meister@denis-online.de
Thanks a lot!
Denis
Hi Arnout,
I cant get it to work.
This is my slide so far: http://www.localhero.de/_Slide/_Slide.php
I want to start it automaticly, and no start an no stop button.
And it would be cool, if it goes forward and at the end backwards :-)
Denis
Instead of creating a custom script, I decided to extend the widget it self. So everything can be controlled from the widget constructor.
Before we get started a small side note:
I would advice to put the changes in a seperate script, and not to modify the current SlidingPanels.js. This way, if you happen to update to Spry 1.7 it will not overwrite the change you made. But if you do not wish to update just paste it in the SprySlidingPanels.js (This saves a HTTP request, resulting in a slightly faster page load, maintainablity vs performance)
The changes allow you specify the following new options in the constructor:
- automatic: true / false [boolean]
turns automatic sliding panels on or off, off by default
- direction: 0 / 1 [number or Spry.forward , Spry.backward if you have SpryEffects included]
direction that panels should automaticly slide to, 1 is forward, 2 is backward
- each: 1000 [number]
time in miliseconds, note I had to name this "each" instead of duration, because duration handles the sliding panel animation duration.
Example constructor:
var sp1 = new Spry.Widget.SlidingPanels("SlidingPanels1", { automatic: false, direction: 0, each: 5000 });
It also adds 3 new methods to the sliding panel:
- .start [ sp1.start(); ]
This allows you to start the automatic sliding of the panels, this will also work, if you did not specify automatic in your constructor
- .stop [ sp1.stop(); ]
Stops automatic sliding of the panels
- .setDirection [ sp1.setDirection(1); ]
Sets a new direction for the sliding panels, requires the same values as you can specify in the sliding panels constructor
The new code:
// line 121 of SprySlidingPanels.js
Spry.Widget.SlidingPanels.prototype.attachBehaviors = function()
var ele = this.element;
if (!ele)
return;
if (this.enableKeyboardNavigation)
var focusEle = null;
var tabIndexAttr = ele.attributes.getNamedItem("tabindex");
if (tabIndexAttr || ele.nodeName.toLowerCase() == "a")
focusEle = ele;
if (focusEle)
var self = this;
Spry.Widget.SlidingPanels.addEventListener(focusEle, "focus", function(e) { return self.onFocus(e || window.event); }, false);
Spry.Widget.SlidingPanels.addEventListener(focusEle, "blur", function(e) { return self.onBlur(e || window.event); }, false);
Spry.Widget.SlidingPanels.addEventListener(focusEle, "keydown", function(e) { return self.onKeyDown(e || window.event); }, false);
if (this.currentPanel)
// Temporarily turn off animation when showing the
// initial panel.
var ea = this.enableAnimation;
this.enableAnimation = false;
this.showPanel(this.currentPanel);
this.enableAnimation = ea;
if (this.automatic){
this.start();
// These are all new methods
Spry.Widget.SlidingPanels.prototype.start = function(){
var self = this; // reference to this, so we can use it inside our function
this.automaticStarted = setInterval(function(){
var panels = self.getContentPanels(),
panelcount = panels.length,
current = self.getCurrentPanel(),
newpanel;
// locate the current panel index, and check if we need to increase or decrease the panel
for(var i = 0; i < panelcount; i++){
if(panels[i] == current){
self.direction == 1 ? (i++) : (i--);
self.showPanel( self.direction == 1 ? (i >= panels.length ? 0 : i) : (i < 0 ? panels.length -1 : i));
break; // stop looping, we already found and are displaying our new panel
}, this.each || 3000);
Spry.Widget.SlidingPanels.prototype.stop = function(){
if(this.automaticStarted && typeof this.automaticStarted == 'number'){
clearInterval(this.automaticStarted);
this.automaticStarted = null;
Spry.Widget.SlidingPanels.prototype.setDirection = function(direction){
this.direction = direction;
Hopes this helps
Hmz,
Sure it possible
As you can just switch direction to backwards once you are at the end, or forwards once your are the beginning..
I'll build a option for that. something like
{ each: 5000, infinite : true, automatic : true }
I'll see what i can do.
Note: its rather annoying that I can't edit the above post, I just spotted a little inefficent code above..
im doing panel.length instead of reusing the panelcount variable. Bummer.
:-) very cool.
I got one other, for me important, question.
