For the devs, here is the output from GPUSniffer.exe (was in the Soundbooth folder) so you can rule out gfx card problems:
D:\Program Files (x86)\Adobe\Adobe Soundbooth CS4>GPUSniffer.exe
Device: 005F7FDC has video RAM(MB): 256
Vendor string: NVIDIA Corporation
Renderer string: GeForce 8500 GT/PCI/SSE2
Version string: 2.1.2
OpenGL version as determined by Extensionator...
OpenGL Version 2.0
Supports shaders!
Supports VUYA Shader -> BGRA
Supports UYVY/YUYV ->BGRA Shader
Supports YUV 4:2:0 -> BGRA Shader
Use basic OpenGL (aka CPU mode) only!
Completed shader test!
Internal return value: 7
If this is indeed related to the OpenGL issues seen in some Nvidia and Intel drivers, there's a few things to try. First, I'd make certain you're completely up to date with your video drivers. Second, as a test to rule this issue out, try temporarily moving or renaming the files
nvoglv32.dll
nvoglv.dll
in your \windows\system32\ directory. If Soundbooth still fails on the next launch, move them back.
I would also recommend contacting Adobe Technical Support as these install/launch issues are significantly faster to troubleshoot and solve over the phone than they are here on the forums. If you'd prefer to keep it here, can you provide any additional information about the crash behavior? Do you get error messages? Do you see the Soundbooth splash screen pop up before the crash?
Durin
Hello,
actually I had to look into my CS Box to find the customer support information, never thought of that (I am more accustomed to Internet communication).
Regarding my problem: I renamed the files (for me it was in the WOW64 folder since Soundbooth is 32bit) and it's crashing behavior didn't change.
Regarding more information: I see the splash loading several modules (around 10 seconds) until I get the famous "report this crash to Adobe" screen. The only weird thing is that I can successfully run Soundbooth through the WinDbg application, but for me it's not an option on the long term of course (starting the application through a debugger).
By the way: I installed Soundbooth on a 2nd portable computer (as the license allows) which got XP (32bit) installed, and it worked fine. So that rules "ruined DVD medium" out I guess.
Thanks for your effort
I had problem with Adobe After Effects CS4, Adobe Encore CS4, Adobe Photoshop CS4, Adobe Soundbooth CS4, Adobe Premiere Pro CS4 and I fixed everything!!!!!!!
My Hardware/Software profile:
- Intel Pentium 4
- Go Fx 5700
- Windows XP SP3
Problems in details :
1- With Soundbooth and Premiere I had problem loading up- Splash screen only used to go up to loading "PlayerMediaCore.prm" then just shuts down.
2. With AfterEffects It was error 0::42
3. With Potoshop it used to crashed as soon as it opened .
Diagnose:
The issue was with the display card drivers and Open Gl
Solution:
As Durin said to delete nvoglv32.dll , nvoglv.dll. It worked and only for Soundbooth and Premiere but Photoshop and AfterEffects still did not work.
I couldnt find latest driver for my card last release was 2004 on HP website.
However I found this site which has all the NIVIDA drivers.
http://www.warezthegfx.com/games/102028-nvidia-drivers-updated-21-03-0 9-a-post105989.html (Choose according to your system)
To Install you must know what type of card you have.
1. Download the file and extract it- The setup will being on it own. If the setup says "The NIVIDA setup program could not locate..............." and exit , do not worry.
2. Go to your Device manager and select your display adapter
3. Under Driver "select uninstall" and uninstall your drivers then restart system
4. Go back to Device manager and select your VGA card
5. Under Driver select Update driver and choose "Install from a list or a specific location"
6. Hit next then select "Don't search....."
7. Click on Have disk or browse and point to the files that you extracted from the download
8. Tick off show Compatible hardware
9. Choose your card, and install it , even if u get any warning ! But make sure u know what card u have.
I hope it works coz it worked for me! Good luck to all!
