kumar1981
Run .bat file with arguments?
Jul 31, 2009 6:12 AM
   I need to run the .bat file with parameters/arguments in Adode Indesign JavaScript. "File.execute()" executes the file using the appropriate application.It executes the .bat file suceessfully.But I am unable to pass the arguments.I need to execute the command like
Eg : test.bat parameter1 parameter2
var myFile=new File("c:\\test.bat");
myFile.execute();
The above statements works fine. Is it possible to execute the with parameters. Please suggest the solution to above problem.
    Community Member
    Jul 31, 2009 8:41 AM
    How 'bout creating a temporary shell script which executes the batch
    with the parameters? You then just execute the shell script which
    executes the batch in turn...
    Harbs
    Community Member
    Jul 31, 2009 9:30 AM
    How 'bout setting environment variables?
    type test.bat
    echo %BLA% > c:\test.txt
    $.setenv("BLA","value");
    File("c:\\test.bat").execute();
    Dirk
    Community Member
    Jul 31, 2009 1:12 PM
    How 'bout always writing out the batch file in full, with the parameters already in place? Then you'd only have to execute it.
    The consensus here seems to be Adobe didn't count on anyone trying to run an MS-DOS style batch file from within InDesign
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