Look at my slide: http://www.localhero.de/_Slide/Box.php
At the right side there are thumbs. I want the one, which panel is on focus to be with a white border.
Can I find out, which RowID is displayed?
This is my Slide Code.
<div id="TeaserContainer">
<div id="TeaserArrowUp"><a href="#" onClick="sp1.showPreviousPanel();"><img src="../Slices/images/images/Arrow_04.png" border="0" /></a></div>
<div id="TeaserArrowDown"><a href="#" onClick="sp1.showNextPanel();"><img src="../Slices/images/images/Arrow_03.png" border="0" /></a></div>
<div spry:region="dsTeaser">
<div spry:repeat="dsTeaser">
<div id="TeaserThumbLink{ds_RowID}"><a href="#" onClick="sp1.showPanel('id{ds_RowID}');"><img src="{artistthumb}" width="60" height="40" border="0" /></a></div>
</div>
</div>
<div id="slidingPanel_1" class="SlidingPanels" spry:region="dsTeaser">
<div class="SlidingPanelsContentGroup">
<div id="id{ds_RowID}" class="SlidingPanelsContent" spry:repeat="dsTeaser">
<div class="TeaserLeft"><img src="{artistimage}" width="450" height="300" /></div>
<div class="TeaserRight">
<h1>{artistname}</h1>
<p>Genre: {artistgenre}<br />
Gründungsjahr: {artistyear}<br />
Heimatort: {artistort}<br />
Besetzung: {artistmembers}<br />
<a href="#" class="TeaserLink">...mehr über dem Künstler</a></p>
</div>
</div>
</div>
</div>
</div>
<script language="javascript" type="text/javascript">
var sp1 = new Spry.Widget.SlidingPanels("slidingPanel_1");
</script>
These lines create the thumbs:
</div>
</div>
But what spry tag shows me which panel is on focus?
Thanks a lot,
Denis
The best thing for that is, again.. to modify the Spry file. I once had the same issue. Here is the code i used:
(I'm using sliding panels as wizzard atm, and want breadcrumb paths to be highlighted based on current panel)
Its a modification to the showPanel method:
Spry.Widget.SlidingPanels.prototype.showPanel = function(elementOrIndex)
var pIndex = -1;
if (typeof elementOrIndex == "number")
pIndex = elementOrIndex;
else // Must be the element for the content panel.
pIndex = this.getContentPanelIndex(elementOrIndex);
var numPanels = this.getContentPanelsCount();
if (numPanels > 0)
pIndex = (pIndex >= numPanels) ? numPanels - 1 : pIndex;
else
pIndex = 0;
var panel = this.getContentPanels()[pIndex];
var contentGroup = this.getContentGroup();
if (panel && contentGroup)
if (this.panelChange){
this.panelChange(pIndex);
this.removeClassName(this.currentPanel, this.currentPanelClass);
this.currentPanel = panel;
var nx = -panel.offsetLeft;
var ny = -panel.offsetTop;
if (this.enableAnimation)
if (this.animator)
this.animator.stop();
var cx = contentGroup.offsetLeft;
var cy = contentGroup.offsetTop;
if (cx != nx || cy != ny)
var self = this;
this.addClassName(panel, this.animatingClass);
this.animator = new Spry.Widget.SlidingPanels.PanelAnimator(contentGroup, cx, cy, nx, ny, { duration: this.duration, fps: this.fps, transition: this.transition, finish: function()
self.removeClassName(panel, self.animatingClass);
self.addClassName(panel, self.currentPanelClass);
this.animator.start();
else
contentGroup.style.left = nx + "px";
contentGroup.style.top = ny + "px";
this.addClassName(panel, this.currentPanelClass);
return panel;
This modification allows you to specify a callback function in the sliding panel constructor using the following option:
panelChange: [function]
The function to be called once the panel is changing.
Example:
function setStep( index ){
alert(index); // current panel index
var sp1 = new Spry.Widget.SlidingPanels('id', {panelChange: setStep});
My finished implementation of it:
funtion updateBread( index ){
// this example uses SpryDOMUtils.js
var steps = Spry.$$('ol.steps li'); // my amount of LI's match the amount of panels
steps.removeClassName('selected'); // remove all selected classNames
steps[index].className = 'selected'; // set selected to the current
var sp1 = new Spry.Widget.SlidingPanels('id', {panelChange:updateBread});
Hopefully it helps you out a bit.
