Feature request for LiveCycle Designer ES
May 21, 2009 11:05 AM
Please consider adding the ability to insert a caption to a radio button group, as well as the ability to insert/or not insert a caption for a checkbox group.  This function is available in Form Guide so I'm hoping it can be done for LD as well.
Currently if you add a text object (caption) above a group of radio buttons or checkboxes it throws off the tabbing order.  It is also a major design challenge to get the layout to mimic the other objects   AND if you are using a Positioned Content in your Subform this setup cannot be done at all.
I've attached a sample pdf so you can see the layout I'm describing.
Thanks for your consideration.
    Jul 6, 2009 7:58 AM   in reply to SciMax
    I second this request.  It's inelegant (to say the least) to have to use a text box to make a caption for a radio button group.  It seems like a common situation to want to have something like "Do you have any pets?" as the radio button group caption and have the individual radio buttons be captioned "Yes" and "No".
    Jul 6, 2009 1:27 PM   in reply to SciMax
    I haven't had any trouble using flowed content with my textbox workaround for a radio button group caption.  If you're having problems, you could try wrapping the textbox and the radio button group in their own subform.  You could make that subform positioned if you needed to and the rest of the form could be flowed.
