micric14
AVCHD lite
Apr 20, 2009 2:04 PM
I'm considering buying a new Panasonic still camera which also records & saves video in "AVCHD lite" format and records audio using the "Dolby digital stereo creator". I'm probably being naive to ask but does Premiere Elements 7 accept these formats ? If not, does anyone know of a cheap & cheerful workaround until it does?
    Community Member
    Apr 20, 2009 2:42 PM
    PE7 does work with AVCHD files. The one thing to consider is the power of your computer, as it takes a lot of horsepower to process these files. Your enjoyment will be directly proportional to the processing power and to your hard disk setup.
    You might want to do a Search on this forum for AVCHD and also look on the fora in Muvipix. There are many articles on editing these files.
    Hunt
    Community Member
    Apr 20, 2009 3:17 PM
    As Hunt says, PE7 supports AVCHD, however AVCHD Lite is somewhat different than AVCHD in that it is a 720p resolution. The lower resolution allows longer files to be captured and therefore it is finding it's way into stills cameras and in some cases replacing the MJPEG codec. The only issue is that PE7 does not have a 720p project preset for AVCHD only 1080i. Therefore your best bet would be to use it in a HDV 720p project.
    Community Member
    May 10, 2009 2:52 PM
    I cannot even read AVCHD Lite from LUMIX TZ7 in Adobe Premiere Elements 4.....
    So Not Supported, yet ???
    Community Member
    May 10, 2009 3:17 PM
    AVCHD was only supported starting with PE7.
    Community Member
    May 10, 2009 3:21 PM
    AVCHD is supported by Premiere Elements with VAIO extensions, but only for 1080i footage.
    I am talking about AVCHD Lite
    Community Member
    May 13, 2009 7:14 AM
    Good News,
    Despite what Sony support says !!?!!!
    Try the last version of Sony Vegas 9, it works wonderfully with Panasonic 720/50p  (Panasonic codec seems to come from Sony...)
    You can even render the file in 720/25p or even 720/50p (by typing 50 in the combo box)
    Use File   Advanced  New personalized Template, Format:AVC, Size 1280x720
    Binary Kbits Base Line
    Profil CAVLS
    Imlmage 25 or 50(type it)
    Encoding 20000
    Audio 192000
    And you get an mp4 file with the same characteristics that your original and the same quality
    It is not packed in an MPEG-2 envelope but who cares
    You can even pack it after in an MPEG2-PS with VLS and get a completely comform m2ts.
    Best Regards
    Dominique
    Community Member
    May 13, 2009 7:55 AM
    Good News,
    Profil CAVLS
    Encoding 20000
    Audio 192000
    Best Regards
    Dominique
    Community Member
    Jun 7, 2009 10:01 AM
    Dominique, thanks you,  I don't find some of the rendering options you suggest for Sony Vega Studio Pro 9.
    I'm a real newbie when it comes to video editing.
    Could you be more specific and detail all the rendering and project settings?
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
