I'm trying to install an OpenType font in WinXP (Inconsolata). When I select the file in the font installation dialog, it just says "Unable to install the ... font. The font file may be damaged. Check with your vendor about obtaining a new file." I'm getting the .otf file from http://www.levien.com/type/myfonts/inconsolata.html. I've also tried http://moorstation.org/typoasis/designers/steffmann/samples/a/albert.h tm with the same result. I've tried downloading the file (from Firefox) several times.
Wise guy, we are trying to assist you!
The question was whether all OpenType OTF fonts have installation problems on this system, not whether you tried to install all fonts ... geez!
The question pertains to whether you have somehow broken your XP system's ability to deal with both Type 1 and OpenType CFF fonts. This can easily occur if you either (1) install a very old copy of Adobe Type Manager or (2) install the most recent version of the Adobe Type Manager and then uninstall it without applying a certain patch file to restore support for Type 1 and OpenType CFF files.
- Dov
david.karr wrote: This is a corporate-prepared laptop.
Do you have write permission to the Windows Fonts folder? Users don't I think, by default. Second, if you right-click on the downloaded file and select Properties, is it blocked (at the bottom of the General tab)?
I use OTF almost exclusively on my XPSP3 machine.
Noel
It's a little hard to find a collection of free OpenType font downloads in a single place, but I found a couple more in various places, and they all fail with the same error.
Heh. You'd be amazed at some of the type sites on the web. :-)
But this means that all OpenType fonts you have attempted to install have failed. That points to something not with the fonts, but with the system.
Are you running with administrator privileges?
Oh, I was able to find lots of font/type sites, I just had trouble finding a single place with just free OpenType fonts, and not lots of other stuff.
I do have admin privileges, yes. I verified that I can create a file in that directory.
I have the very same problem, with ATM installed or not in Windows XP machine since a long time ago.
In the very last days I cannot use my OTF fonts, none of them, well exactly not anyone from Adobe, neither PS fonts, only TTF and MS OTF ones, I cannot preview them with ATM and cannot even copy them to the fonts folder in the Windows folder.
I can only copy Adobe OTF to the font folders of Adobe applications, thus I suspect no font is corrupted. It is a problem with Windows XP or my installation.
What I have changed lately?
Oh, my new Geforce 9600GT!
I think I will have to touch the Registry, thus thank you very much for pointing to this likely culprit, I will try T. Phinney solutions and let you know. Thank you.
I had an entry in the registry for a lower (decimal) value and increased it up the recommended value, but no success, finally I have had to remove the /3GB switch in the boot ini file and I have got it.
I would like to find a different or better solution as I am back limited to only using 2GB of RAM in WinXP.
