am new to indesign and just got a job in a publishing company responsible for the layout of their newspaper, am used to working with jpeg but them my predecessor was using .eps files, my problem is that the eps files appear bad in document but good in print, but lately i streched a picture too much and had no way of telling if its pixilated or not, how can i notice that a picture has been stretched too far.. PARDOM MY ENGLISH
If the images are vector files (like logos, that are supposed to have smooth edges) then eps files are much better than jpegs. If you go View>Display Performance>High Quality Display you will see them better but the views will update slower. You can stretch a vector eps file as much as you want and it will never lose quality, however some eps files also contain bitmap images that will lose quality when you stretch. The info panel may help here.
How is it that you are stretching an eps file?
An eps file should be used as it is provided. You should go back to the original file, before the eps was created, to manipulate elements.
I'm sure if this eps was provided from an advertiser they wouldn't want it stretched and if it was produced inhouse as I said I cant see why you aren't working with the orginal source file.
high resolution pdf's would be a better format.
these are hi res pictures from the journalists that come in jpeg format, what i do i sent them to Photoshop and reduce the resolution to 72dpi (is still correct?) then i save the file as .eps. so far the output is fine save for the pic that i streched too much and its pixilated in output, my question is how can i tell if an .eps file has been stretched too much given that unlike jpeg, they appear bad when imported even though they appear good at output.
Is it time to buy the Classroom in a book?
That is not a good way to do it. Don't do anything to the jpegs that they send you, apart from converting them to CMYK in Photoshop if necessary. Place them in Indesign and set the resolution on export (I assume you're exporting to PDF?). That will mean that they all have the same resolution and you won't run into problems if you enlarge something. Use the info panel to see what their resolution is, the effective figure will tell you if you're making a photo too big.
Osgood: for stretching read enlarging, it was never said that the stretch was only in one direction!
i hope this is not too late to save my job..
so you agree that i should not convert these images to eps, i should place them as jpegs. What is the correct resolution because some pics are sourced from the net and might not have the same res as the ones from the journos.
When i package the file i get a warning about transparency blend not matching the pdf, what is this all about.
I need this job i can't tell the boss am failing..
Personally I would not convert them to eps. Tiffs are propably a better option.
Not sure that all rips (raster image processors) handle jpgs, check with your print house if they can.
Depends on the quality of the publication as to what resolution you use. If it's a glossy journal 300dpi, if its newsprint you could possibly get by on 150dpi. Using images sourced from the net, which are usually poor quality 72dpi, arent really good enough to use for print.
If they are digital images supplied by the journalist then they may provide them at 72dpi but they would normally be very large in area size. In this instance you can resample them down to 300dpi in photoshop.
I would not worry about the 'warning'. Your print house will handle the output.
makate wrote:
if they handle jpeg do you recommend that i keep them, and the res should be at 150dpi, the images from the journos are very big yet the res is 72dpi this confuses me a lot, so if i resample them to 300dpi should i again reduce the res to 150dpi to match the other images..
If your prepress company (the one you use to output the InDesign files) says they can handle jpgs then I see no reason why you should not leave them as jpgs.
To be on the safe side I'd leave all of your resolution at 300dpi. If that much resolutiuon is not required it won't matter as the rest just gets ignored at output stage whereas if 300dpi is required and you send 150dpi images then they may not look as sharp as they should do.
Its best always to check with your prepress company what the requirements are.
Digital images can be very large in dimension and yet only have 72dpi. In photoshop change the dpi to 300 make sure the 'resample image' box is unchecked. You should see the image reduce in dimension whilst keeping its clarity. A good check is to zoom into the image 2 or 3 times, if it doesnt pixilate too much from the original then you know it will be good to print.
Your newspaper may have a media pack where all the print specifications are written down.
the company is new and am required to set standards and all.. so i have to work everything from scratch as my predecessor has done nothing and he has been using eps that you reckon is not a good idea. I agree with you on the clarity loss, the images appear dull on output and we blamed the quality of the print, so i should ask the printers if they take the 300dpi.. please break it down for me so i can be able to improve the quality of the paper.. currently it looks amaturish.
