I have to move my Frame 9 installation to a new drive.
I have uninstalled Frame 9 from the existing drive, but a colleague says I needed to deactivate it.
Did the uninstall perform a deactivation automatically? If not, how do I regain the installation rights from the previous instance?
AFAIK, if the re-installation is on the same machine, then you don't have to deactivate. There's a set of activation FAQs at: http://www.adobe.com/products/activation/
I have to disagree here. If you reformat the drive, you don't need to reactivate, but I believe a new drive will require activation. I'd rather be safe and de-activate even if it means re-installing the software first. If its not possible and you have used your activations, Adobe will grant you an additional activation. So I wouldn't sweat it, but if I can avoid the hassle, I do.
If the machine is being rebuilt, rather than just a new drive being added, then I would go with Mike's recommendation to deactivate. The Adobe Licensing software is finicky & ornery, hiding stuff all over your drive. If you replace the drive, then this prior info is lost and you could be up the creek without a paddle. I just went through an exercise in frustration trying to get all components of the TechCommSUite running properly after a disk glitch forced me to LicenseRepair and re-install, since I couldn't deactivate prior to having the disk hiccup. The only saving grace was a deactivation followed by an uninstall, running Adobe's clean scripts and a re-install to get things working properly.
I've never had a problem with Adobe tech support when something like this has happened -- installation support is free, and they're quite familiar with this scenario. So best case is the software will go on and activate without a hitch. Worst case is the activation will be screwed, which means you have a 30-day window during which the software works to give you a window to call Adobe tech support and get it resolved. Which usually isn't a big deal -- just keying in a new key.
Art
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
