I was wondering if it is possible to make a text box (or any kind of box) expand as you type into it. Currently the box does not have a caption, I simply want to allow the value box to expand as i type into it. It would also be great if it would expand to another page...does anyone know if this is possible and if so how can i do it?
Total Likes
There is one way how you can reach what you want.
First set your TextField Allow Multiple Lines
Second, at the Layout tab set Expand to fit(heigth ar width)
After you will insert text to TextFiled it will be expanded.
Example attached.
BR,
Paul Butenko
Total Likes
The box will not expand until you exit the field. While you are in the field typing ...scroll bars will appear.
Paul
Total Likes
The box is not expanding, when i am done typing there is a "+" sign in the lower right of the box. I tried all that you said before i origonally posted and got the same result...any ideas why this is not working? I could not open your attachment as well.
Total Likes
The form must be saved as dynamic as well and the root subform must be flowed for expansion to occur.
Paul
Total Likes
can you please explain to me how to do both of those. I am a newbie and apologize for that.
Total Likes
It woudl be easier for me to show you on your form ...can you post your form and I will tell you what I changed.
Paul
Total Likes
Here is the form. I would really like this to also go into the next page if needed as well. I also need to be able to see what i am typing as i am typing it.
Thanks for anything you can do for me...please try to explain how you do what you do so i can try and learn myself. I think that i was able to add a subform and ticked it to "flowed" properly.
Total Likes
I have a question along these lines also. I have been able to get my text box to expand but then it overlaps the section below it. Is there some code I can use for the subform to get the next subform to move as the text field it expanding?
Total Likes
you subforms shoud be flowed. If you will post your form i'll check it.
BR,
Paul Butenko
Total Likes
Here it is... and thanks!
Total Likes
I made your flowedText subform flowable and now it working fine.
See attach.
BR,
Paul Butenko
Total Likes
Well if it's not in designer itself, I wouldn't even think about programming this as each and every font has different widths and sizes. Meaning if you want to expand it correctly you'll need to know about everything about the fonts in the first place and well you know as well as I do ... it's a crazy man's job.
Total Likes
Pguerett,
Were you able to figure out where i went wrong?
Total Likes
Hi Wrenm, I took a quick look and fixed things up for you.
I setup and named some subforms:
I think that should get you started!
Oh, and saved the form type as "Adobe Dynamic XML Form".
Total Likes
Juno,
Thanks, although i have not been able to review your changes because the document is still queued. I do have one question though, how do i save as adobe dynamic xml form???
Total Likes
File->Save As -- the "Save as type" dropdown is where you pick the file type.
As the file is still queued here's a link to download it:
https://share.acrobat.com/adc/document.do?docid=6dc5417d-fe5e-4809-926a-90633089b270
Total Likes
i am getting an error message when i click on the dl button.
Total Likes
Weird, don't know what's up with that -- acrobat.com seems to be having trouble.
Give me your email address and I'll send it to you.
Total Likes
THanks,
Total Likes
File sent.
Total Likes
