"Update Link" keyboard shortcut
Jun 16, 2009 7:33 AM
Is there a keyboard shortcut to automatically update modified links?  I couldn't find it in Edit > Keyboard Shortcuts, maybe there's a different way?
    Jun 16, 2009 8:04 AM   in reply to Landdogger
    Try this....
    - go to the menu Edit > Keyboard Shortcuts
    - in the popup window, select Panel Menus
    - scroll down the section that starts with Links... until you get to Links: Update Link
    - set a command key of your choice
    - click 'assign'
    - another window will appear saying you can't modify the default set - and do you want to create a new set based on the default. Click yes
    - in the new popup window, name the set, and click OK
    - click OK in the open window
    ... you should be good to go.
    good luck!
    elaine
