Can Reader users Save Form and Preserve data?
Jan 8, 2009 8:53 AM
I designed a form with Livecycle Designer and sent it to a few people who have Reader only. They are able to fill in the form but when they try to save it they get a message stating: "Data typed into this form will not be saved. Adobe Reader can only save a blank copy of this form."
This product seems absolutely useless if users cannot save their forms. I have to believe I've made a mistake or placed some restrictions on the form that is forcing this error. I've read in other posts that people are indeed sending forms to customers to fill out and email back. So saving from Reader must be possible right?
Can anyone tell me what I've done wrong? Thanks.
    Jan 8, 2009 10:52 AM   in reply to (James_Houghtaling)
    You have to have Adobe Livecycle Reader Extensions. It is additional software from adobe that you purchase and install, it gives you the ability to enable a form filler to save the form data as entered.
    Jan 8, 2009 10:55 AM   in reply to (James_Houghtaling)
    let me specify a bit more, it is software you buy and install on a machine, then you use the web interface of the software to enable features for your form. then when you distribute it to users they will have the ability to save the form with the data they entered. Hope that helps you.
    Jan 8, 2009 11:19 AM   in reply to (James_Houghtaling)
    You are correct. I have not tried that method nor read much about but i do now recall reading about the feature being available through acrobat pro somehow. I am not sure if it will work for reader users? Im not sure also which book i have that discussed that option, it might be the book by j.p. Terry - creating dynamic form with adobe livecycle designer
    Jan 9, 2009 4:19 AM   in reply to (James_Houghtaling)
    I have same issue, very frustrating. This product eludes it can provide such easy functionality but its does not
    Jan 9, 2009 5:52 AM   in reply to (James_Houghtaling)
    Reader does not allow a local save by default. You can Reader Extend the form to allow (just that form) to be saved. This can be done in two ways.
    1. You can Reader Extend the form in Acrobat
    2. You can apply the Reader Extensions right sin LiveCycle Reader Extensions Server.
    Feb 9, 2009 7:25 AM   in reply to (James_Houghtaling)
    Thank you James Houghtaling!
    Feb 16, 2009 12:55 PM   in reply to (James_Houghtaling)
    Hi... you can create a pdf form with live cycle as in acrobat professional and then allow users to fill in and save a copy of the form in reader... you do not need reader extensions to do this.
    what you must do is open the form in professional and then click on the "advanced" menu and select "enable user rights in adobe reader" from the list. a window will ask for your ok to save the form... when you click " Save Now" you will have the option of renaming the pdf or leaving it the same. WHen the saved form is opened in reader 8 or above... the user will be able to fill in the form, and save the form and print it with the data they entered intact.
    Feb 18, 2009 8:34 AM   in reply to (James_Houghtaling)
    In CS4 the menu item is:
    Advanced>> Extend Features in Adobe Reader
    Feb 27, 2009 12:13 PM   in reply to (James_Houghtaling)
    I used acrobat pro to enalbe user rights in reader. But when I then open the form via my web application it says:
    "This ducument enabled extended features in Adobe Reader. The document has been changed since it was created and use of extended features is no longer available. Please contact the author for the original version of this document."
    I'm confused. More than I used to be.
    Jun 25, 2009 9:21 AM   in reply to (James_Houghtaling)
    I would add that one cannot be in field-editing mode to enable the extended features....
    Jun 30, 2009 6:44 AM   in reply to (Tony_J_White)
    I am having the same issue as Tony.  I have enabled the usage rights using Adobe Acrobat Professional.  The users are able to fill out the form and save a copy.  However, after a few times of adding/editing data and saving the following message appears and does not allow the user to continue editing the form:
    Jun 30, 2009 6:59 AM   in reply to KTost
    I came across this error before, under the following conditions:
    1. The form was Reader Enabled using Acrobat Professional on one computer (with the correct date and time);
    2. When the same form was subsequently opened on a second computer (with an incorrect date and time), the error occurred as the form opened.
    My conclusions at the time were that if you are opening a Reader Enabled form on a computer which has the date/time set to a date that is earlier than the enabled date/time, then Acrobat throws the error.
    For example,
    Form enabled on first computer on 30/06/2009 at 2:13pm; but then opened on the second computer who's clock is set to 28/06/2009 at 10:34am, then Acrobat gets confused.
    I found that once the second computer's clock goes past the enabled date/time then the form opens no problem.
    Best solution is to have all computers working off the same (correct) time.
    Hope that helps,
    N.
    Jun 30, 2009 7:03 AM   in reply to Niall O\'Donovan
    Thanks for your quick response.  Both the computer the form was originated/enabled on and the user's computer have the exact same date and time.  Our computers are synchronized using a central server.  Any other suggestions?
    Jun 30, 2009 7:22 AM   in reply to KTost
    No, sorry!!
    I was just checking back through records and I came across it last March. Correcting the clocks resolved the problem straight away. I had not come across this error before that or since.
    Might be worth a try taking your form outside of your network and test it on a standalone PC.
    Good luck,
    N.
    Jun 17, 2011 5:05 AM   in reply to Niall O\'Donovan
    Wow.
    Here's my simplistic summary.
    I have been using LCD for about 18 months and I NEVER had this problem.
    Now with Adobe X, it is a constant bother.
    Yes, there are various ways to cope with it, but before Adobe X, my Saveas and Send buttons always worked in Preview PDF mode...long before I applied the Advanced permissions to the final PDF.
    So...something has changed. Adobe has done something wrong/differently in Adobe X and failed to explain it.
    But thanks for all the posts. At least I know I can live with this problem. (And that it's not just me.)
    Mar 5, 2013 2:59 PM   in reply to (James_Houghtaling)
    For those who are using Adobe Acrobat X, the procedure has completely changed from what you may know from earlier versions of Adobe Acrobat Pro. This web page has information on the new way to handle usage rights: http://help.adobe.com/en_US/acrobat/X/pro/using/WS58a04a822e3e50102bd6 15109794195ff-7e0d.w.html
    Mar 6, 2013 7:02 AM   in reply to jjohnsonace
    If you have both Reader and Pro on the same machine, it will cause problems.
    James Houghtaling, is there any reason you could not have looked at Paul's response, decided you don't have Reader Extension server, don't want to buy it and asked "How do I Reader Extend the form in Acrobat?".
    Mar 6, 2013 7:53 AM   in reply to Steve Bishop
    You need to open the pdf in Acrobat X and save a copy like I show in this image:
