Premiere Pro not responding
Aug 22, 2009 5:59 PM
  Latest reply: Harm Millaard, Sep 3, 2009 5:39 AM
Replies 1 2 Previous Next
    Aug 26, 2009 2:02 AM   in reply to F.Terh
    F.Terh
    If the BSOD is caused by memory problems, try removing one of the 1GB of memory. Then re-open PPro to try to induce the crash. If yes, put the 1GB memory removed back in after removing the other, again re-open PPro. It is unlikely that both sticks of memory are defective.  I previously ran on 1GB of memory successfully, only working with SD material. It may be the m/board and/or chipset that is defective, new memory may not do it.
    I do not have Vista, but with XP you can do a repair, if a hardware problem the repair sometimes fails.
    The undernoted link states you can safely ignore the error ?????????????????
    "SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 99" could not be reactivated in namespace "//./root/CIMV2" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected
    http://support.microsoft.com/kb/950375
    The error message may be part of the computer domino effect, when something falls over it shows up way down the line with great difficulty in unravelling.
    There seems to be a double post on this problem:
    http://forums.adobe.com/thread/446365
    John
    Aug 26, 2009 2:31 AM   in reply to F.Terh
    This is somewhat similar to problems I had with my previous system. Mysterious hangs, followed by BSOD's. In my case it showed that not memory was the problem, but the PSU. That brings me back to your 8.8V on the +12V rail, as was shown by Speedfan. The fact that the Bios indicates an adequate 12V rail with sufficient voltage does not prove that the PSU is in good health, at least not 'beyond reasonable doubt'. I had the same problem, but it really was indicative of imminent death and I had to replace the PSU. That solved my problems. I'm not saying your case is exactly the same, but it may be worthwhile to have your PSU tested under load and replaced if necessary.
    Aug 26, 2009 4:00 AM   in reply to F.Terh
    Firstly it's not an accidental double post. I posted in two threads in order to reach a "wider audience", as both threads are related to the post.
    Don't do that.  It's not allowed for a number of reasons.
    -Jeff
    Aug 26, 2009 8:38 AM   in reply to F.Terh
    One thing to consider is that PrPro and AE will likely stress your system, more than almost any other programs will. They can show almost any weakness anywhere along the line. May have a bearing, or maybe not.
    Good luck,
    Hunt
    Aug 26, 2009 8:42 AM   in reply to Jeff Bellune
    What happens in a situation like that is that both the poster, and those making replies can get very confused. Many of us reply to many posts in a day. It's hard to follow threads, if they "seem" to be the same. We'll start replying with, "hey, did you see post ______, 'cause someone has the same issue?" Well, it the poster's other article. For the poster, one can get all sorts of answers, as different respondents see different things. Keeping tabs on two posts can be a real nightmare.
    That is why it is not allowed.
    Good luck,
    Hunt
    Sep 1, 2009 6:08 AM   in reply to F.Terh
    The only thing you could try is to use some DV material and see if that encodes OK. If that works, it likely is a problem in the combination of MJPEG source, the MC / Morgan codec and AME.
    Sep 1, 2009 6:15 AM   in reply to F.Terh
    In that case try with HDV and a standard HDV preset.
    Sep 1, 2009 8:46 AM   in reply to F.Terh
    That depends on the HDV camera used and the settings for that camera during your shoot.
    Sep 2, 2009 2:46 AM   in reply to F.Terh
    HDV can never be MJPEG.
    From what camera originates the material?
    Sep 2, 2009 3:54 AM   in reply to F.Terh
    HDV is the wrong preset. You need to create a custom sequence, that reflects what you shot.
    Sep 2, 2009 4:36 AM   in reply to F.Terh
    Something like this:
    Just adjust the audio to the correct settings as well. I forgot that in the screenshot.
    Sep 2, 2009 5:49 AM   in reply to F.Terh
    Check the camera manual.
    Sep 2, 2009 6:23 AM   in reply to F.Terh
    We are now at post # 68 and the only conclusion I can draw from this extended discussion is that your source material from a digital still camera is not suitable for editing with PR and you may be better served with a consumer application like the free WMM or the low cost alternatives such as PE, Magix, and the like.
    Sep 3, 2009 5:39 AM   in reply to F.Terh
    You can show your appreciation by clicking on the relevant button in a post. In total you have three posts you can award points, one for correct and two posts for helpful.
1 2 Previous Next
Actions
