SecurityError: fileWriteResource
Feb 26, 2009 1:24 PM
Hello all, I'm having a little difficulty reading, then writing to a XML file in the applicationDirectory. I can read from it fine, parse the results, close the stream. However, when it comes time to write to the file, I get this error thrown:
at runtime::SecurityManager$/checkPrivilegeForCaller()
at flash.filestream::FileStream/open()
... (the rest is my stuff)
    Feb 26, 2009 2:30 PM   in reply to Damon Edwards
    You should not write the application directory.
    -ted
    4. ,
    Mar 3, 2009 11:32 AM   in reply to Damon Edwards
    I am trying to do the same thing. I see now that is it read-only. However, when an AIR application is uninstalled the applicationStorageDirectory is not cleared or removed. I am trying to create a screen that thanks the user upon install, meaning when the app is uninstalled I would need to clear out the memory of it ever being installed. The applicationDirectory is removed, but it isn't writable. HMM, any suggestions guys?
    Jul 3, 2009 12:17 AM   in reply to Damon Edwards
    The solution is to use a line like
    myFile = new File(pathAsString);
    so use the File(path) constructor. Then you will be able to write files in the application directory. Solution found at http://exaflood.de/syrotech/air-securityerror-filewriteresource/.
    Aug 16, 2010 8:03 PM   in reply to Andreiut
    This does not seem to be working in AIR 2.  Can anyone else confirm this?
  • Chris Campbell
    May 4, 2010
    Aug 18, 2010 11:54 AM   in reply to losing
    Hi losing,
    Is it possible to get some sample code describing the problem you're running into?  What platforms are you having issues with?
    Moved discussion to the Problems and bugs forum.
    Chris
    Feb 21, 2011 3:55 AM   in reply to Andreiut
    Thanks.
    It works fine.
    Quim
    May 30, 2011 4:19 PM   in reply to tzeng
    Sep 6, 2011 3:48 AM   in reply to Damon Edwards
    Hi, this is how I solved/hacked the problem.
    var filePath:String = "app:/" + FileNames.DATA_COMMENTS_DIR + "/" + fileName;
    var appDirFile:File = new File(filePath);
    var xmlFile:File = new File(appDirFile.nativePath);
    var fileStream:FileStream = new FileStream();
    fileStream.open(xmlFile, FileMode.WRITE);
    fileStream.writeUTFBytes(newXMLStr);
    fileStream.close();
