I get the following error message when I try to load the CF Admin Page.
The following information is meant for the website developer for debugging purposes. | ||||||||||||||||||
Error Occurred While Processing Request | ||||||||||||||||||
waiting for Help..
Naveen
This usually means that the CF Administrator version is not in sync
with the CF version. Maybe you upgraded ColdFusion and the CFIDE
directory was not upgraded or it points to an older CFIDE version ?
Mack
Hello Mark,
thanks for the reply...
It's not an upgradation of the CF but a fresh installation that is causing this error after 48 hours.
And this is the second time, the re-installation is done.
Can you please advice what would be the solution ?
Naveen
Does it happen consistently after 2 days ? Are there any operating
system scheduled tasks might restore a previous version of CFIDE ?
Mack
No there is no scheduled task running...
We had re-installed CF and this error came up after a couple of days of the re-instalation...
Not only for the adinistrator, but the same error just poped up for one of the Users created...
Naveen
The web site you are accessing has experienced an unexpected error.
Please contact the website administrator.
Please, I have gotten this error message since last Wednesday. I even asked my teacher -- we can not understand.
I have uninstalled all versions of CF BEFORE I downloaded and installed CF 9.
But I can not get the administrator to work -- I have NEVER had a problem like this before.
Please, I really need to fix this problem. My school project is due in less than five days.
I REALLY DO NEED SOME HELP.
SHOULD I UNINSTALL CF 9 AND GO BACK TO AN EALIER VERSION?
THANKS
Wrong path/filename for the admin page. Correct is /cfide/administrator/index.cfm or just /cfide/administrator
-reed
he's right, i know how to solve your problem, here is my email
walterjone96@gmail.com
I am experiencing the same problem and I am going to be seriously boned unless I can get CF9 on my laptop.
I have had no problems with the other versions. I completely uninstalled them from my computer and even checked to make sure they were deleted.
I tried to download CF 9 on my laptop and I did get the download and installation.
THE REAL PROBLEM IS THAT I CAN NOT GET THE ADMINISTRATOR TO WORK.
PLEASE, PLEASE, PLEASE, does anyone have any clue? I have been working on this same problem since last Wednesday (four days now -- almost 20 hours per day).
I really need to get this problem solved.
PLEASE..... ANY HELP?
THANKS
Check the ColdFusion Installation Logs. See if there where any important errors from the installation.
Check the web server configuration. Make sure there is a propper connection between the web server and ColdFusion.
n
The error message makes me think that there is not a CFIDE virtual directory created in your web server.
P.S. what web server are you using anyway? There is an issue with a defaut IIS7 configuration that comes on new Windows machines. One has to install optional IIS6 compatibiity components to the web server for ColdFusion to work.
What does this - "I CAN NOT GET THE ADMINISTRATOR TO WORK" - mean? In what way does it not work? Do you get an error message? As someone else asked, did anything get reported in the logs? What web server are you using? What *OS* are you using? How do you imagine anyone could help you based only on the info you've provided (which is basically none).
Have you read the "before you post" guidance? http://forums.adobe.com/thread/607238
Adam
I know it's too late for this, but for others ...
I'm still using Coldfusion MX7
See if the file component.cfc is in the wwwroot/web-inf/cftags/ directory of your Coldfusion installation. It is zero bytes - they can sometimes get removed by system cleaners. If it's not there, just create a file with that name in notepad or something - with nothing in it, just save it as a filename in the specified directory.
This was driving me crazy!
