i try the Adoby Sample: Quick Start: Applying usage rights using the web service API for WSE Services
http://livedocs.adobe.com/livecycle/8.2/programLC/programmer/help/0001 25.html#1548411
Everytime i start the servie i get message: ALC-RES-001-002: No credential found with alias [administrator]. When i try sample to generate 3D-PDF, all works right. But by the Extensions the same credentialAlias does not work. I'm using the AdobyLiveCycle ES 8.2 Update1 as Trail version with AdobyAcrobat 9.1 and have all installed with JBoss on a Windows 2003 Server like deklared in InstallTurnkey from adoby.
What can i do? Here a part of the code:
ReaderExtensionsServiceServiceWse readerExClient = new ReaderExtensionsServiceServiceWse();
readerExClient.Credentials = new System.Net.NetworkCredential(USER_ID, PASSWORD);
//Specify the PDF document
string path = OUTPUT_PDF_PATH;
FileStream fs = new FileStream(path, FileMode.Open);
//Get the length of the file stream
int len = (int)fs.Length;
byte[] ByteArray=new byte[len];
//Populate the byte array with the contents of the FileStream object
fs.Read(ByteArray, 0, len);
inDoc.binaryData = ByteArray;
//Create a UsageRight object and specify usage rights
UsageRights useRight = new UsageRights();
useRight.enabledComments = true;
useRight.enabledFormFillIn = true;
useRight.enabledDigitalSignatures = true;
useRight.enabledDynamicFormFields = true;
//Create a ReaderExtensionsOptions object
ReaderExtensionsOptionSpec reOptions = new ReaderExtensionsOptionSpec();
reOptions.usageRights = useRight;
reOptions.message = "This is a Rights-Enabled PDF Document";
//Apply usage rights to a PDF document
ReaderExtensionsService.BLOB outDoc = readerExClient.applyUsageRights(
inDoc,
USER_ID,
PASSWORD,
reOptions);
The full errormessage is:
An unexpected exception was encountered: com.adobe.livecycle.readerextensions.cl
ient.exceptions.ReaderExtensionsException: ALC-RES-001-002: No credential found
at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(Soa pClie
ntMessage message, WebResponse response, Stream responseStream, Boolean asyncCal
l)
at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodN
ame, Object[] parameters)
at Pdfg3dWebServiceClient.ReaderExtensionsService.ReaderExtensionsServic eServ
iceWse.applyUsageRights(BLOB inPDFDoc, String credentialAlias, String credential
Password, ReaderExtensionsOptionSpec applyOptions) in C:\Adobe\LiveCycle8.2\Live
Cycle_ES_SDK\samples\PDF3dGenerator\DotNet\Pdfg3dWebServiceClient\Web References
\ReaderExtensionsService\Reference.cs:line 38
at Pdfg3dWebServiceClient.Pdfg3dClientWS.Main(String[] args) in c:\adobe\live
cycle8.2\livecycle_es_sdk\samples\pdf3dgenerator\dotnet\pdfg3dwebservi ceclient\p
dfg3dclientws.cs:line 183
If i uncomment line2: readerExClient.Credentials = new System.Net.NetworkCredential(USER_ID, PASSWORD); the errormessage says:
l)
And like sayed before with Generate 3D PDF Service API Quick Starts it works fine.
Thanks for all answers.
