Pedro Varela
The chosen operation is not currently available
Jul 2, 2009 10:00 AM
Hi all, I installed BluePrint, I'm usin Eclipse 3.2 and Flex Builder 3.0.2 Update.. When I press Alt+B it  a popUp says The chosen operation is not currently available, and when I open the BluePrint View appears this error..
java.lang.ClassNotFoundException: com.adobe.flexbuilder.blueprint.views.BlueprintExplorationView
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(Bundl eLoader.java:402)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(Bundl eLoader.java:347)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(De faultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(Unknown Source)
at org.eclipse.osgi.framework.internal.core.BundleLoader.loadClass(Bundl eLoader.java:278)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleH ost.java:227)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(Abs tractBundle.java:1245)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createEx ecutableExtension(RegistryStrategyOSGI.java:147)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutable Extension(ExtensionRegistry.java:759)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecuta bleExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createE xecutableExtension(ConfigurationElementHandle.java:51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:24 2)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:67)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlug in.java:238)
at org.eclipse.ui.internal.registry.ViewDescriptor.createView(ViewDescri ptor.java:69)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference. java:292)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:1 97)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartR eference.java:566)
at org.eclipse.ui.internal.Perspective.showView(Perspective.java:1675)
at org.eclipse.ui.internal.WorkbenchPage.busyShowView(WorkbenchPage.java :987)
at org.eclipse.ui.internal.WorkbenchPage.access$13(WorkbenchPage.java:96 8)
at org.eclipse.ui.internal.WorkbenchPage$13.run(WorkbenchPage.java:3514)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:351 1)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:348 7)
at org.eclipse.ui.internal.ShowViewAction.run(ShowViewAction.java:76)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection (ActionContributionItem.java:539)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContri butionItem.java:488)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionC ontributionItem.java:400)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:1930)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1894)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.jav a:422)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplication.java:95 )
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformAct ivator.java:78)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runAppli cation(EclipseAppLauncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ec lipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.ja va:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.ja va:177)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Have any idea??
    Jul 6, 2009 1:04 PM   in reply to Pedro Varela
    Hi Pedro,
    Thanks for trying out Blueprint! What OS version are you using?
    Mira Dontcheva
    Research Scientist
    Adobe Systems
    Jul 17, 2009 1:31 PM   in reply to Pedro Varela
    Hi Pedro,
    Sorry for your trouble. I have filed a bug, and we'll try to fix this problem in the next release.
    Mira
