    Community Member
    Mar 18, 2009 11:01 AM
    Yes indeed is noticeable faster, and yes I do have problems with the use of the library. For example lets take a look at MetalBot's project. The following is his as3_jpeg_wrapper.gg
    { // start pass-thru C code
    #include <stdlib.h>
    #include <stdio.h>
    #include <jpeglib.h> //This is the library I want to use
    #include "badatadst.h"
    void sztrace(char*);
    AS3_Val no_params = NULL;
    AS3_Val zero_param = NULL;
    AS3_Val ByteArray_class = NULL;
    #define GGINIT_DEFINED true
    static void ggInit()
    sztrace("setting up as3_jpeg_wrapper library");
    no_params = AS3_Array("");
    zero_param = AS3_Int(0);
    AS3_Val flash_utils_namespace = AS3_String("flash.utils");
    ByteArray_class = AS3_NSGetS(flash_utils_namespace, "ByteArray");
    AS3_Release(flash_utils_namespace);
    /* Copy the byteArray data into a malloc'd buffer */
    static void* newMallocFromByteArray(AS3_Val byteArray, unsigned int* size)
    AS3_Val byteArraySize = AS3_GetS(byteArray, "length");
    *size = AS3_IntValue(byteArraySize);
    AS3_Release(byteArraySize);
    void* bytes = malloc(*size);
    AS3_SetS(byteArray, "position", zero_param);
    AS3_ByteArray_readBytes((char*)bytes, byteArray, (int)*size);
    return bytes;
    /* end pass-thru C code */
    import flash.utils.ByteArray;
    public function write_jpeg_file(data:ByteArray, width:int, height:int, bytes_per_pixel:int, color_space:int):ByteArray {
    struct jpeg_compress_struct cinfo;
    struct jpeg_error_mgr jerr;
    unsigned int size = 0;
    unsigned char* raw_image32 = newMallocFromByteArray(data, &size);
    unsigned char* raw_image24 = (unsigned char*)malloc(size*3/4);
    AS3_Val array = AS3_New(ByteArray_class, no_params);
    /* this is a pointer to one row of image data */
    JSAMPROW row_pointer[1];
    /* semi-lame conversion from 32bit pixels to 24bit pixels. */
    int i=0,j=0;
    while (i++<size) {
    raw_image24[j++]=raw_image32[i++];
    cinfo.err = jpeg_std_error( &jerr ); // From this line and on I get errors when trying to compile and use in flash / flex, etc.
    jpeg_create_compress(&cinfo);
    jpeg_bytearray_dest(&cinfo, array);
    /* Setting the parameters of the output file here */
    cinfo.image_width = width;
    cinfo.image_height = height;
    cinfo.input_components = bytes_per_pixel;
    cinfo.in_color_space = color_space;
    /* default compression parameters, we shouldn't be worried about these */
    jpeg_set_defaults( &cinfo );
    /* Now do the compression .. */
    jpeg_start_compress( &cinfo, TRUE );
    /* like reading a file, this time write one row at a time */
    while( cinfo.next_scanline < cinfo.image_height )
    row_pointer[0] = &raw_image24[ cinfo.next_scanline * cinfo.image_width * cinfo.input_components];
    jpeg_write_scanlines( &cinfo, row_pointer, 1 );
    /* clean up after we're done compressing */
    jpeg_finish_compress( &cinfo );
    jpeg_destroy_compress( &cinfo );
    free(raw_image32);
    free(raw_image24);
    return array;
    In the function write_jpeg_file is all the functionality that will be used later on in flash / flex through the .SWC file.
    Now when I try to compile this .gg file with gluegen and then through gcc, to make a NEW as3_jpeg_wrapper.swc that should be just like MetalBot original .SWC file. I do not seem to get any error compiling, BUT at the moment I go into flash and replace the new SWC for the old and test the swf movie, it throws me an error,
    Undefined sym: _jpeg_std_error
    at <anonymous>()
    at <anonymous>()
    According to the Undefined sym: _jpeg_std_error, that would have to do with the line cinfo.err = jpeg_std_error( &jerr );
    I never changed a thing from this file and so that is the main issue I have. Without changing a thing, a project that was working properly, I just recompiled the SWC and it does not work anymore. I hope this makes everything clear.
    Community Member
    Mar 18, 2009 11:03 AM
    Sorry I sent the message twice.
    Community Member
    Mar 18, 2009 6:46 PM
    Take this Archive
    Try to compile your swc using files from the archive.
    Unfortunately I can not repeat the problem. I have everything compiled without any problems
    Community Member
    Mar 18, 2009 10:02 PM
    Is there a way you could walk me through the way you get to the end of it ( the whole process).
    (assuming we don't have the jpeg lib installed) Starting from the point where we download MetalBot's project and we start building from the as3_jpeg_wrapper.gg he has until we get the as3_jpeg_wrapper.swc and we go inside flash / flex and try it with the JpegTest.as
    Thank you
    Community Member
    Apr 2, 2009 3:47 AM
    hello i need your help.
    I use ONLY Abode Flash CS4 (i haven`t any FlashDevelop, Adobe Flex SDK).
    I make flash uploader, and i need use as3_jpeg_wrapper.swc, but i can`t.
    my action:
    1) I add as3_jpeg_wrapper.swc to "C:\Program Files\Adobe\Adobe Flash CS4\Common\Configuration\ActionScript 3.0\libs"
    2) download This file is <a href=" http://flexlife.googlegroups.com/web/jpeg_enc.zip?hl=ru">a project of Metalbot </a>
    3) i Create empty fla
    4) add JpegTest class to empty fla
    5) run and i have error: ReferenceError: Error #1065: varaible DocJpgEncoder isn`t defenition
    Tell me please what can i do to imrove this situation ?
    Community Member
    May 5, 2009 8:46 AM
    Hello,
    I have test the library for record some Jpeg file.
    It's very fast, but i have a problem, how can I modify the source for add a new variable for change the compression ( Number between 0 to 100 )
    Do you have any idea, because in the actual state, it's impossible to work with this code...
    Thanks a lot for your help.
    -Geo
    Community Member
    Jun 21, 2009 9:39 AM
    @Geo: Check this blog post: http://www.websector.de/blog/2009/06/21/speed-up-jpeg-encoding-using-a lchemy/
    There you will find a modification of metalbots example for changing the quality of a compression.
    -Jens
1 2 Previous Next
Actions
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
