Tacking this preloader on almost working - what's missing?
Jun 8, 2009 5:54 AM
Hi
I found a cool preloader tutorial with a free preloader which I added onto my flash project.  I did it by creating a new scene before my project scene, and adding the preloader to it.
The pre loader works fine, and my project all worked fine before I put the preloader on, but now after the preloader finishes, my site's buttons won't work and in Flash CS4 there is a compiler error:
TypeError: Error #1009: Cannot access a property or method of a null object reference.
    at website_fla::MainTimeline/frame2()
Take the preloader scene away, and my site works fine again.
Any idea what I need to do to make them work together?
Cheers
Shaun
  • kglad
    Jul 21, 2002
    Jun 8, 2009 5:57 AM   in reply to billygoatkaraoke
    show the code you added.
  • kglad
    Jul 21, 2002
    Jun 8, 2009 6:58 AM   in reply to billygoatkaraoke
    you need a movieclip named:  preloaderMC
  • kglad
    Jul 21, 2002
    Jun 8, 2009 7:01 AM   in reply to kglad
    actually, it looks like the problem is in frame 2.
    click file/publish settings/flash and tick permit debugging.  retest.  note the frame/line number of the error.  find that object that's causing the error.
  • kglad
    Jul 21, 2002
    Jun 8, 2009 7:37 AM   in reply to billygoatkaraoke
    there's something on your main timeline frame 2, line 18.
  • kglad
    Jul 21, 2002
    Jun 8, 2009 7:33 PM   in reply to billygoatkaraoke
    there's only one main timeline.
    if your first scene is the preloader scene and that has only one frame, then frame 1 of the next scene is the frame containing the problematic code.  whatever's on line 18 in that frame is the problem.
  • kglad
    Jul 21, 2002
    Jun 8, 2009 11:31 PM   in reply to billygoatkaraoke
    no, i didn't think that added any info.
    here this may help you help yourself.  scenes don't exist when you publish/test your swf.  flash arranges the timeline of each scene from the last frame of the previous scene followed immediately by the first frame of the next scene.
    so, that's why we know the error is in your 2nd scene's frame 1.  the first scene only has 1 frame so the next frame will be the first frame of the 2nd scene.  if you post the line of code that matches the number in the error message, we should be able to pinpoint the object reference causing the problem.
  • kglad
    Jul 21, 2002
    Jun 9, 2009 6:55 AM   in reply to billygoatkaraoke
    what happens if you comment out all your preloader code?  do you see the same error?
  • kglad
    Jul 21, 2002
    Jun 9, 2009 7:31 AM   in reply to billygoatkaraoke
    post a link to your fla or zip it and attach it here.
  • kglad
    Jul 21, 2002
    Jun 9, 2009 10:02 PM   in reply to billygoatkaraoke
    here's your corrected file:  www.kglad.com/Files/website.zip
    the problem was your use of movieclips in your buttons.  those buttons weren't instantiated when your frame2 first played and the code executed.  the objects on-stage needed to "render" before they were referencable.
  • kglad
    Jul 21, 2002
    Jun 9, 2009 11:18 PM   in reply to billygoatkaraoke
    the duplicate objects in your preloader scene is what you sent me.  just remove all 3 duplicates.
    add:
    stage.invalidate();
    // just before the render listener.  retest.
  • kglad
    Jul 21, 2002
    Jun 10, 2009 7:48 AM   in reply to billygoatkaraoke
    that's all i did and it's working for me:
  • kglad
    Jul 21, 2002
    Jun 10, 2009 7:10 PM   in reply to billygoatkaraoke
    when i run it the gilbert buttons opens the gilbert page (complete with tainted love!).  and then if i click anything else the video keeps playing (and if i click gilbert again i hear tainted love playing over tainted love in an awful cacophony that all flashers know too well).
    are you sure it's not working for you?  is the website.fla dated 6/10 at 7:47 am?
  • kglad
    Jul 21, 2002
    Jun 10, 2009 7:44 PM   in reply to billygoatkaraoke
    i see that problem on your site.  but not on mine:   http://www.kglad.com/Files/website.html
    i zipped the fla, html and swf and reupped:  http://www.kglad.com/Files/website.zip
