We have a large number of sites which do not work correctly with IE8 because of compatibility issues. We find that this removes the problem IF and ONLY if it is the first tag after the <head> tag:
<meta http-equiv="X-UA-Compatible" content="IE=EmulateIE7" >
The problem is that a huge number of these pages also use <cfform> which plugs <script> lines immediately after the <head> tag so that the meta tag is ignored.
How do I stop ColdFusion from doing this without editing a huge number of files to make them work using <form> instead of <cfform>!?
Is there a way of to edit the template that is inserted so that it inserts the <meta> tag along with the <script> tags?
This is extremely critical to our operation and right now it looks like a huge reprogramming task.
I'd like a more rational solution if anyone has it!
I could be wrong, but I do not think there is a non-hackish solution. AFAIK, the default html forms are generated directly from a java class. So there is not template to modify. I believe only format="xml" uses a kind of 'template' in the form of xsl files in the C:\ColdFusion8\wwwroot\CFIDE\scripts\xsl directory.
Assuming you have tried other methods without success, you might be able to trick CF by setting the header inside a custom tag. Not a great solution, but it should work.
http://www.coldfusionjedi.com/index.cfm/2007/9/3/ColdFusion-custom-tag -for-layout-example
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
