How can I convert .swf  file to exe file?
Apr 20, 2006 8:16 PM
thanks
    Apr 25, 2006 11:26 AM   in reply to Newsgroup_User
    You wouldn't convert a swf to an exe, unless you were creating a self-launching zip file, but that's a function of winZip and other compression apps, and all the exe will do is produce the swf file, it won't open it.
    Other than that route, if all you have is the swf file, somebody with more experience than me will have to comment if it's possible to convert a swf to an exe that launches the Flash object.
    Now, I think what you want to do is publish a Windows projector (exe) from the .fla file. If you have access to the .fla file, luckily it's very easy to do this.
    So when you open the project in Flash, go to the File menu, select Publish Settings, and now you can choose from all the different types of files you can publsh to. Select Windows Projector (exe) and deselect any that you don't want.
    Now click publish. Wherever it published to, you will find an exe file that you can open like any other app, and it will run the flash object.
    Apr 25, 2006 5:04 PM   in reply to Newsgroup_User
    to convert a swf to exe just open the swf alone then go to file > create projector this will create a standalone exe file that will run on virtualy any PC computer with or without the flash player
    Apr 26, 2006 7:16 PM   in reply to .:}x-=V!P=-x{:.
    quote:
    I stand corrected!
    Jun 28, 2011 6:41 PM   in reply to PepperKev
    Wow, thanks alot for that. It's really helpful. I'm actually new to Adobe flash and I'm having trouble exporting the .swf to a .exe with ALL the required files (some XML and .jpg files) in the .exe. Really appreciate it!
    Mar 7, 2012 12:59 PM   in reply to Newsgroup_User
    How can I convert an swf to jpg?
    May 1, 2012 12:27 PM   in reply to Newsgroup_User
    Try flajector or similar converter
    Jul 16, 2012 4:54 AM   in reply to Abbaty
    You can try bullrushsoft SWF to EXE Converter.
    It's a powerful and easy-to-use wizard-like tool that can add all files (some XML and .jpg files) in the ONE .exe.
    Please google "bullrushsoft" for more details.
    May 7, 2013 10:34 AM   in reply to Sandro_brs
    Good day! I'm looking for a way to convert SWF into executable. I've heard that I can convert in such a way that flash video will play without flash player installed. Is this true?
    May 8, 2013 7:12 AM   in reply to RobertMiles
    Hi, Robert. You I do not quite understand what exactly you are interested.
    You want to know which converter is able to do it or what technology is used? Can you clarify??
    May 10, 2013 8:55 AM   in reply to JohnDepth
    Actually I would like to know about the technology. How can I play the flash movie without flash player? What's the trick?
    May 13, 2013 4:31 AM   in reply to RobertMiles
    Look, if you want to know more about this technology, you can read the documentation of f-in-box, this is a library for flash. Select a section "Create flash-enabled applications..."
    I know that the flash player can be packed into an executable file
    May 14, 2013 4:21 AM   in reply to JohnDepth
    Thank you, John! I think I understood
