Fireworks CS4 updater 10.0.3 is LIVE
May 5, 2009 10:49 PM
  Latest reply: lots2learn2, Nov 3, 2009 10:10 AM
Replies 1 2 Previous Next
    Jul 6, 2009 1:35 PM   in reply to Sanjay B
    Hi Sanjay
    I've attached the log again and if there's any problems also uploaded it for you to download at;
    http://www.andrewscrivener.co.uk/fireworksLog.zip
    To answer your other question I did originally try the Fireworks CS4 beta but that was on my previous Macbook and I removed it with the CS4 beta removal tool, the only possible way there could be any stray files is if they weren't removed correctly and have since synched to my new Macbook via MobileMe.
    Andrew
    Jul 13, 2009 3:07 AM   in reply to A Scrivener
    Andrew
    I have sent mail to you seprately to setup a meeting.
    Sanjay
    Aug 10, 2009 9:17 AM   in reply to Sarthak Singhal
    I'm running into a different, but related issue. When checking for updates within FW, the updater checked all Adobe apps, offered the various downloads, including 10.0.3 for FW, and ran the updater without incident. However, when viewing the version number on the splash screen, or checking Help > About Fireworks, I'm seeing the version as 10.0.0.495. I've run through this process three or four times now with the same results.
    I also just tried downloading the standalone updater for FW 10.0.3 and when I attempt to run it, it tells me that 10.0.3 is already installed.
    Any help?
    Aug 11, 2009 5:01 AM   in reply to digitaldojo
    Please verify by hovering your mouse on Fireworks.exe application for its version.
    Since you do not get any error message I do not see much use of log files.
    I suggest uninstall Fw cs4 and then re-install Fw CS4.
    Sanjay
    Aug 11, 2009 7:39 AM   in reply to Sanjay B
    Sanjay, thanks for the suggestion. Hovering over the .exe displays
    10.0.0.495 ... same as the 'About Fireworks' view. I believe the issue I'm
    having is not specific to FW, but to all the Adobe products as every time I
    check for updates, the updater is finding the same three updates ... one for
    FW, one for Reader, and one for Illustrator.
    So I'm thinking a complete uninstall and reinstall ... ugh.
    Thanks again,
    Rick
    Sep 4, 2009 10:53 AM   in reply to Sarthak Singhal
    Sarthak,
    Could you send me an email or place to upload the files you need. I have CS4 Master Suite and I ran the updater every app updated but the Fireworks 10.0.3 I even made a new user account for a different issue and it's still won't update, I also used thew standalone installer.
    David
    Sep 6, 2009 10:33 PM   in reply to Sarthak Singhal
    Hi David
    Note the location of installer logs in this thread.
    1. Please move all existing installer logs to make the place clean. (Leave any other folders at that location intact)
    2. Run the standalone updater
    3. Send the newly created installer log
    Also keep in mind last time you had to post the logs at your website instead pf attaching here because of size limitations.
    Sep 26, 2009 9:13 PM   in reply to Sarthak Singhal
    I have recently upgraded both my computer and Adobe software suite.  I have 6 GB of ram and a very fast processor.  Issue I am having is the slow speed of Fireworks CS4 opening and saving files.  Is there some form of Vista Business 64 bit optimization I need to do?  Does having both CS3 and CS4 installed on the same system cause an issue?
    I am desperate to get this solved.  I have invested heavily in using the increased speed of CS4 64 bit, and have in no way realized those time savings because of the issues above.
    Please help me.
    Sep 27, 2009 12:56 PM   in reply to Sarthak Singhal
    Sarthak,
    Attached is the file I am having problems with.  The components that are
    causing the problem are Illustrator Artistic Brush strokes that I imported
    into Fireworks CS4 form Illustrator CS4.  These components have been
    highlighted in purple.  CS3 does not have any issues with this.  Is there a
    patch or work around for this?
    This file will take 60 seconds to save in CS4 versus 3 seconds to save in
    CS3.
    Please help me.
    Natalya Brandt
    office  510.538.1177
    mobile 510.599.7110
    natalya@sierrausa.com
    www.sierrausa.com
    Sep 27, 2009 1:14 PM   in reply to Sarthak Singhal
    Sarthak,
    Adobe support is telling me that Fireworks CS4 is not compatible with 64 bit
    operating systems.  Is this true?  When I purchased CS4, part of the
    advertised benefit was the speed increase that would be realized when
    running the package on a 64 bit system.  When I installed the product, I
    installed the 64 bit version.  This line of reasoning from Adobe support
    does not make sense.  Can you please clarify?
