My new and creative LR2.4 work flow.
After all editing is complete and prior to exiting the application, I go into the Preferences and Uncheck the Import box. This way LR2 does not automatically sense and import files when I connect my camera.
The next time I launch LR2 the box will again become checked and I just need to remember to Uncheck it each time as I close the application down. That is better than having LR2 pop up every time I connect my external drives or camera. This works for me but what a pain in the butt ![]()
When I made the initially suggested registry change and also removed the permissions from ShowPicturesOnArrival in the EventHandlersDefaultSection it prevented any program, including LR, from setting itself as the default handler for pictures, so I always get the explorer popup letting me choose which program I want to use. I just need to remember to change that entry back when/if Adobe fixes the problem. ![]()
I always download directly from the CF card, though, not by attaching the camera.
Man this is a really annoying bug. September tomorrow and still no fix from Adobe.
Anyway, I just wanted to add that the registry permissions fix written about in this thread works for me on Windows 7 RC (64 bit).
By the way, I'm in no way affiliated with "Geoff the Kiwi", who given his input into this thread should perhaps change his screen name to "Geoff the Adobe Apologist". It would be nice if someone actually from Adobe put an appearance in to reassure upset users that they are working on this, and advise when we can expect a fix.
Thanks for your input Dave........
There are very few users having problems, maybe you should be looking at why your system has this occur and not others. The last time there was a major issue with an LR release, To Hogarty - the Product Manager, apologised publicly and a dot release was made available asap.
This issue is being investigated and I would expect that the next LR release will not be too far down the line given the release timeline so far. I would expect a fix then - keeping in mind that it is impossible to test any application against all the possible combinations of hardware and software especially those out there for PC's.
We all appreciate how frustrating these things are..........
Yes, on further investigation I was dissapointed to find that the registry edit did not fix the problem.
At first I though it was probably some problem between LR and Windows 7 RC, but then reading this I see others running Vista have the same issue. Seems to be specific to 64 bit versions though. I did send a bug report, and I hope Adobe come up with a fix soon. It's a hell of a lot more annoying than it sounds. It's amazing how many things you plug into your computer have images on them.This morning I opened a Windows Home Server backup, and of course as soon as my machine mounted the backup image, LR popped up and wanted to download several thousand photos. I'm going to see if I still have a copy of LR 2.3 and see if that solves it.
I generally love Adobe software (with the exception of the endlessly problematic Acrobat), but needless to say I've been a bit down on Adobe lately. After recently installing CS3 on Win 7 I lost my internet connection. I eventually discovered that CS3 installs the Apple Bonjour service (I know other Apple stuff does too, but I avoid Apple software on the PC for this very reason), and Bonjour was resetting the default gateway to 0.0.0.0! I killed that service quick smart.
I had the problem on both 32bit vista and 64bit win7, RC and RTM. Changing the registry fixed the issue for me on both. I made the change several weeks ago and have use LR 2.4 many times since then and the fix is still working.
I expect the problem is more widespread than some suspect, since if you always use LR to import pictures you'd not notice the issue.
On Tue, Sep 1, 2009 at 9:19 AM, Marty Mignard<forums@adobe.com> said:
Geoff, if you think very few are having problems with this, please look at the number of people that have looked at this thread. It is over 7000 now! I have never seen a thread here with this number of hits.
I've looked at this thread, and I don't have this problem. So the
number of views is not necessarily indicative of the number of people
who have the problem. Some might read it, trying to help; some might
be curious, in case it comes up in future; etc.
If the official response from Adobe was to revert to v 2.3 it is a non option for me. Version 2.4 apart from providing support for more than 20 new camera models there were several bug fixes included. To revert to 2.3 now would be going back in history about six months.
This issue is more of an annoyance than a performance bug. I see no reason why Adobe could not have corrected this with a version 2.4.1 if that was the only fix. Its a slap in the face for paying customers.
I'd be willing to bet this does not occur on the 23 bit version ![]()
I just let this happen. Ignoring this issue. I tried the fixes and workarounds. Started again. I actually run both 2.0 and 2.4. How about that. Why? Because of some crappola issue with Sigma RAW that has never been corrected. ![]()
My XP machines do not have the issue.
My Vista and Win7 machines, do.
LR 2.3 was fine. LR 2.4 was not on Vista and Win7.
If you have not had the issue and using LR 2.4 on Vista or Win7 then people would like to know.
I suspect you're using XP or a Mac or are answering No to a UAC about LR monkeying with the registry.
Just been putting up with this silliness for months (since upgrading to 2.4 back in June) and then checked again today to see if there was any new solution. I followed jmlphotography's steps posted on 8/16 and they worked like a charm for me. No more LR2 popping up whenever a flash drive is inserted or a camera attached. I can CHOOSE to run LR2 import, but when it's no longer starting up all the time when I don't want it. Thanks.
After posting a previous comment, I've discovered that I have this problem exactly. And after reading many volumes of comments, it appears Photoshop LR 2.4 is not fixed, nor is there a fix. I feel ripped-off. Not only have Adobe failed to "make good" on a a fix. They have failed to offer us something better as a free replacement. I think this is totally unacceptable. I've bought many Adobe products over the years, but this one has spoiled it. http://web-max.info
Your comment is totally off base.
If you are using LR 2.4 then update to LR 2.6. This has been fixed since mid-September with a free update from Adobe.
If you are using LR 2.6 and don't want LR starting up when a memory card is plugged in, then uncheck the relevant preference on the general tab that deals with LR starting up when a memory card is detected.
Others have already replied to your comment. Yes, it is fixed and working FINE. My only complaint now is that Adobe removed the option to compress or not to compress DNG when importing files to LR. I am a firm believer in "not compressing". Regardless what some people say, you do lose information in compressing. Granted, it might not be that noticeable; but, I don't want anything lost and Adobe should leave that decision to the user. (They are like Microsoft now -- deciding what the user should have.)
Lossless compression is just that. You don't lose information.
If you have a special need to not compress, imagined or real, then you still have a choice if you use the DNG Converter. It is just less convenient.
Removing the compression setting is likely in preparation for the entirely new Import interface in LR 3.
Lossless - Don't believe it. The articles I have read state otherwise. Although, they state it is negligible and you may not notice it. I am of the "old school" and do not like to compress, especially on important jobs. I am not concerned about space; just have to use more DVD's when archiving.
Yes, using the convertor method is less convenient.
