how to unbold text in header
Aug 18, 2009 2:13 PM
http://prosol1.com/dreamweaver/index.html
i can't figure out how to turn off the bold on all of the text.  i created a header 5 [smaller text size] and there's no setting to turn on or off the bold.  but all of it is bold.
please advise.
    Aug 18, 2009 2:46 PM   in reply to Michael Walton
    Header 5 (<h5>) is, by definition, a headline style. If you want to restyle it, you may, with CSS.
    Possibly better for you to be using a paragraph style <p>, which you can also restyle, but which does not come with bold styling inherent.
    Beth
    Aug 18, 2009 2:49 PM   in reply to Zabeth69
    <h5 style="font-weight:normal;">
    Aug 18, 2009 3:33 PM   in reply to Michael Walton
    You could add font-weight:normal; to your H5 CSS rule.
    But it would be better to use <p> tags in place of the <h5> since the text is more content than sub-heading.
    Aug 18, 2009 8:18 PM   in reply to Michael Walton
    Michael,
    as others have said, you need to use the <p> tag for your content text, not heading tags.
    Add the following to the other styles in the head of the document:  This is giving a style to paragraph tags:
    p {
        font-size: 12px;
        color: #000;
        font-family: Arial, Helvetica, sans-serif;
    and in your code change the <h5>s to <p>s  like this:
    <h3>Sidebar1 Content</h3>
    <p>The background color on this div will only show for the length of the content. If you'd like a dividing line instead, place a border on the left side of the #mainContent div if it will always contain more content.</p>
    <p>Donec eu mi sed turpis feugiat feugiat. Integer turpis arcu, pellentesque  eget, cursus et, fermentum ut, sapien.</p>
    Only use the <h1> <h2> <h3> etc for headings only.  This is especially important from a SEO perspective as well.  All content text should be within paragraph tags <p>
    Nadia
    Adobe® Community Expert : Dreamweaver
    http://www.perrelink.com.au
    Unique CSS Templates | Tutorials | SEO Articles
    http://www.DreamweaverResources.com
    http://twitter.com/nadiap
    Aug 19, 2009 6:11 AM   in reply to Michael Walton
    You can use a <span> tag to set style of selected text. So for example;
    This text is set in the style called for in your CSS rule <span style="font-size:14px;">but this text is bigger.</span>
    Gary
    Aug 19, 2009 6:43 AM   in reply to Michael Walton
    You can make specific paragraph styles for different parts of your page by making descendant selectors.
    For instance, for the left sidebar text, you might have a div with an id of #leftsidebar (aka <div id="leftsidebar">)
    Then you could make a style like this, which would take the general fontsize for p (which you might have defined as 12px) and make the new size 85% as large, as well as making the line-height more spaced out, at 120%. Technically, it would be 85% of the size of <p> in the parent div.
    #leftsidebar p {
         font-size: 85%;
         line-height: 120%;
    For other content areas, you might have a div with an id of #maincontent. Then you could make a descendant style #maincontent p.
    In each case, you would only need to invoke the <p> tag to get the style, as long as you have id'd the div.
    This cleans up your surface code a great deal.
    Beth
    Jun 1, 2012 10:19 PM   in reply to Michael Walton
    <h5 style="font-weight:normal;"> </h5>
