Hi!
I'm still having the same problem
I was hoping to find some solution, because it is really annoying.
I've noticed that this exception occurs after some minor modification in topic text (e.g. correcting a grammar mistake). Also, after generating JAVA help and viewing the results, the topics which have "?xml version="1.0" encoding="utf-8" ? at the beginning, won’t be displayed correctly and won’t be found in the search results.
So, I was not able to find the problem, although my colleague can modify the same help projects, and won’t get the same exception
. So, my PC was changed, Robo Help installed freshly, but this problem still remains
Well, any clues?
I have moved this thread to the Other Layouts category where it belongs as the problem is with a particular output.
I don't know the answer but hopefully SYGP or Susan Darling will come back with how they solved the problem.
Thanks for the reply.
There are two possible workarounds in this case:
1. Import the source again and do not change a thing.
2. Extract the damaged output file and delete the "?xml version="1.0" encoding="utf-8" line. Then compress .jar again.
Neither of these are timesavers ![]()
I'll be still hoping to see a solution for this problem.
Sounds like the time to report a bug.
The more people who report a bug or request a feature, the more likely it is to be actioned. Please follow this link.
http://www.Adobe.com/cfusion/mmform/index.cfm?name=wishform&product=38
