I've been struggling with a large project that I could use some help on.
The project is a 245 slide powerpoint with imported audio and some powerpoint animations. ( We hold 2 hour webcasts and repackage them for resale). Captivate 4 does not seem to like large projects. I have used all the tricks to compress the file size so it will finally go through the publishing process without erroring out - however, the published project will not play.
I did use the advanced project compression option - is this causing it to freeze? I iasked that it be published in Flash player 7 but my pc has recently been upgraded to flash player 10 - do I need to publish it in Flash layer 10? What if my users are on an earlier version of flash?
If I turn it into an aggregator project but do not have an LMS to load it to, will the html link work - will it create multiple links?
Any ideas on how I can get this to work? Any info is greatly appreciated!
Phyllis
Hi there
Please read the thread linked below.
Cheers... Rick ![]()
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
Thanks for the information on the daisy chain process. It certaintly makes sense and I'll give it a try. I have to create both a CD and a weblink. How do I produce a CD with all the linked projects onto the same CD? Should I try using the aggregator product instead - will this accomodate the creation of a CD? Thanks !
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
