Maquese
RH8 IE7 Blank Page
Feb 16, 2009 10:34 AM
My company just moved to Robohelp 8 and I've run into an issue. During some testing for a new project, I created a demo webpage with links to several different context sensitive help ids. See code example below.
In Firefox, clicking each link displays the appropriate help topic in a single window. In IE7, the first link clicked opens the appropriate help topic in a new window, but clicking any subsequent links on the demo page causes IE7 to display only a blank webpage. If I close the help window and click a link in the demo page, the appropriate help topic is displayed in a new window, but, again, clicking any other link on the demo page displays a blank webpage.
I even tried upgrading an existing project from RH7 into RH8, and the webhelp exhibits the same issues that the new project does.
Thoughts?
    Community Member
    Feb 23, 2009 3:00 AM
    I have the same problem. I call the help from my (.NET) application. The first time the help shows fine, but when I leave the browser open and call the help again I recieve an error : Access denied, whcsh_home.htm, line 196 char8
    It seems to be a bug, so I hope for a fast response.
    Community Professional
    Feb 23, 2009 4:50 AM
    Calling a second topic whilst the first is still open was a problem here but it was fixed by some changes to our calls to the help. This was done by the developers who have their own routine for calling the help.
    There is some information that I gleaned from them on my site. See Calling WebHelp.
    EVDL. The error you are getting is not the same as you are getting an error message. On the subject of fast responses, this forum is a user to user forum so you get answers when people can fit them in with their work. That is usually pretty quick. If you need faster, try Adobe Support.
    Community Member
    Feb 24, 2009 4:07 AM
    Peter, thanks for your reaction and I'am sorry to expect a (to) quick reaction.
    The manner I want to communicate with my Help is from an .NET windows application. With Robohelp 8 there is a RoboHelp_CSH.cs file you can use to open the default browser and open the context-sensitive WebHelp based on Map id's. Even with de adjustmenents on the Url I do not succeed to fix the problem.
    The url I use is : http://<server>/index.htm#<id=<number>
    The first time it works fine, but when I leave the browser open and ask for help again it goed wrong
    Feb 24, 2009 4:57 AM
    EVDL no worries but I needed to explain how things work here. I cannot help you with calls to the help other than point to the links on my site. They contain information written by others who do understand such things and they may have covered this issue.
    Have you checked the RH Help on this subject?
    Looking at the other Maquese's code in this thread, that call using map ids does look very different to yours which seems to be a mix of the URL call and the map id call. However, that would break even the first call if I were right.
    Feb 24, 2009 7:09 AM
    Adobe is looking into this problem and is close to finding the fix.
    Vivek.
    Adobe RoboHelp Team
    Community Member
    Feb 27, 2009 3:29 AM
    We have found the fix, file <Program files>\Adobe\Adobe RoboHelp 8\RoboHTML\WebHelp5Ext\template_csh\whcsh_home.htm is the culprit.
    4 lines (code attached) are to be removed from function SwitchURL()
    If you are not comfortable removing this then you shall find this updated file on Peter's site.
    He continues to be the most helpful person around :-)
    Vivek.
    Feb 27, 2009 3:45 AM
    It will be on my site for Monday.
    And I love you too Vivek. :-)
    Community Member
    Feb 27, 2009 8:17 AM
    Was the code Vivek posted new in whcsh_home.htm for RH8? It's not in that file for an RH7 project.
    Feb 27, 2009 8:44 AM
    Yes, this thread is for RH8.
    Mar 1, 2009 6:52 AM
    The fix is for EVDL's issue only. Maquese's issue is different.
    Mar 2, 2009 4:30 AM
    Hi Vivek,
    I am facing the same issue with RoboHelp for Word X5. But i dint find the code which you typed for RH8. Could you please assist with RHX5 as well.
    I just see a blank page when i click on the Help link. i do not see any error. The help files opens and then goes off byitself and i get to see only the transferring from the weblink and a blinking progress bar. Please help
    Regards
    Chandrika
    Mar 2, 2009 6:34 AM
    Hi Chandrika
    I'll be very surprised if you hear from anyone on your issue. There are a few different reasons.
    1. You are using RoboHelp for Word. Fewer and fewer people are using this and moving to RoboHelp HTML.
    2. You didn't say what your output type is? WinHelp? WebHelp? FlashHelp?
    3. You are using a very old version of RoboHelp. According to my records, X5 was released in January 2004. That's five years ago. An eternity in computer terms.
    Cheers... Rick
    Community Member
    Mar 18, 2009 10:38 AM
    Thank for Info. this forums help me a lot.
    zojirushi
    Dec 16, 2009 4:26 PM
    I seem to be having the same problem - second context sensitive help file does not load. I also have Robohelp 8.0.2 and have experimented with the new file - still doesn't work. Everything works fine in Firefox (and flawlessly in Google Chrome). Not in IE 8.
    Dave Richards
    Community Member
    Dec 18, 2009 12:38 PM
    OK, so I downloaded Mr. Grainge's file (thank you, sir) and followed his instructions. This solved my problem.
    However, I must note that I had already downloaded and installed both the 8.0.1 and 8.0.2 updates for Robohelp 8.