Actually this is how I solved the Soundbooth crash:
a) Format harrddisk (yes, i did that)
b) Complete _fresh_ install of Windows
b1) Install GFX card drivers from webpage
c) Install all patches, updates AND redist packs from Microsoft webpage
d) Install Adobe products
e) install updates for adobe products
It also seems that the ORDER of doing this things is important (Adobe at last)
Now it works all fine. A bit work intensive but anyway ;-)
Well I had this problem in Windows 7, it was a simple fix based on a problem with the ExporterAVI Plug-in.
In the \[install directory]\Adobe Soundbooth CS4\Plug-ins\Common folder there is a file called Blacklist.txt, I simply added the offending plugin to the list ("ExporterAVI") and was able to launch Soundbooth again.
Much as the people here want you to go through an inquisition about your OpenGL drivers and have you reinstalling entire operating systems, it boiled down to a simple plugin.
Matt, I am wondering what the shift key does in this case. I have been having the problem of the program crashing when ever I wanted to do a multi-track file, I help the shift key down at start up and it seems to be working now. I unlike the everyone else run a Mac with OSX Snow Leopard, I hadn't had the problem until I updated to Snow Leopard.
I get the error WinPathUtils.cpp-582
C:\Documents and Settings\djatkins>set
ALLUSERSPROFILE=C:\Documents and Settings\All Users
APPDATA=\\BETA\djatkins\.windows\Application Data
CommonProgramFiles=C:\Program Files\Common Files
FP_NO_HOST_CHECK=NO
HOMEDRIVE=C:
HOMEPATH=\Documents and Settings\djatkins
HOMESHARE=\\beta\djatkins
LOGONSERVER=\\BETA
OS=Windows_NT
Path=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOW S\system32\WindowsPowerShell\v1.0;C:\Program Files\QuickTime\QTSystem\
PROCESSOR_ARCHITECTURE=x86
PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 11, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=0f0b
SystemDrive=C:
SystemRoot=C:\WINDOWS
TEMP=C:\DOCUME~1\djatkins\LOCALS~1\Temp
TMP=C:\DOCUME~1\djatkins\LOCALS~1\Temp
USERDOMAIN=OZ
USERNAME=djatkins
USERPROFILE=C:\Documents and Settings\djatkins
windir=C:\WINDOWS
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\ Shell Folders]
"AppData"="\\\\BETA\\djatkins\\.windows\\Application Data"
"Cookies"="C:\\Documents and Settings\\djatkins\\Cookies"
"Desktop"="\\\\BETA\\djatkins\\.windows\\Desktop"
"Favorites"="C:\\Documents and Settings\\djatkins\\Favorites"
"NetHood"="C:\\Documents and Settings\\djatkins\\NetHood"
"Personal"="\\\\BETA\\djatkins\\.windows\\My Documents"
"PrintHood"="C:\\Documents and Settings\\djatkins\\PrintHood"
"Recent"="C:\\Documents and Settings\\djatkins\\Recent"
"SendTo"="C:\\Documents and Settings\\djatkins\\SendTo"
"Start Menu"="C:\\Documents and Settings\\djatkins\\Start Menu"
"Templates"="C:\\Documents and Settings\\djatkins\\Templates"
"Programs"="C:\\Documents and Settings\\djatkins\\Start Menu\\Programs"
"Startup"="C:\\Documents and Settings\\djatkins\\Start Menu\\Programs\\Startup"
"Local Settings"="C:\\Documents and Settings\\djatkins\\Local Settings"
"Local AppData"="C:\\Documents and Settings\\djatkins\\Local Settings\\Application Data"
"Cache"="C:\\Documents and Settings\\djatkins\\Local Settings\\Temporary Internet Files"
"History"="C:\\Documents and Settings\\djatkins\\Local Settings\\History"
"My Pictures"="\\\\BETA\\photos"
"Fonts"="C:\\WINDOWS\\Fonts"
"My Music"="\\\\BETA\\djatkins\\.windows\\My Documents\\My Music"
"Administrative Tools"=""
"CD Burning"="C:\\Documents and Settings\\djatkins\\Local Settings\\Application Data\\Microsoft\\CD Burning"
"My Video"="\\\\BETA\\djatkins\\.windows\\My Documents\\My Videos"
If I log on as a Non-Domain ie Local User it works
f it identifies any file or setting to be damaged, missing, or corrupted, it provides you with an updated list of the same and also repairs these errors. Therefore, if your computer keeps crashing and need to fix blue screen of death a good registry cleaner is all you need. Your computer can also cause problems because of redundant files in its registry. Reg cleaners identify all these redundant and junk files that were left over during the uninstalling process of hardware of software and delete them. This makes sure that the "computer keeps crashing" issue is taken care of.
