May 13, 2009 12:54 PM
updating bets based on _droptarget
Like (0)
I have another question on my roulette game that I am building.
The bets for the game are being placed by dragging a chip to a slot on the table. There are six slots, with numbers 1-6, 6-12, 12-18, etc....
I have a $25 chip and a $5 chip. I am using _droptarget to detect when a chip has been placed on one of the slots. If a $25 chip is placed on "slot1",
slot1Bet += 25;
Now the tricky part...if I move the chip from slot1 to another slot before the roulette wheel is spun, I need to change the bets so that "slot1 -= 25" and another slot gets the bet added. I'm calulating the final results by using something like this:
if (winningNumber<= 6){
return Number(money) + Number(slot1Bet) - Number(slot2Bet) - Number(slot3Bet) - Number(slot4Bet) - Number(slot5Bet) - Number(slot6Bet);
Any ideas?
P.S. sorry for reposting this, but I thought it better to start a new thread since my last question was answered.
you could define a property of each chip that stores its slot. when a chip is dropped check its property to see if you need to update a slotbet (ie, the property is defined) and then update its property.
Thanks Kglad! I hope your in for another question.
I have set a property for my chips like this: twentyfiveChip_mc.slot = undefined;
I have code like this when the chips are dropped on a slot:
if(twentyfiveChip_mc._droptarget == "/slot1"){
twentyfiveChip_mc.stopDrag();
if (twentyfiveChip_mc.slot == undefined){
slot1Bet += 25;
} else updateSlotBet();
twentyfiveChip_mc.slot = 1;
trace("You have a 25 chip on slot " +twentyfiveChip_mc.slot);
trace("Slot 1 bet is " + slot1Bet);
} else if (twentyfiveChip_mc._droptarget == "/slot2"){
slot2Bet += 25;
twentyfiveChip_mc.slot = 2;
trace("Slot two bet is " +slot2Bet);
I'm trying to figure out what the updateSlotBet function will look like. I'm going to sleep on this one, but if you have an idea...I'd love to hear it!
i would approach this with some fore-planning. first, i would have each chip have a value property (how much it's worth), in addition to a slot property to indicate which slot the chip is placed on. (btw, you do not need to intialize chip.slot=undefined. chip.slot will be undefined unless you explicitly define it which you're not going to do unless it's dropped on a slot).
and each slot1,..,slot36,slot0,slot00 i would add to a parent movieclip (say table) and assign it a property storing its slot number (though this can be derived easily using the slot movieclip's _name property and the flash string methods).
and i would create the initial setup using some parameters to give you more flexibility:
var chipValA:Array=[1,5,25,100]; // chip values
var chipNumA:Array=[20,20,20,20]; // number of $1, $5, $25, $100 chips.
i would create 1 of each of those chips and assign a linkage id: chip1_ID,chip5_ID,chip25_ID,chip100_ID
you could then code:
var dep:Number = 0;
for(var i:Number=0;i<chipNumA.length;i++){
for(var j:Number=0;j<chipNumA[i];j++){
var mc:MovieClip = this.attachMovie("chip"+chipValA[i]+"_ID","chip_"+dep,dep++);
mc.value=chipValA[i];
// assign _x and _y properties
mc.startX=mc._x;
mc.startY=mc._y;
mc.onPress=function(){
this.startDrag();
mc.onRelease=mc.onReleaseOutside=function(){
for(mc in table){ // loops through all the slots
if(typeof(table[mc])=="movieclip"&&table[mc]._parent==table){
if(eval(this._droptarget)== table[mc]){
if(table[mc].chip==undefined){
this._x=table[mc]._x;
this._y=table[mc]._y;
this.slot=table[mc].slot;
table[mc].chip=this;
} else {
// this slot already has a chip on it. decide what to do. replace previously placed chip, add to slot or return this chip to its startX,startY
} else {
this._x=this.startX;
this._y=this.startY;
then when your wheel spins you can loop through all the table children like above (to loop through all the slots), to see which have a chip property. the chip property references the chip(s) placed on that slot and has(have) a value property so you can determine the amount won.
after each slot's payout is determined, reassign the slot's chip property to undefined.
if a slot can hold multiple chips, make its slot property an array so you can push chips into the array should there be more than one chip placed on a slot.
Thanks Kglad!
I ended up solving the problem sticking with value and slot properties like you suggested before. Thanks for this other script though. If i have to do something like this again I have a better idea what is involved.
you're welcome.
I don't mean to advertise here, but thought the forum members might like to see the final project that was possible from the great help received here. Thanks everyone!
Has anyone heard of ot tried these two systems:
https://www.amazines.com/article_detail.cfm?articleid=972192
Copyright © 2011 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
