Formatting mySQL date in a dynamic field
Jul 27, 2009 7:06 PM
Hi all.. I've seen many articles on here about how to INSERT dates to the mySQL table, but I need to know how to format it into MM/DD/YYYY when the form dynamically populates from an existing record.  Just using a regular DW8 Recordset behavior for this...
Thanks-
    Jul 27, 2009 8:57 PM   in reply to AdrianLe
    In ColdFusion you would use the date format function
    #DateFormat(CreateODBCDate(yourDate), "dd/mm/yyyy")#
    For more information on this do a Google search on: ColdFusion date format function
    In PHP
    date("Y/m/d")
    For more info on this do a Google search on: php date format function
    Lawrence   *Adobe Community Expert*
    www.Cartweaver.com
    Complete Shopping Cart Application for
    Dreamweaver, available in ASP, PHP and CF
    www.twitter.com/LawrenceCramer
    Jul 28, 2009 4:36 AM   in reply to AdrianLe
    Use the MySQL DATE_FORMAT() function and assign the result to an alias in your SQL.
    For example, let's say you have a date stored in a field called start. The following would format the date in your desired format, and present it in the recordset results as start_date:
    SELECT DATE_FORMAT(start, '%m/%d/%Y') AS start_date,
    another_field, yet_another
    FROM my_table
    There's a full list of the formatting characters in the MySQL reference manual (follow the link above).
    Jul 28, 2009 4:40 AM   in reply to David_Powers
    By the way, the answer to this question was in Formatting dates stored in MySQL in the Dreamweaver FAQ.
    Jul 28, 2009 8:41 AM   in reply to AdrianLe
    That makes no difference. Just write your SQL so that it includes the DATE_FORMAT() and alias.
    If you're being incredibly lazy, you can do this:
    SELECT *, DATE_FORMAT(start) AS start_date
    FROM my_table
    Jul 29, 2009 4:30 AM   in reply to AdrianLe
    Interesting.. both of your suggestions return errors claiming that there are too few arguments, resulting in an empty query.
    Yes, there were too few arguments in the second example. It should be this:
    SELECT *, DATE_FORMAT(start, '%m/%d/%Y') AS start_date
    FROM my_table
    Make sure you use single quotes around the '%m/%d/%Y'.
    Jul 29, 2009 8:41 AM   in reply to AdrianLe
    That should work. What happens when you use SELECT joindate FROM member?
    The alternative way to do it is to create a small PHP function like this:
    function format_mysql($date) {
      $parts = explode('-', $date);
      if (is_array($parts) && count($parts == 3)) {
        return "$parts[1]/$parts[2]/$parts[0]";
      } else {
        return 'Date not available';
    Then display the result from your recordset like this:
    <?php echo format_mysql($row_recordsetName['joindate']); ?>
    Jul 29, 2009 9:36 AM   in reply to AdrianLe
    There's something wrong with your code somewhere. I have just run the following test code, and it displays '02/01/1993', exactly as I expected it would.
    <?php
      } else {
    $test = '1993-02-01';
    echo format_mysql($test);