__________________________
| Free Sound Effects |
I had the same problem with Soundbooth crashing on startup after PlayerMediaCore was seen on the splash screen.
A post above about the file called Blacklist.txt gave me the idea to move all of the plug ins to another folder and start the program. Replace them one by one, loading the program after each plug in was moved back into the original folder. The program would not load when the plug in called ImporterFastMPEG was loaded back into its original folder. I can run the program without it.
Thank you Adobe for this forum and thank you to all of you who chose to post here. You have helped more than you could ever know.
I could not start soundbooth yesterday.
So I tested a solution that I has used to get Encore to start.
I renamed the directory: C:\Documents and Settings\UserName\Application Data\Adobe\Adobe Soundbooth\2.0 to C:\Documents and Settings\UserName\Application Data\Adobe\Adobe Soundbooth\2.0_Old. I later deleted the library.
After that Soundbooth started.
I still do not know what caused the problem.
Anyone any idea what is happening?
Just got done fixing a problem with the exporteravi.prm plugin and I thought I would share the experience for those who may run into the same problem. Basically, after updating Premiere and After Effects, these programs (plus soundbooth) would crash on load. I noticed that it would always crash while loading exporteravi.prm, so I found the file in each applications directory and removed it. After doing so, all three programs worked.
Michael Feig
I found that my CS4 Soundbooth 2.0.1 startup crash problem was resolved by simply uninstalling Quicktime (as Durin has mentioned), after all of the other trouble shooting methods failed on me. After the uninstall, Soundbooth loaded up perfectly and did not crash during its startup and allowed me to edit some audio files successfully. I haven't tried to reinstall Quicktime yet, to see if the crash reoccurs again, but maybe Soundbooth just prefers to have Quicktime uninstalled and then reinstalled again (after the initial Soundbooth installation)? Everybody's computer seems to have its own individual resolution for the Soundbooth crash problem, so one just has to experiment a little to see which fix actually works. Good luck to future crash problems!
I am getting the same problems. i keep getting a Soundbooth Startup error "Soundbooth could not find capable video playback modules"etc....
I am running on Windows 7 64 bit, with a radeon HD 5600 graphics card.
I have tried downloading the latest drivers, reinstalling soundbooth, doing a system restore, moving/renaming folders and files, holding down shift etc and to no avail.
I tried loading it in safemode too which partially worked, ie i could see the interface but the it got a critical error and crashed.
Any help or advice would be appreciated
That is the error message that comes up on the screen. It fails whilst hanging on loading playerMediaCore.prm, which is displayed on the soundbooth splash screen. I get a similar error if i try and load premiere. Before the first time i got the error i also got a system error saying that the GPUSniffer.exe was not working properly, is this related?
Find the playerMediaCore.prm and move it to a new location..and whtaever
other plugins, while loading, causes the program to crash, move them too.
Also check the http://premierepro.wikia.com/wiki/Troubleshooting
Adobe CS4 suit has way over too many bugs, If u see the forums u
see everyone is complaining.
I wish i cud be more help ![]()
Good luck!
Ab.A
Please move the playerMediaCore.dll BACK where it was. While many plug-ins can certainly be removed for troubleshooting, this happens to be the backbone of the media player in all of the CS4 suite applications and is required.
Generally, the DLL displayed in the startup screen tends to be the last one to successfully load. The error messages you've posted and described indicate an issue with the video driver - chiefly that it is not reporting OpenGL support, which is a graphics acceleration library included with most video drivers. Unfortunately, the drivers installed by Windows tend to be basic and not support the advanced features of a video card that the manufacturer's drivers would. My first recommendation would be to visit the website of the manufacturer of your video card, for example ATI or Nvidia, and install the latest drivers for your video device. For your Radeon HD 5600, you can find the latest ATI driver at http://support.amd.com/us/gpudownload/Pages/index.aspx
I suspect this will resolve your issue, Emma, or at least get beyond the error you've posted so we can continue troubleshooting.