    Natalya Brandt
    office  510.538.1177
    mobile 510.599.7110
    www.sierrausa.com
    Sep 27, 2009 2:23 PM   in reply to natalyabrandt
    According to the MS Vista Compatability list here http://www.microsoft.com/windows/compatibility/Search.aspx?s=Adobe%20F ireworks&type=software&os=64-bit
    Yes Fireworks CS3/CS4 should be fine on 64bit
    h
    Sep 27, 2009 8:33 PM   in reply to heathrowe
    Heathrowe,
    Thank you for the information.  Yes I agree that the 64 bit CS4 package (and
    there are two versions of CS4, one 32 bit and one 64 bit, I installed the 64
    bit version) I installed should be compatible with Vista and all 64 bit
    hardware platforms.
    Here is the response I got from Adobe:
    The simultaneous installation of Fireworks CS3 and CS4 does not cause any
    performance issues. The increased speed of 64 bit is not being consumed by
    Fireworks like other Adobe apps ex Photoshop.
    You might probably try running a fewer applications to make the system and
    apps run faster. A guess.
    The problem I have happens when just Fireworks CS4 is open and all other
    apps are closed.  The second response I received was:
    Firstly, I need to inform you that Adobe does not certify Fireworks
    CS4 for Windows Vista 64-bit operating system. It is only certified for
    the 32-bit version. Hence working on a non-compatible OS may result in
    unexpected errors. I can either suggest you to use a 32-bit vista or
    wait for a compatible release from Adobe.
    The second statement came directly from Adobe online support.  The problem
    happens in CS4 and not in CS3.  I have isolated it to the addition of
    Illustrator Artistic Brush elements.  The included file has the problem.
    Any help you can give would be greatly appreciated.
    Natalya Brandt
    office  510.538.1177
    mobile 510.599.7110
    www.sierrausa.com
    Sep 29, 2009 1:28 PM   in reply to Sarthak Singhal
    I am also having an issue updating Fireworks to 10.0.3. I am running PPC 10.5 Web Design Premium CS4.
    I don't have any logs in the folder indicated in this forum's thread. Looks like I may have to do a clean reinstall of my whole machine but that is going to be a waste of time if I still can't update. Can someone help me?
    Sep 29, 2009 9:12 PM   in reply to Sarthak Singhal
    Sarthak,
    Attached is the file that has the Illustrator Artistic Brush strokes that were imported into Fireworks CS4.  This file saves at the normal rate in CS3, but takes a long time (up to two minutes) in Fireworks CS4.  Please help me to understand the problem.
    Natalya
    Sep 30, 2009 5:38 PM   in reply to A Scrivener
    I'm having the same problem.. Eveytime I tried to install 10.0.3 update, I get the same error: "Adobe Fireworks CS4 10.0.3 - Failed to Install.".
    What can I do about it? Somebody already discovered how to fix it?
    I also attached the log that you guys were talking about. Hope it be helpfull.
    Oct 2, 2009 7:44 AM   in reply to Sarthak Singhal
    I installed the patch and see no difference in stability problems.  FW CS4 crashes every 5-10 minutes on an otherwise stable Pentium 4, 4GB RAM, Win XP Pro.
    Your software team may want to study this page of design professionals who have all experienced the same instability:
    http://www.flickr.com/photos/hicksdesign/3961465821/
    IT IS YOUR SOFTWARE.  PLEASE FIX IT.
    Oct 6, 2009 5:30 AM   in reply to eversonjp.com.br
    Hi Eversonjp
    We have workaround that is likely to fix this issue.
    1.       cd  /Applications/Adobe Fireworks CS4/Configuration/Mac/Shared/AdobeAIR/SDK/runtime/Adobe AIR.framework
    2.       rm –f Versions/Current
    3.       rm –f “Adobe Air”
    4.       rm –f Resorces
    Oct 6, 2009 5:41 AM   in reply to Sanjay B
    Nice! Thanks Sanjay!
    I will try this!
    Oct 30, 2009 4:21 PM   in reply to Sarthak Singhal
    My Fireworks CS4 will not open.  I get the error, "An internal error occurred" (twice).
    I moved all my fonts and it still wouldn't work.
    I tried moving specific fonts that other people noted, and it still didn't work.
    I downloaded and unzipped the update.  My screen shows Version 10.0.3.011.  It still doesn't open.  same error.
    what else?  It worked fine for the last three months. Then this error.
    Can you help me please.
    Nov 3, 2009 10:04 AM   in reply to Sarthak Singhal
    No Sarthak, I don't have any .dfonts.  I repaired my Office 2007 and lost many fonts, leaving only .ttf, one .ttc, and two .fon.
    Any other suggestions?  It worked fine for a few months until now.
    Nov 2, 2009 9:13 AM   in reply to Sarthak Singhal
    Oops, Sarthak, can you remove my personal information from that last e-mail?  Please.
    Nov 3, 2009 10:10 AM   in reply to Sarthak Singhal
    Anything?  Do you have any help for me at all?  I've tried removing fonts and downloading the updater.  I continue to get the same error message.  This was not inexpensive software.  I would really like to be able to use it.  Sure would appreciate some help on this.  I don't know what to do.
1 2 Previous Next
Actions
