defines the appearance of the TextInput component's background. -->
            <s:fill>
            <!--- Defines the background fill color. -->
            </s:fill>
        </s:Rect>
        <!-- text -->
        <s:RichEditableText id="textView"
                  lineBreak="explicit"
                  paddingLeft="3" paddingTop="5"
                  paddingRight="3" paddingBottom="3"/>
    </s:SparkSkin>
    Peter
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
