Is there a registry setting I tweek to uncheck the box for Display PDF In Browser? The only ones I could find grayed out the box but it didn't un check the box.
Unfortunately this is for every user.
HKCU\Software\Adobe\Adobe Acrobat\9.0\Originals\bBrowserIntegration should be 0 (DWORD) for unchecked. 1 for checked, or just delete bBrowserIntegration.
Although not test, but for new users, you can have it defaulted to unchecked by creating this registry key:
HKLM\Software\Adobe\Adobe Acrobat\9.0\Installer\Migrate\_8F96F27E-4B57-411A-A268-632AF06C6929
(Default) REG_SZ Software\Adobe\Adobe Acrobat\9.0\Originals
name REG_SZ bBrowserIntegration
type REG_DWORD 4
val REG_SZ 0
I'm just confirming what anhnguyen7902 posted.
This was tested against Acrobat Reader 9.3.1. I exported all of the registry keys from HKEY_CURRENT_USER\Software\Adobe\ with the "Display PDF in browser" setting enabled and disabled. Below are the only relevant differences when changing this setting from within Acrobat Reader.
With the setting enabled, keys under [HKEY_CURRENT_USER\Software\Adobe\Acrobat Reader\9.0\Originals] are...
"bHostBasedCM"=dword:00000001
"iPSLevel"=dword:00000000
"sProofingSpace"=hex:55,2e,53,2e,20,57,65,62,20,43,6f,61,74,65,64,20,28,53,57,4f,50,29,20,76,32,00
"bDisplayedSplash"=dword:00000001
With this setting DISABLED, keys under [HKEY_CURRENT_USER\Software\Adobe\Acrobat Reader\9.0\Originals] are...
"bBrowserIntegration"=dword:00000000
The difference being the bBrowserIntegration key being present and set to dword:00000000 when this option is DISABLED, but the key being completely removed when the setting is ENABLED.
While writing this post, I decided to test it against Acrobat Reader v4.2.1. The results were the same.
Hope this helps.
