I created some new learning modules today (like normal) and now I cannot open any of them. I receive the following error message "An error was encountered while loading the image."
HELP! Has anyone else seen this? I am really stuck...
Many thanks.
Hi there,
Why don't try opening the back up file which captivae automatically creates for you. It is hidden by default. Here is how you can open the back up file:
- Go to control panel(Start>>Settings>>control panel)
- Double Click folder options
- In the folder options dialog switch to the view tab(2nd tab)
- Under the "Hidden files and folders" section select the "Show hidden files" radio button.
- Uncheck "Hide extensions for known file types"
- Press OK.
- Go to the location where you had saved your cp file. You will see a file with the same name having .cp.bak as extension
- Select the file and press F2.
- Now delete ".bak" from the file name.
- Try opening this cp file.
Good luck