I have tried that, completely removed them and put them back. It was working perfectly fine then it just stopped working. The first thing that came up was a GPUSniffer.exe error, and then i couldn't load soundbooth or premiere. I have tried restoring my system and it didn't work, which leads me to believe its a file on the system that isn't getting removed with a restore or reinstall. Any ideas what it could be?
If i try and run the sniffer its come up with a not working error
I have seen on a lot of forums illustrating problems with it breaking.
I'm having this issue with none of the suggested fixes working. I opened Event Viewer for Applications and notice that whenever I attempt to launch Soundbooth and it crashes before opening a Windows Search Service error is logged to the Event Viewer.
Event ID: 3083
Description: The protocol handler Groove.SearchProtocolHandler.1 cannot be loaded. Error description: A dynamic link library (DLL) initialization routine failed. . Any ideas???
I have SB cs5 and it does not crash when i start just not finishing loading, i get loading playermediacore.prm then nothing,
i moved the nvoglv32.dll from \windows\system32 and that helped, question is how much else is broken now ![]()
I use Win 7 ultimate-N 64 bit, i added some media stuff from microsoft to get the mediaplayer and codecs i guess so i could run
songbird, and the performance index in windows, at that point sb stopped working.
Thank you so much guys. I was racking my brain, pulling what's left of my hair out trying to figure this one out...then I read this posting about Quicktime. I remembered that I reluctantly installed Quicktime a few months ago. I tried uninstalling it, restarted the computer and Soundboth CS5 WORKS PERFECTLY!!! I should have never installed anything from Apple which is my normal policy but I got reckless. THANKS AGAIN!
Deacon_1 had the answer that worked for me! Thanks mate! I'm on Windows 7 on a MacBook Pro. I just moved the ImporterFastMPEG.prm plug-in from the Plug-ins\Common folder - back to the root directory of the Soundbooth installation, and it all loads fine now!
Strange problem though. Before this fix, Soundbooth didn't open 3 times, then it opened, then it didn't, then it did... and after that it never opened again.
Thanks Deacon_1 and ccoltmanhttp://forums.adobe.com/people/ccoltmanhttp://forums.adobe.com/people/Deacon_1
im getting the splashscreen issue, says loading PlayerMediaCore.prm and just sits there... i tried the blacklist thing and got past it to the NV_OGL error, i have nvidia w/ cuda, its a gtx 280 with driver version 266.58 (current) and even tried a fix i saw on nvidia forums about the nvoglv32.dll being inghte wrong spot. when i check the plugin loading oog the last entry is...
Loading C:\Program Files (x86)\Adobe\Adobe Soundbooth CS4\Plug-ins\Common\PlayerMediaCore.prm
There was an error loading C:\Program Files (x86)\Adobe\Adobe Soundbooth CS4\Plug-ins\Common\PlayerMediaCore.prm from the plugin cache
The registry key will be deleted and the plugin will be loaded from disk.
Loading from disk..."
plenty other plugin load from the "disk" fine...
"Loading C:\Program Files (x86)\Adobe\Adobe Soundbooth CS4\Plug-ins\Common\ImporterMp3.prm
This plugin was recognized by loader ba1058cd-0007-44e4-bf1a-0ef51307b979.
Loading C:\Program Files (x86)\Adobe\Adobe Soundbooth CS4\Plug-ins\Common\ImporterMPEG.prm
Loading C:\Program Files (x86)\Adobe\Adobe Soundbooth CS4\Plug-ins\Common\ImporterQT.prm
Loading C:\Program Files (x86)\Adobe\Adobe Soundbooth CS4\Plug-ins\Common\ImporterWave.prm
This plugin was recognized by loader ba1058cd-0007-44e4-bf1a-0ef51307b979."
ive checked the plugin folder and the .prm file is there... so im stuck. any thought.
