DataServiceTransaction
Avatar
Former Community Member
I'm running lcds on Jboss.
I'm trying to add an object on the server and push it to the client using the DataServiceTransaction class.
I do so by writing these lines:
DataServiceTransaction dataTrans = DataServiceTransaction.begin(false);
dataTrans.createItem(destinatin name, createItem);
dataTrans.commit();
but when running, i get the follow exception on the first line:
Unable to locate a MessageBroker initialized with server id 'null'
does anyone know how can i solve it??
thanks,
Liat
Avatar
Level 2
We you able to resolve this issue?
I am trying to update Data on client side from Server side using DataServiceTransectionClass. These updates are triggered at regular interval using EJB Timer API on JBoss App Server
I am facing similar issue following is stack trace
javax.ejb.EJBException: flex.data.DataServiceException: Unable to locate a MessageBroker initialized with server id 'null'
    at org.jboss.ejb3.tx.Ejb3TxPolicy.handleExceptionInOurTx(Ejb3TxPolicy.java:77)
    at org.jboss.aspects.tx.TxPolicy.invokeInOurTx(TxPolicy.java:83)
    at org.jboss.aspects.tx.TxInterceptor$Required.invoke(TxInterceptor.java:190)
    at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
    at org.jboss.aspects.tx.TxPropagationInterceptor.invoke(TxPropagationInterceptor.java:76)
    at org.jboss.ejb3.tx.NullInterceptor.invoke(NullInterceptor.java:42)
    at org.jboss.ejb3.security.Ejb3AuthenticationInterceptorv2.invoke(Ejb3AuthenticationInterceptorv2.java:80)
    at org.jboss.ejb3.ENCPropagationInterceptor.invoke(ENCPropagationInterceptor.java:41)
    at org.jboss.ejb3.asynchronous.AsynchronousInterceptor.invoke(AsynchronousInterceptor.java:106)
    at org.jboss.ejb3.BlockContainerShutdownInterceptor.invoke(BlockContainerShutdownInterceptor.java:67)
    at org.jboss.aspects.currentinvocation.CurrentInvocationInterceptor.invoke(CurrentInvocationInterceptor.java:67)
    at org.jboss.ejb3.stateless.StatelessContainer.callTimeout(StatelessContainer.java:304)
    at org.jboss.ejb.txtimer.TimerImpl$TimerTaskImpl.run(TimerImpl.java:561)
    at java.util.TimerThread.mainLoop(Timer.java:512)
    at java.util.TimerThread.run(Timer.java:462)
Caused by: flex.data.DataServiceException: Unable to locate a MessageBroker initialized with server id 'null'
    at flex.data.DataServiceTransaction.begin(DataServiceTransaction.java:267)
    at flex.data.DataServiceTransaction.begin(DataServiceTransaction.java:293)
    at org.divy.scheduler.QueryScheduler.runQuery(QueryScheduler.java:58)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
    at java.lang.reflect.Method.invoke(Method.java:597)
    at org.jboss.aop.joinpoint.MethodInvocation.invokeTarget(MethodInvocation.java:122)
    at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:111)
    at org.jboss.ejb3.EJBContainerInvocationWrapper.invokeNext(EJBContainerInvocationWrapper.java:69)
    at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.invoke(InterceptorSequencer.java:73)
    at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.aroundInvoke(InterceptorSequencer.java:59)
    at org.jboss.aop.advice.PerJoinpointAdvice.invoke(PerJoinpointAdvice.java:174)
    at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.fillMethod(InvocationContextInterceptor.java:72)
    at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_fillMethod_17490623.invoke(InvocationContextInterceptor_z_fillMethod_17490623.java)
    at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.setup(InvocationContextInterceptor.java:88)
    at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_setup_17490623.invoke(InvocationContextInterceptor_z_setup_17490623.java)
    at org.jboss.ejb3.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInterceptor.java:62)
    at org.jboss.ejb3.entity.TransactionScopedEntityManagerInterceptor.invoke(TransactionScopedEntityManagerInterceptor.java:56)
    at org.jboss.ejb3.AllowedOperationsInterceptor.invoke(AllowedOperationsInterceptor.java:47)
    at org.jboss.ejb3.stateless.StatelessInstanceInterceptor.invoke(StatelessInstanceInterceptor.java:68)
    at org.jboss.aspects.tx.TxPolicy.invokeInOurTx(TxPolicy.java:79)
Avatar
Level 1
Hi DJ,     I think you have to install and configure JOTM first, see  http://www.nabble.com/LCDS---Tomcat---JOTM-Integration-td18761900.html     Cheers!     Martin Zach
Avatar
Level 1
Hi Liat,
Cheers!
Martin Zach
