Why does WinXP think all OpenType files are corrupted?
Jun 30, 2009 10:45 AM
I'm trying to install an OpenType font in WinXP (Inconsolata).  When I select the file in the font installation dialog, it just says "Unable to install the ... font. The font file may be damaged. Check with your vendor about obtaining a new file."  I'm getting the .otf file from http://www.levien.com/type/myfonts/inconsolata.html. I've also tried http://moorstation.org/typoasis/designers/steffmann/samples/a/albert.h tm with the same result. I've tried downloading the file (from Firefox) several times.
    Jun 30, 2009 10:53 AM   in reply to david.karr
    I just tried downloading and installing the font you refer to in Windows Vista (pretty much same font handling mechanism as XP) without any problem whatsoever.
    Do you have problems with all OpenType OTF fonts as your post's title implies or just this font?
              - Dov
    Jun 30, 2009 11:23 AM   in reply to david.karr
    Wise guy, we are trying to assist you!
    The question was whether all OpenType OTF fonts have installation problems on this system, not whether you tried to install all fonts ... geez!
    The question pertains to whether you have somehow broken your XP system's ability to deal with both Type 1 and OpenType CFF fonts. This can easily occur if you either (1) install a very old copy of Adobe Type Manager or (2) install the most recent version of the Adobe Type Manager and then uninstall it without applying a certain patch file to restore support for Type 1 and OpenType CFF files.
              - Dov
    Jun 30, 2009 11:48 AM   in reply to david.karr
    "Have you ever tried to install ALL available fonts?"
    When debugging font issues, yes.
    Jun 30, 2009 11:49 AM   in reply to david.karr
    Let me ask another way: have you installed any other opentype fonts that worked?  Is it just those 2 that fail, or does every opentype font you attempt to install fail the same way?
    Jun 30, 2009 12:33 PM   in reply to david.karr
    david.karr wrote:
    This is a corporate-prepared laptop.
    Do you have write permission to the Windows Fonts folder? Users don't I think, by default. Second, if you right-click on the downloaded file and select Properties, is it blocked (at the bottom of the General tab)?
    I use OTF almost exclusively on my XPSP3 machine.
    Noel
    Jun 30, 2009 1:14 PM   in reply to david.karr
    It's a little hard to find a collection of free OpenType font downloads in a single place, but I found a couple more in various places, and they all fail with the same error.
    Heh. You'd be amazed at some of the type sites on the web. :-)
    But this means that all OpenType fonts you have attempted to install have failed.  That points to something not with the fonts, but with the system.
    Are you running with administrator privileges?
    Jun 30, 2009 9:49 PM   in reply to david.karr
    David,
    Check points 3 and 4 listed at http://www.thomasphinney.com/2008/12/no-font-instal/
    Jun 30, 2009 11:54 PM   in reply to Miguel Sousa
    I have the very same problem, with ATM installed or not in Windows XP machine since a long time ago.
    In the very last days I cannot use my OTF fonts, none of them, well exactly not anyone from Adobe, neither PS fonts, only TTF and MS OTF ones, I cannot preview them with ATM and cannot even copy them to the fonts folder in the Windows folder.
    I can only copy Adobe OTF to the font folders of Adobe applications, thus I suspect no font is corrupted. It is a problem with Windows XP or my installation.
    What I have changed lately?
    Oh, my new Geforce 9600GT!
    I think I will have to touch the Registry, thus thank you very much for pointing to this likely culprit, I will try T. Phinney solutions and let you know. Thank you.
    Jul 5, 2009 12:50 AM   in reply to david.karr
    I had an entry in the registry for a lower (decimal) value and increased it up the recommended value, but no success, finally I have had to remove the  /3GB switch in the boot ini file and I have got it.
    I would like to find a different or better solution as I am back limited to only using 2GB of RAM in WinXP.
