scasey1982
TypeError: Error #1009: Cannot access a property or method of a null object reference.
Jul 21, 2009 10:58 AM
I am having a problem with this error when I am trying to use a function for a button.  Everything works fine when I have it on frame 1, but when I add a preloader to frame 1 and put my content on frame two I recieve the #1009 error.
When I tested my code with just a simple function I still got the error.  the code is below, Any help would be greatly appreciated!
****Code for Preloader(Frame1)*******
stop();
loaderInfo.addEventListener(ProgressEvent.PROGRESS, updatePreloader);
function updatePreloader(evtObj:ProgressEvent):void
    var percent:Number = Math.floor((evtObj.bytesLoaded*100)/evtObj.bytesTotal);
    preloader_txt.text=percent+"%";
    if (percent>=100){
        nextFrame();
****Code for Main Content (Frame 2)****
stop();
//Import the necessary files for all of the tweening
import fl.transitions.Tween;
import fl.transitions.TweenEvent;
import fl.transitions.easing.*;
//Move all of the text off screen and set them invisible
featuresText_mc.alpha=0;
featuresText_mc.y=-500;
viewCottageText_mc.y=-500;
rateInfo_mc.alpha=0;
rateInfo_mc.y=-500;
viewCottageText_mc.alpha=0;
contactInfoText_mc.alpha=0;
viewCottage_btn.addEventListener(MouseEvent.CLICK, goCottage); function goCottage(evtObj:MouseEvent){
    trace("test")
***Any Help would be greatly Appreciated***
  • kglad
    Jul 21, 2002
    Jul 21, 2009 11:01 AM   in reply to scasey1982
    click file/publish settings/flash and tick "permit debugging" and retest to pinpoint your error.  the frame and line number that's causing the error will be displayed.
  • kglad
    Jul 21, 2002
    Jul 21, 2009 12:00 PM   in reply to scasey1982
    a function won't give a null object reference error.   the line above your function could be causing the error but it should be obvious which line is causing the error because the lines are numbered.  which line is referenced in the error message and copy and paste the exact error message.
  • kglad
    Jul 21, 2002
    Jul 21, 2009 12:37 PM   in reply to scasey1982
    if
    is the line referenced in the error message, viewCottage_btn doesn't exist when that error message occurs.
  • kglad
    Jul 21, 2002
    Jul 21, 2009 12:52 PM   in reply to scasey1982
    that depends how you create that instance.
    if it's done on the timeline, then you should have that code attached to the first frame where that object first appears and never remove that object for as long as it's needed.
  • kglad
    Jul 21, 2002
    Jul 21, 2009 2:18 PM   in reply to scasey1982
    use a trace() statement to confirm that the error occurs as the playhead enters the frame that contains your button for the first time.   if so, you have a typo either in the code or the properties panel.  use copy and paste to make sure they match.
  • kglad
    Jul 21, 2002
    Jul 21, 2009 5:09 PM   in reply to scasey1982
    is the code that causes the error message and the button in the same frame?  if so, you have a typo.
  • kglad
    Jul 21, 2002
    Jul 22, 2009 9:16 AM   in reply to scasey1982
    you're welcome.
    May 11, 2011 11:08 AM   in reply to kglad
    Hi kglad,
    I recently suffered a similar problem and reading your advice here helped me get it working again. Just wanted to let you know your helping us all and we appriciate it
    THANK YOU!!!
    p.s. you're a genious
