I cannot get updates 8.1.5 or 8.1.6 to install on my PC. I am running Windows XP Pro SP3, 2G Ram, Adobe Acrobat 8.1.4 (update 8.1.4 obviously installed just fine). The automatic update for version 8.1.5 will not complete; it ends with an error message that gives 3 choices of repeating the update, quitting and continuing later, or cancelling the update altogether. If I try to install 8.1.5 or 8.1.6 after downloading the updates from Adobe's web site, I get this error message: The installation source for this product is not available. Verify the source exists and that you can access it. I have run the Adobe "Repair Acrobat Installation" from the help menu and rebooted the PC, but that did not fix the problem.
I have the same problem. When I go to Add or Remove Programs in the Control Panel and click on Change/Remove for Adobe Acrobat 8.1.4 Standard, I get the message "The installation source for this product is not available. Verify that the source exists and that you can access it." It appears that either the source for my last update, 8.1.4, is missing or that somehow my registry lost track of it. The machine has been stable for many years and I have a fair amount of skill for taking care of computer operating systems. Does anyone know where the "installation source for this product" should be located? I would like to look there and see if that is the problem or if there is another cause. Any ideas on what is going on and how my machine ended up being messed up? I would like to avoid this in the future.
I don't even see how to uninstall it. It appears that the machine has some idea that it was once installed but nothing more. It looks like the thing to do is unregister it, and then try and install it again. I don't have the disks handy so I will have to try doing so another day.
Thanks, Michael
Okay, to everyone who's got the issue of this error message: "The installation source for this product is not available. Verify that the source exists and that you can access it."
This is what worked for me to re-install my Adobe 8 Standard and get updates all the way through Ver. 8.1.6. (I think you should forget about finding the "Source" because I think that is really a red herring and you'll end up spending way more time screwing around compared to simply following these steps.) Also, while the following steps are time consuming, I just don't believe that there is any other way to fix whatever when wrong with any thing in Adobe Acrobat. Consequently, the process does take time, but it works completely.
First, you have to get the Windows Installer Cleanup Utility at this site: http://support.microsoft.com/kb/290301. Then download the Installer Cleanup Utility and run it. You should get a window which lists all of the programs for which the Windows Installer can be removed. DON'T REMOVE ANY PROGRAM LISTED EXCEPT ADOBE ACROBAT 8 OR YOUR VERSION OF ADOBE ACROBAT. (Also, make sure you have temporarily disabled your antivirus and anti-spam,anti-spyware, etc. programs.)
Second, you will not be able to use Add/Remove programs for Adobe 8 but that didn't matter for me because now that you've useed the Windows Installer Cleanup Utility for Adobe 8, you should be able to install Adobe 8 completely fresh or new just as you did the first time. For me, I just ran my Adobe 8 CD on one PC and ran my other Adobe 8 program download on my other PC (I bought two programs of Adobe 8) and after the programs installed new or fresh, I then proceeded with getting all updates through Ver. 8.1.6. Everything worked just beautifully.
You should note that the Windows Installer Cleanup Utility apparently makes it possible to reinstall a previously installed program because it apparently removes certain program components that would otherwise indicate that the program is already installed. In short, the Utility removes whatever software items are used to keep you from re-installing. Also, when you run the Utility, it effectively renders the Add/Remove Programs function useless for your Adobe program because it no longer recognizes the Adobe program as being installed.
Finally, while I did not need to upgrade to Adobe 9, I believe that if you are having the same error message when you are trying to uninstall Adobe 8 to install Adobe 9, the above-stated process will work just as well for you and you should then be able to make a clean install of your Adobe 9 program.
If you go through the above-stated process and you're successful, please post to the forum so others know that it is certifiably correct. If you go through it and it does not work for you, please post your comments about what went wrong or what did not work, making sure that all of us know which version of Adobe Acrobat you were working with.
Good luck!!
"For source missing or Source not found", use the installation CD/DVD that you got while purchasing Acrobat or if you downloaded it from the website then i am sure u'll be having the backup. So eiher of the two should help you in solving the problem
When the uninstaller asks for the source either point it to the CD?DVD or to the downloaded location of the Acrobat and continue with the process.
jleesq's solution above (it is his, not mine) worked for me too. I had to call Adobe to get help with reactivation. The support person told me that sometimes the registration gets locked up and that I had probably not done anything wrong.
While reinstalling, I noticed the option to keep 300+ Mbytes of installation files cached on my disk to aid in upgrades and such. I suspect I originally had done this and wonder if I deleted them a while back and if that is what messed things up. Just a guess. I still would like to understand what went wrong so I don't do it again.
Thanks big time to jleesq for posting great directions on how fix the problem. I did not read the "download the Installer Cleanup Utility and run it" and understand that I needed to "install it" and then run "Windows Install Clean Up" from the Windows/Start/All_Programs menu. Once I figured this out, things went smoothly.
Michael
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
