ORM Code Generator not showing up
Jul 14, 2009 8:33 AM
Hi, if I right click on a table in the RDS Dataview the "ORM Code Generator", "ModelGlue Assistant" and "Generate AS Class from DB Table" are not showing up. Does anyone has a clou why not ?
I had a CF8 & CF9 installation on the machine yesterday and got some error messages while trying to use the ORM Code Generator. I thought the problem was running CF8 & CF9 on the same pc. I unistalled everything: CF8, CF9 and ColdFusion Builder to have a "Clean" Testing Enviroment. After installing just CF9 and Buider new the already named options are missing in the RDS Dataview.  Thanks for your help.
    Jul 14, 2009 9:14 AM   in reply to supamark
    Can you go to Preferences --> Extensions and check if the extensions are installed? Can you also check which server are they associated with? Is it same as the one you are using via RDS dataview?
    In case you dont find an extension installed, you can easily install them from the zip file that is in the <install_root>/extensions folder. If the extensions are already installed, you can import them from your existing server.
    Jul 14, 2009 10:20 PM   in reply to supamark
    can you switch off show debug output setting in CF9 server admin and try again?
    thanks,
    Sandeep
    Adobe ColdFusion team
    Jul 23, 2009 7:26 PM   in reply to supamark
