I'm trying to create a DVD of some screen capture footage using Camstudio and/or Camtasia, import to Premiere Pro CS3 and burn to DVD, but the end result is always horrible - text is unreadable, graphics blurred and choppy. I'm capturing at 1024x768. I've searched high and low, but nothing I've read is working. Here's what I've tried:
I'm exporting using the MPEG2-DVD setting in Premiere.
The footage directly from Camstudio and Camtasia looks fantastic. It's after it's brought into Premiere that the quality suffers.
I'm merely a hobbyist, so I hope everything I've written down makes sense.
Well, there are some facts to consider here:
So, if it can't be too soft and it can't be too sharp… make it larger. Here's what I do:
Preparing the Captures:
Cropping, Scaling and Filtering the Captures in After Effects
Editing in Premiere Pro
So, the "establishing shot" will show them the entire screen. Small text will not bet legible, but it will give them a good idea of how things the screen is laid-out. The "medium shot" will let them see text fairly well – and it allows them enough space to see how the "focused" text relates to other elements. Finally, the "close up" will give them the best view of individual menu items and buttons; showing how things highlight when clicked, etc.
Dan,
Nice article! I'm definitely going to be linking to this thread a lot. Now, that does mean that it is likely to become active, beyond what the OP needs, so keep your eyes out.
I read your step-by-step with great interest, as I have been looking at Camtasia, and most of my research on editing the Techsmith material has not been all that favorable. Personally, I want to say, "THANKS!"
Your input is always appreciated and of great value.
Hunt
Thank you for the advise, I've been trying to figure out how to make videos from Camtasia play in Premiere Elements. However I do not see any of the options you mention in step 3 above. Am I doing something wrong?
Great, thank you!
I got through that part, but as for After Effects, I cannot get a trial because it says I need 64-bit, and I guess I have 32. Is there a way to do it without After Effects, or should I purchase it? I wanted to make sure it worked before buying it, but if there isn't a way to do that, it may be my only option.