    Curious, I did a file comparison between the whcsh_home.htm file I had in my Robohelp folders and Mr. Grainge's file.
    They are NOT the same. Shouldn't the 8.0.1 update have solved my problem?
    Thanks to Peter Grainge for his help.
    Dec 18, 2009 1:15 PM
    I would have thought the DLL in the patch would have included the fix for this problem. I'll let Adobe know there is still an outstanding issue as far as patches are concerned.
    Follow me @petergrainge
    Feb 26, 2010 4:12 PM
    I am a newbie to this forum.
    I have the same problem described in this thread and I would like to get the fix for function SwitchURL() in template_csh\whcsh_home.htm. This post says "4 lines (code attached) are to be removed from function SwitchURL() "; but I don't see where the code is attached.
    Can you help me?
    JGaf,
    Community Member
    Feb 27, 2010 12:22 AM
    hmmm...I searched too for this information on Peter's site and couldn't find it.  Has it been removed?
    Is this the same issue I asked in this post:
    IE 7 and Firefox 3 display issues - neither work as expected
    Feb 27, 2010 1:55 AM
    Jgaf
    It is not the same issue.
    @petergrainge
    Feb 27, 2010 1:56 AM
    Tony Y
    Download the file from Item 1 in Using RH8 on my site. You can use that or compare the files.
    @petergrainge
    Community Member
    Mar 1, 2010 4:46 PM
    Thanks Peter.
    I replaced whcsh_home.htm with your version and then I re-generated/re-published my help files. IE7 works fine. IE8, not so much. With IE8, I am able to open help twice, but not three times.
    This is all pretty strange. I have version 8.0.2.208, so I would have expected that my template_csh would have had a version of whcsh_home.htm that was at least as current at yours. The modified date on your file is 3/1/2009 12.32 PM. All of the other files in my template_csh have a modified date of 12/14/2008 3:42 PM. Does that seem strange to you?
    Also, do you know if Adobe has a fix for the problem with IE8?
    Tony
    Mar 3, 2010 10:18 AM
    The file will have been moved from PC to PC so I wouldn't worry about the date.
    See Calling WebHelp Using URLs on my site. There is information there about a change that may be needed but not sure without running through it again if it is relevant.
    @petergrainge
    May 12, 2010 1:28 PM
    We are having this problem using IE8 even after updating my whcsh_home file with the one you suggested. It is preventing us from moving foward with releasing a new version of software at the moment.
    Here is what we have found:
    Setting the debugger on the page with the error shows this is the line with the error:
    curWnd = window.open("about:blank",sNewName,strOpt);
    We are falling into the following code:
    if(gbIE5)
         var curWnd = null;
         goNewWnd=window.open(sURL,sNewName);
    else
         gsURL = sURL; // IE4 had hard time to handle bookmark.
         goNewWnd=window.open("about:blank",sNewName,strOpt);
    setTimeout("postWindowOpen();",100);
    Someone else is having this problem, but no replies/solutions exist:
    http://forums.adobe.com/message/40878#40878
    Even though we are running IE8, we are falling into an IE5 branch in the whcsh_home file?
    Please help, I've tried to figure it out on my own, and there are several people in my office that are also trying to figure it out but we are all puzzled.
    Sep 13, 2010 1:02 PM
    Note that someone named Derek Price has offered a possible solution in the thread linked below.
    Click here to view
    Cheers... Rick
    Helpful and Handy Links
    RoboHelp Wish Form/Bug Reporting Form
    Begin learning RoboHelp HTML 7 or 8 moments from now - $24.95!
    Adobe Certified RoboHelp HTML Training
    SorcererStone Blog
    RoboHelp eBooks
    Community Member
    Oct 13, 2010 10:15 AM
    (I know this might be asking a lot but...) Do you have the code from this post? I did not see an attachment and I could not find it on Peter's site.
    Amanda
    Oct 13, 2010 10:38 AM
    See Using RH8 Item 1.
    After downloading, do the following. I will be adding that to my site shortly.
    Derek Price found this file did not work and made the following changes.
    Lines 193 and 194 were commented out by prefixing them with double forward slashes
    // var curWnd = null;
    // curWnd = window.open("about:blank",sNewName,strOpt);
    Line 195 was amended from
    to
    goNewWnd=window.open(sURL,sNewName,strOpt);
    Thanks to Derek for testing with IE6, 7, & 8, and FF 3.6 and for sharing his changes#.
    @petergrainge
    Community Member
    Oct 13, 2010 10:46 AM
    This worked for us (your file and Derek's update)- Thank you for the quick response!
    Amanda
    Community Member
    Oct 13, 2010 11:43 AM
    So, Peter has taken care of the issue for you?
    He does seem pretty responsive.
    Cheers,
    Dave Richards
    Nov 24, 2010 12:43 PM
    I'm also trying to get WebHelp generated by RH 8 to work properly with IE 8 (FF works fine.). The default 8.02 installation  causes the blank window issue stated by the original poster. Using the version on Peter's website causes a different set of issues (including a blank popup window and an Access Denied error). After  applying Derek's changes to my project, I was able to call it twice  using map IDs. However, all subsequent calls to it are ignored. All suggestions are welcome.
    Joe
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
