Removing project from source control
Mar 19, 2009 7:22 AM
We have a project that is source controlled in RoboSource 3.1. There are currently three writers on the project and we each have a version of the project on our hard drives from which we are working. We are having a hard time keeping our projects synced between our hard drives and RoboSource. My question is this: If I go into RoboHelp and select remove project from source control, does it only remove the temporary project on my hard drive, will it remove the main project in RoboSource, and/or will it remove everyone else's project from source control.
Thanks.
Bill
    Mar 19, 2009 7:27 AM   in reply to wesacalypso
    Hi Bill
    I'm a bit confused as to why you are even using source control if each author has a different version of the same project on their local drive. The purpose of source control with RoboHelp is to ensure that all authors are working with the same project. Suzie's project should look identical to John's and so on.
    Assuming Source Control is properly set up and configured, I would think if you deleted a project from the Source Control repository it would very likely affect the other users.
    Cheers... Rick
    Mar 20, 2009 6:01 AM   in reply to wesacalypso
    We've also recently moved to using RSC (as part of converting X5 to RH8), so expert advice this is not.
    However, it seems that renaming should be done in RSC, and not in RH. In addition, the RSC Edit > Delete / Hide option might be the answer for folders.
    Good luck,
    Leon
    Mar 23, 2009 9:51 AM   in reply to MergeThis
    I can understand your frustration with errors in RSC/RH integration. Strange things do seem to happen.
    In answer to your original question, I do not believe that removing the project from source control on a single author's machine takes the project "Out" of source control for other authors.
    The database of files on the RSC server will remain the same and the rpoject will be maintained locally. This can be a good way to clean up a project and then add it back to a new RSC database later.
    Good Luck!
    Mar 23, 2009 11:17 AM   in reply to Eli_for_Hire
    Hi all
    I wrote this article a couple of years (and versions) ago. Not sure if it will still apply but it may. Perhaps take a look at the link below:
    Click here to read
    Cheers... Rick
    Apr 17, 2009 7:29 PM   in reply to wesacalypso
    We rebuild our CPD files quite often, for precisely the kinds of synchronization issues you describe. The only problem we run into when we do so is that it can take a long time to rebuild for the really huge projects. For most people, this shouldn't be a problem.
    G
    Apr 17, 2009 7:38 PM   in reply to Captiv8r
    Rick, your article still applies to RH6/RSC3 projects. FYI, I also remove the pss file and the mssccprj.scc (if present).
    I haven't checked the procedure for RH7/RH8 projects, but I'll bet it's the same.
    G.
    Apr 17, 2009 7:54 PM   in reply to MergeThis
    Leon, you might want to be careful with renaming items in source control. If you make a change in source control, RH may not know about it. We generally make changes in RH, letting RH communicate the relevant changes to RSC. I don't usually make changes directly in RSC unless there's a problem.
    I might mention that such problems tend to occur when there is a RH crash during certain kinds of operations. For example, say that the help author renaming a folder when his or her pc crashes. This kind of interruption can leave RH with one set of information and RSC with another. Then you can get stuck with having to manually rename and delete things to get them sync'd up again.
    I'll agree with you on deleting/hiding folders in RSC. Sometimes there gets to be quite a bit of visual clutter, but you probably don't want to totalll obliterate the old items.
    My 2¢.
    G
    Apr 18, 2009 7:46 AM   in reply to wesacalypso
    Hello again,
    So, I tried it out on one of my test systems.
    Removing the project from source control will change that user's view of the project.
    However, the user can re-connect to the project again (by opening it from source control) which will copy all the files back down as if it was new again.
    However, if the issue you are having is that your authors are seeing different versions of the files, you should check on the status of the files for each user.
    I reccomend you have each user save and check in all files.
    This should put all changes back up. Then, when you open the project, have each user download the latest from the server. If there are any inconsistencies, you will get warnings about them.
    Hope this helps.
    Apr 18, 2009 8:04 AM   in reply to Eli_for_Hire
    Oh, One more comment.
    You can disconnect a project from source control instead. This makes the local set of files on your PC a local only project, but leaves the stuff on the RSC for other authors to connect to.
    Apr 7, 2010 10:23 AM   in reply to Eli_for_Hire
    Hello Eli
    How do you disconnect a project from RSC?
    My system Attributes:
        RoboHelp HTML V8.02
        RoboSource Control 3.1
        RoboHelp Server V8.0
        WebHelp Pro 5.50 (7.00.145)
    Jun 15, 2012 6:13 AM   in reply to Captiv8r
    I followed Rick's instructions using RoboHelp 8. It works. But I did not have to delete the pblsvrs.sss file, which in RoboHelp 8 lists the names of the servers to publish (HTML files) to.