Makate, to get the maximum resolution for your images you don't have to do anything! Leave them how you get them! Indesign will automatically downsample them to a suitable resolution when you export to PDF, for example Press Quality is between 300 & 400dpi. You only have to use Photoshop if they're RGB and your output needs CMYK.
Talk to the next user (i.e. printer or prepress operator) of your files and ask them what they need, they will appreciate you trying to put standards in place.
This means that the photo is 300ppi (Actual) but at the size that you've got it you can only get 170ppi (effective). So if you want to output at 300ppi (recommended for high quality offset print) you'll either need to make the image smaller in Indesign or get a bigger image. A problem I get is that sometimes photographers email their pictures and send a smaller one so it'll come faster.
makate wrote:
what if the picture is smaller than the space reserved, can't i strech them and how can i know i have reached the limit, someone suggested the Info panel so this is what i see:
Actual ppi: 300x300
Effective ppi: 170x170
what does all this mean in terms of the picture quality.
You can enlarge the image in photoshop without it losing that much definition, 50% or so. You'll lose a bit of quality but it won't be noticable to joe public and it may well be that a larger sized image is not available.
Then bring it back into InDesign and look at the resolution info.
Persoanally I'm not keen on this idea of leaving your images as you have recieved them and letting InDesign do the output calculations. I'd rather manually make sure the images contain the correct resolution, color space etc etc
am sorry but am not understanding what you are saying.. i wanted you to explain to me how van i tell if i have reached the limit and what is the explain to me what the Info panel is all about..
Am now encountering a new problem.. Indesign closes when a create pdf.. what could be the problem
Sorry.
Window > Info... this shows you all kinds of useful information about whatever is selected.
The "rule of thumb" for resolution (and the only resolution that matters is "effective resolution") is that it should be two times the line screen at print size. The line screen is how densely the halftone spots are packed on the paper, and affects the balance between spot size, detail and number of gray levels (or other color levels) produced in the printed image.
Two times is actually more than is really required -- 1.4 x is about the minimum -- and newsprint is very porous so you can't print using high lpi values. I think 85 to 100 lpi is pretty typical these days, so 200 ppi effective resolution should be fine for a target, and 180 ppi ought to be no problem. Even 150 ppi will probably be OK on newsprint for most images.
Crash on export to PDF can be caused by a lot of different things, from bad fonts or images, to not having enough temp space. Do you get an error message?
Peter
When Makate said "i hope this is not too late to save my job..
so you agree that i should not convert these images to eps, i should place them as jpegs. What is the correct resolution because some pics are sourced from the net and might not have the same res as the ones from the journos."
It inspired me to add my thoughts to this conversation. I am a basic knowledge user of ID so I'm not going to be able to give you expert advice like the others, but I want to offer my simple thoughts.
First, do what the experienced people said—talk to the prepress people and begin establishing a good working relationship with them to define the requirements for publication. I find that if you establish good lines of communication and ask intelligent questions, people usually are motivated to help you. Don't be uncomfortable saying to your new employer that you don't know the answer to a particular situation, followed by a confident attitude that you will sure find out. You have an incredible resource here in this forum where you can receive great help. Employers appreciate when their people are hardworking and dedicated to doing a good job. Makate you seem that and more. I think you'll do fine when you get your feet wet in this job.
This part I'm going out on a limb because I may not know what I'm talking about, but when you said "what if the picture is smaller than the space reserved..." Here's my input.
1. Always save the photo you receive or obtain in the original format.
2. Make a copy that you then use to edit to whatever resolution you learn from the prepress people is what they want.
3. If the reserved space is 2 x 3 or ? edit your photo in photoshop to fit that space.
So, hang in there, be optimistic and go for success. (Donuts or cookies now and again to show your appreciation to the help you receive from the prepress people couldn't hurt either!)