You change it for your need, add an id attribute on your:..
Example:
<div spry:repeat="dsTeaser">To:
<div spry:repeat="dsTeaser" id="thumbs">
var steps = Spry.$$('ol.steps li'); would become:
var steps = Spry.$$('#thumbs a');
And CSS:
#thumbs .selected img { border : 2px solid white }DenisCGN wrote:
Hi Arnout,
thanks a lot.
Is it somehow possible, to ad an third direction?
"FORWARD and BACKWARD"
It starts forward comes to the end and goes back step by step and then starts forward again :-)
like: 1 2 3 4 5 4 3 2 1 2 3 4 5 4 and so on.
I gonna try your code NOW :-)
Cheers
Denis
Done, update Spry.Widget.SlidingPanels.prototype.start with the new function i specified below
newpanel;
// set the correct panel index based on the direction
// check if we want to do 1 2 3 2 1 .. looping instead of 1 2 3 1 2 3 ..
if(self.backAndForth){
if(self.direction == 1 && i >= (panelcount -1)){
self.direction = 0; // reset the direction
i = panelcount;
} else if(self.direction == 0 && i == 0) {
self.direction = 1; // reset direction
i = 0;
self.showPanel( self.direction == 1 ? (i >= panelcount ? 0 : i) : (i < 0 ? panelcount -1 : i));
This will add another option to your construction.
- backAndForth: true / false [Boolean] false by default.
It makes your panels slide like this: 1 2 3 4 5 4 3 2 1 2 3 4 5 4 3 2 1 2 3 4 5 4 3 2 1 2 3 .. you get the drill
So, I think its all done now
, this just shows you can virtually do anything you want with Spry and Spry Widgets as long you know where to look for.
Working samples: https://dl.getdropbox.com/u/1381492/slidingpanels%20automatic/SprySlid ingPanels.html
Temporarily online, just for laughs and giggles to show all the possibility and to show how it works and could be implemented..
Arnout,
Thanks so much for your great work!
Maybe you can attach the final js file with all the new functions. I think I am to stupid to include all the new code :-(
I copied it from your demo, but my slide didnt start runing.
http://www.localhero.de/_Teaser/lh.php
Denis
This is what I use. The slide only starts if you click on the down arrow two times :-(
Its because you don't attach your SlidingPanel when your region gets regenerated.
Apply the same techniques as they do in the Spry Accordion sample:
http://labs.adobe.com/technologies/spry/samples/accordion/AccordionSam ple2.html
var sp1; // place it outside the scope so you can still it through javascript
Spry.Data.Region.addObserver("Teaser", {
onPostUpdate: function(observer, region){
sp1 = new Spry.Widget.SlidingPanels(region.regionNode, {automatic: true, direction: 1, each: 5000, backAndForth: true});
That would do;
me again!
I cant get that thing with the BORDERED Thumbs to work. I copied, the CODE and tried to figure out, how and where to put code.
But now, the thumbs are gone and the slideshow stops :-(
Its really hard to find out things if everything is only in english. I sometimes dont even know how and where to start. Like that OBSERVER thing, how should I know that :-)
The best would be, if Adobe creates more, widgets.
Now I open a beer and enjoy my working slider.
Again, thanks a lot.
Denis
Looking on your working eample i saw this reference:
<script type="text/javascript" src="http://config.spry-it.com/js?f=effects"></script>
Looking on the code i dont know what is it for . i have tried your example and it seem to work fine without it. Could you say if this reference is neccessary, and if so what does it do.
Its not nessesary but I remember again why i put it in there. I used it as reference. So you can also use Spry.Forward and Spry.Backward from the SpryEffects to define your sliding panel directions, just a handy extra that is build in. To make it more readable
. Its not needed to make script work.
The /js?f=effects is custom file combiner application i have written for Spry, it takes all specified files, and combines it in to one file with the correct license header. It can be prefixed with Spry or with out. In this case its points to the latest Spry version and gets a minified SpryEffects file. /js?f=1.6.1/effect would point to a specific version and /js?f=1.6.1/xpath/dataset/nestedxmldataset would combine multiple files.
Ok thanks for the explanation but as a rooky i do not understand your strong japanize accent. The only think i understand thus far is " Its not needed to make script work". I would like to thank you for making my life easier with your great extention to the sliding panel widget. Great work.
