Hi all.. I've seen many articles on here about how to INSERT dates to the mySQL table, but I need to know how to format it into MM/DD/YYYY when the form dynamically populates from an existing record. Just using a regular DW8 Recordset behavior for this...
Thanks-
In ColdFusion you would use the date format function
#DateFormat(CreateODBCDate(yourDate), "dd/mm/yyyy")#
For more information on this do a Google search on: ColdFusion date format function
In PHP
date("Y/m/d")
For more info on this do a Google search on: php date format function
Lawrence *Adobe Community Expert*
www.Cartweaver.com
Complete Shopping Cart Application for
Dreamweaver, available in ASP, PHP and CF
www.twitter.com/LawrenceCramer
Use the MySQL DATE_FORMAT() function and assign the result to an alias in your SQL.
For example, let's say you have a date stored in a field called start. The following would format the date in your desired format, and present it in the recordset results as start_date:
SELECT DATE_FORMAT(start, '%m/%d/%Y') AS start_date,
another_field, yet_another
FROM my_table
There's a full list of the formatting characters in the MySQL reference manual (follow the link above).
By the way, the answer to this question was in Formatting dates stored in MySQL in the Dreamweaver FAQ.
Interesting.. both of your suggestions return errors claiming that there are too few arguments, resulting in an empty query.
Yes, there were too few arguments in the second example. It should be this:
SELECT *, DATE_FORMAT(start, '%m/%d/%Y') AS start_date
FROM my_table
Make sure you use single quotes around the '%m/%d/%Y'.
Hello David.. yes, my actual code piece was almost identical.. I even changed it JUST so that it would retrieve the date field, and the query still ends up empty even though I have confirmed that field on that record has a value. Here is my select statement:
SELECT DATE_FORMAT(joindate, '%m/%d/%Y') AS newdate FROM member
That should work. What happens when you use SELECT joindate FROM member?
The alternative way to do it is to create a small PHP function like this:
function format_mysql($date) {
$parts = explode('-', $date);
if (is_array($parts) && count($parts == 3)) {
return "$parts[1]/$parts[2]/$parts[0]";
} else {
return 'Date not available';
Then display the result from your recordset like this:
<?php echo format_mysql($row_recordsetName['joindate']); ?>There's something wrong with your code somewhere. I have just run the following test code, and it displays '02/01/1993', exactly as I expected it would.
<?php
} else {
$test = '1993-02-01';
echo format_mysql($test);