Good luck,
Patty
Good advice, as long as you mean "leave the original alone".
There is rarely any good reason to upscale resolution. So if your prepress people ask for 300 ppi, downscaling to 300 ppi is harmless, but if you're starting with a 100 ppi photo, upscaling to 300 ppi just hides the low resolution. Adding resolution doesn't add any new detail and you'll end up with hi-res garbage. For that matter, unless you're going to sharpen your photos, downscaling to 300 ppi is unnecessary, unless you're considering file size and RIP time.
Again, not really necessary. Cropping before Indesign is harmless but unnecessary, unless (again) you're considering file size and RIP time.
Ken
Ken,
Thanks for your comments about my basic instructions to Makate. I knew the experienced people would chime in. My main purpose for talking was to give Makate a feeling of confidence that there are life-lines here that can help. I don't want Makate to lose the job and I like the donut/ cookie idea!
I don't know about the RIP etc. that you speak of (that's the stuff I thought the prepress people would help with) but I do have one question. If Makate was forced to deal with a small-sized 100 ppi photo for placement in the newspaper would a slight upscaling for newspaper print be really noticeable to readers?
Patty
this has been very helpful.. am printing today at 12pm (south african time) and i you have helped me so much that i now feel confident now and it has in the process solved the technical problems of Indesign crashing when opening documents and closing without a warning when generating pdf.. i missed the deadline but its not much of a train smash.
now this is what i did based on the advice you guys so generously provided:
1. I changed all my images back to jpg and the res to 300dpi (the resampling advice helped me a lot here), i found it very helpful that i could use Photoshop to view how far the images can be enlarged without compromising the quality.
2. I found that some of my Links were in different directories owing to copying previous articles into the current without updating the Links.
The Indesign ni longer crash and i have generated the pdf, the proofs have been printed and the pictures look perfect..
Thank you Guys![]()
PS: Its a pity i can't email the doughnuts maybe i could get you free accomodation if you are coming to South Africa for the 2010 World Cup..
Congratulations, Makate!
One more bit of advice, though...
If you are re-saving any image for print don't use jpeg as the file type. JPEG uses lossy compression and every save cycle does some damage to the image, though how much depends on the quality settings for the save. JPEG also does not support transparency and layering which limits what you can do.
Instead, use TIFF or even native PSD files. Any layout application can import tiff, and it has the option for lossless LZW compression if you need it, and InDesign is quite happy importing native PSD files (also natively compressed without loss), my personal first choice.
Peter
It's not that upsampling resolution would be noticeable; it's that it wouldn't make any difference except to hide the fact that it's low-res. Preflight programs look specifically for low-res images, but if you upsample, it's still going to look like sh*t, but preflight will be happy with it.
Ideally, users wouldn't try to print low-res images, but many people think they can copy pictures from the web and use them in print. Web art is usually 72 ppi; print art is usually 200-300 ppi. Web art looks bad in print unless you make it really small.
If you need to print a picture and it's low-res, you have four choices:
1) Get a higher-res original
2) Print it small
3) Print it anyway
4) Upsample it to high-res and print it anyway.
Choices 3 and 4 are really the same thing, except that preflight won't see the problem in choice 4.
Why all this talk of upsampling? It sounds to me that there is a complete lack of understanding of the resolution to file size. Most Jpegs from a digital camera have plenty of resolution. all that needs to be done is changing the ppi without resampling anything. after the ppi has been changed the image needs to be saved as PSD or Tiff.
Yes, they do. And if everyone got their pictures from a camera I wouldn't be droning on and on about resolution. But many, many people get their pictures from the internet, and these pictures are almost never acceptable quality for print. Those same people who think web-quality pictures are good enough to print often think you can make something out of nothing and "fix" those pictures by upsampling.
There is no free ride with images. Resolution is like money: printing more than you really have is counterfeiting.
Ken
