I've started to test a migration of a Flex 3 app to Gumbo. I couldn't find out how to remove the border from components like e.g. mx:TextInput. The code below shows the problem:
<?xml version="1.0" encoding="utf-8"?>
<mx:Application
xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:mx="library://ns.adobe.com/flex/halo"
layout="vertical"
<mx:TextInput
borderStyle="none"
borderThickness="0"
borderColor="red"
text="A red border is visible but I expect no border."
<mx:TextInput
borderColor="red"
text="A red border is visible"
</mx:Application>
How can I remove the border of Flex 3 components?
Thanks for any hints,
Marc
Marc,
I believe you may need a custom TextInput border skin to achieve the same effect with the Spark skins for the mx:TextInput control. Certain styles that were supported by the default Halo controls/containers are not as easily tweakable with the Spark skins.
So, long story longer, here is my solution. I copied the default Spark skin for the Halo TextInput control (you can find the default skin, TextInputBorderSkin.mxml, in the <SDK_Dir>\frameworks\projects\sparkskins\src\mx\skins\spark\ folder) and made a couple minor tweaks and then saved my custom skin as CustomTextInputBorderSkin.mxml in the /src/skins/ folder of my Flex Project. Here's the revised CustomTextInputBorderSkin.mxml file:
<!--- The Spark skin class for the border of the Halo TextInput component. -->
<local:SparkSkinForHalo xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:local="mx.skins.spark.*"
implements="mx.core.IBorder">
<fx:Script>
<![CDATA[
import mx.core.EdgeMetrics;
import mx.core.IUIComponent;
/* Define the skin elements that should not be colorized. */
static private const exclusions:Array = ["background"];
override public function get colorizeExclusions():Array {return exclusions;}
/* Define the content fill items that should be colored by the "contentBackgroundColor" style. */
static private const contentFill:Array = ["bgFill"];
override public function get contentItems():Array {return contentFill};
/* Define the border items.*/
static private const borderItem:Array = [];
override protected function get borderItems():Array {return borderItem;}
static private const metrics:EdgeMetrics = new EdgeMetrics(2, 2, 2, 2);
public function get borderMetrics():EdgeMetrics {
return metrics;
override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void {
super.updateDisplayList(unscaledWidth, unscaledHeight);
if (parent && parent is IUIComponent && !IUIComponent(parent).enabled) {
alpha = 0.5;
} else {
alpha = 1;
</fx:Script>
<!-- fill -->
<s:Rect id="background" left="1" right="1" top="1" bottom="1">
<s:fill>
<s:SolidColor id="bgFill" color="0xFFFFFF" />
</s:fill>
</s:Rect>
</local:SparkSkinForHalo>
And then I specified the custom border skin by specifying the borderSkin style on the Halo TextInput control, as seen in the following example:
<mx:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:mx="library://ns.adobe.com/flex/halo">
<mx:TextInput
borderStyle="none"
borderThickness="0"
borderSkin="skins.CustomTextInputBorderSkin" />
<mx:TextInput
borderColor="red"
text="A red border is visible" />
</mx:Application>
Hopefully that helps. For a lot of other great migration information and differences between Flex 3 and Flex 4 (and how to use the Halo skins in your projects), see the following article on the Flex Developer Center: http://www.adobe.com/devnet/flex/articles/flex3and4_differences.html
Peter deHaan
Flex SDK Team | Adobe Systems Inc
Correct.
For the Spark TextInput control, I would use something like the following:
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
<s:VGroup horizontalCenter="0" verticalCenter="0">
<s:TextInput id="textInput"
skinClass="skins.CustomTextInputSkin" />
</s:VGroup>
</s:Application>
And my custom skin, /src/skins/CustomTextInputSkin.mxml, is as follows:
<!--- The default skin class for Spark TextInput component. -->
<s:SparkSkin xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark"
alpha.disabled="0.5">
<fx:Metadata>
<![CDATA[
[HostComponent("spark.components.TextInput")]
</fx:Metadata>
<fx:Script>
static private const exclusions:Array = ["background", "textView"];
</fx:Script>
<s:states>
<s:State name="normal"/>
<s:State name="disabled"/>
</s:states>
<!-- fill -->
<!--- Defines the appearance of the TextInput component's background. -->
<s:fill>
<!--- Defines the background fill color. -->
</s:fill>
</s:Rect>
<!-- text -->
<s:RichEditableText id="textView"
lineBreak="explicit"
paddingLeft="3" paddingTop="5"
paddingRight="3" paddingBottom="3"/>
</s:SparkSkin>
Peter
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
